Question about EPoX EP-4BEAV Motherboard
Motherboard install. upon startup I get nothing but a constant fast beeping, no video or anything.
  • 104 Answers
First Check your Memory is inserted properly or it works fine
Next, if you use Video Card make sure it is fitted correctly or working fine
Posted on Jan 05, 2009
  • Vanbiak Thanga
    Vanbiak Thanga Jan 05, 2009
    Fast beeping is the indication of faulty Memory or Video Card error!
I have a P5K Deluxe asus mother board error beeps no visuals
Two beeps is usually the video card.
Do you have a spare video card to change out?
This is why people keep obsolete PCI video cards for just such tests.
Dec 05, 2015 | ASUS P5k Deluxe Socket 775 Motherboard
AMD sempron power supply
I would venture that "shows winfast on monitor" indicates the type of Video Card that your PC is using. Thereafter it should go to POST showing the motherboard, BIOS, memory count and others.
Since as you posted, after Winfast nothing follows, I can only suspect that you have a motherboard problem or at least a BIOS corruption.
Please post back the brand and model of your computer or at least what motherboard.
Good luck and kind regards.
Thank you for using FixYa.
Mar 16, 2008 | Computers & Internet
I have a quanta 3082 MB in a HP Pavilion zd8230us laptop when I startup it beeps constantly got any ideas? anyone
The beeps with have a pattern to them. Listen closely when you first turn the laptop on and listen for the pattern. It might be something like 1-3-2 (1 beep, wait, 3 beeps in a row, wait, 2 beeps) It will repeat for listen for a bit to make sure you have the correct pattern. Once you have that pattern got to the HP webpage, in the support section, in the search type in "beep code errors". It will give you a list of beep patterns and tell you what the problem is. It could be the RAM, it could be another problem with the motherboard; those codes are what you need to have first.
Dec 24, 2014 | HP Computers & Internet
Dell xps 9100 constant beeps upon startup
Beep Codes
Your computer might emit a series of beeps
during start-up if the monitor cannot display
errors or problems. The following repetitive
beep codes help you troubleshoot problems
with your computer.
NOTE: To replace parts, see the Service
Manual on the Dell Support website at
support.dell.com.
One beep - BIOS ROM checksum failure;
possible motherboard failure
Contact Dell (see "Contacting Dell" on page 53).
Two beeps - No RAM detected
Remove the memory modules, reinstall
one module and restart the computer. If
the computer starts normally, reinstall anadditional module. Continue until you have
identified a faulty module or reinstalled all
modules without an error.
If available, install memory modules of the
same type in your computer.
Three beeps - Possible motherboard failure
Contact Dell (see "Contacting Dell' on page 53).
Four beeps - RAM read/write failure
Ensure that no special memory module/
memory connector placement requirements
exist (see the Service Manual on the Dell
Support website at support.dell.com).
Verify that the memory modules that you are
installing are compatible with your computer.
Five beeps - Real Time Clock failure
Replace the battery.
Six beeps - Video BIOS test failure
May 22, 2014 | Dell Studio Xps 9100 Desktop Computer
Dell Dimension 9200 beeps on startup, with nothing...
A beep code of 3-3-4= Video Memory(RAM) Test Failure that would explain why you get nothing on your screen the first thing you would need to do is disconnect your monitor and try it on another computer. if it works fine then the problem is your video card. If that the case and the video card is intergrated with the motherboard, you will need to repalce the motherboard --- Sorry-- Please vote me a 10 when this works
May 20, 2010 | Dell Dimension 9200 PC Desktop
I have a dell small form factor with a foxconn ls-36 mobo, upon power-up it gives me ram beep and power to fans, etc., but as far as anything else, nothing, also, mobo lights up but stays constant, no...
you could have a bad board, bad video card, bad processor, any number of things. try reseating the video card, if it is not onboard, does it post? just not enough info here to solve it
Jul 08, 2009 | Dell Computers & Internet
No video at startup
The beep code you mentioned is either a video problem or RAM problem, that is what the beeps mean. Check your RAM one by one in case you got a bad stick, making sure they are properly seated in the slots. Since a new video card did not slove the problem then it also could be a motherboard issue, video slot dead. If your motherboard is still under warranty contact the manufacturer to see if they'll send you a new board. These are the common problems for the symptoms you describe. Hope this helps.
Apr 24, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Not booting, i mean even getting past post.
how many beeps..3 long beeps means no memory signal, 3 short beeps and 1 long beep means some pci cards is damage or not working properly.
Oct 21, 2007 | Intel Motherboard
No beeping, no video displayed.
hi, The beep test is notrmally done with the small speaker attached to the computer internally, there could be a problem with the RAM installation check the RAM compatablity with the mother board, give me further details of the make and model of the mother board and RAM , i will try to help you.
Jun 30, 2007 | Abit LG-95Z Motherboard
EPoX EP-4BEAV Motherboard Logo
87 people viewed this question
Top EPoX Computers & Internet Experts
David
David
Steven Wander
Steven Wander
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
