Question about Remington 16" Electric Chain Saw
Chain came off remington chainsaw now will not run
Put chain back on and plugged in saw and will not run
    Sergeant:
  • 458 Answers
If you can't move the chain around the bar it is too tight.Back off the tension.Put on some gloves and see if it will move. If it was so loose that it came off the driver links could have been damaged and you will need to replace the chain because the drivers have burs on the side of them and are to wide to slide in the grove of the bar
Posted on Nov 04, 2013
SOURCE: Remington 16 in. electric chain saw
Go to www.masterparts.net Remington chain saws are listed by bar length and model number. There is a parts list with each saw.
Posted on Oct 31, 2008
firesnake09
  • 2923 Answers
SOURCE: Owners Manual for a Remington 2.5 HP 16 '' Chain saw, Model EL-7
Kindly check this link for manual. Please select the correct model:
http://lawnandgarden.owneriq.net/manuals/mfg/remington/remington_chainsaw_product_list.html
Posted on Apr 18, 2009
  • 188 Answers
SOURCE: Remington Pole Saw Model # 106890-020 - Chain Oil Cap broke
Call Master Parts at 1-800-446-1446, or go online at www.masterparts.net. They have the part (107512-01) you need. I hope this helps...
Posted on Apr 27, 2009
  • 188 Answers
SOURCE: I need an owner's manual for a remington electric chain saw
Here is the owner's manual for the M30016AW... http://12.153.20.74/manuals/113005-01G.PDF. Here is also the instructions on the installation for the chain that goes on the your saw ... http://12.153.20.74/manuals/113556-01A.pdf. If you are need of a part you can conatct Master Parts at 800-446-1446, they can also help you. I hope this helps!
Posted on May 27, 2009
dontbother10
  • 2220 Answers
SOURCE: repair parts for LNT-2 remington chainsaw
I went here:
Remington.com
http://www.desaparts.com/index.htm
  • Typed "LNT-2" into the "Model #:" window, then clicked search.
  • Click the LNT-2 12 - Remington Electric Chain Saw "View Model" link.
  • Click "View Illustrated Parts Breakdown" I think you want item 12, 107713-01, Internal Gear
  • On the original view in the "Search for your parts by Part #:" type "107713-01" and click "Search"
  • Click the 107713-01 - USE REPLACEMENT PART # 122511-01 "View Part" link.
Results follow:
Part #: 122511-01 Price: $16.99
SPROCKET DRIVE GEAR BEARING KIT 747
3 piece replacement kit.
If this is what you need I suggest you order it soon.
RemingtonPower has stopped production and replacement pars are almost exhausted. Sooner or later a part you need will be NLA. HTH
Lou
Posted on Nov 10, 2009
Remington manuals
For an electric saw, just add oil to the chain oiler, plug it in, and cut away. Do not put any body parts in contact with any of the moving parts of the saw.
Sep 02, 2014 | Remington 10" Electric Pole Saw Chain...
Remington chainsaw gas/oil ratio?
If this is an electric saw as the title says the only oil you put in it is bar oil. This is a thick oil to lubricate the chain and bar. If it is a gas powered saw you will need to mix the gas with 2 cycle oil.
Jun 05, 2011 | Remington 16" Electric Chain Saw Assembled...
I have a remington electric chainsaw model 107624-02. The chain came off I put it back on and the saw will now not start. It worked perfectly before this. What are the most likely problems and how can I...
It is possible there is a micro switch in the chain brake handle, grab the hand guar and pull it fully back to the top handle, it should click when the brake has dissengaged, now try again.
May 08, 2011 | Remington 16" Electric Chain Saw
THE CHAIN SAW RUNS. THE CHAIN XS NEW. IT DOESN'T CUT THE SMALLEST OF BRANCHES
I don't mean to sound offensive, but is the chain on the right way? I've put 'em on backwards, even started the saw before I noticed. And is the chain running when the motor runs?
If the chain is right then you may have gotten a chain with a bad grind. Never heard of it but it could sure happen. Get back with me if the chain is right and it's turning- we'll get it to cut.
lp
Jan 10, 2011 | Remington 111409 - 01 6" Branch Wizard...
Remington 14" Electric Chain Saw Assembled 1.5 Peak: I just wanted to know what type of oil to put in t...
I have been using regular chainsaw oil and I think it works ok. I inherited one of these and would like to find a spare chain and also a manual. Can you give me any info? Thanks
Tim
May 17, 2010 | Desa International Remington 14" Electric...
The chain came off of my Remington 16" electric saw. How do I put the chain back on?
If the saw was at speed when the chain came off there are probably burrs on the chain drive links (the part that goes in the bar). They often cause binding and in extreme case may cause the chain to ride up and off the bar when operated. Use a file on the drive link flats to remove all burrs.
An Operator Manual far almost all models of RemingtonPower chainsaws can be found here:
Remington.com
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
HTH
Lou
Dec 28, 2009 | Remington 16" Electric Chain Saw
Chain fell off chain saw remington 10" pole saw, need directions to put back on.
Look from the side of the saw the motor/engine to left and the bar nose to the right. The thinnest part of the chain (sharpened edge) on the top of the bar is to the right.
Sep 26, 2009 | Remington Electric Pole Saw
Replancement bar for 16 inch remington chain saw
The bar is the piece of metal that the chain goes around. This link has lots of info on your saw http://www.remingtonchainsaw.com/chainsaw.html
Mar 31, 2009 | Remington Electric Chain Saw
Oct 27, 2008 | Remington Electric Chain Saw
Remington 16" Electric Chain Saw Logo
104 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
