Question about LG WM-2077C Front Load Washer
Need Boot gasket for wm2077cw without drain port on bottom and no ports on top Need a part number
Bought 4986ER0004f has port on bottom and think I bought 4986ER0004B had open port on bottom and 3 on top. Last part may have been mixed up and may have been another part. On inside it read 4986ER0004 No 13 and original read 4986ER0004 No 4. Think the 4F ready 4986ER0004 no 33. There are a lot to choose from and need the right one!
2 Suggested Answers
  • 566 Answers
SOURCE: Retro-fit drain hose
hi not seen one of these retro types but having always wiped the seal and door after use as recommended with clean damp cloth prevents seal deteriation i would have thought this drain?on retro type that drains accumulation of any water from seal would be draining inside the outer drum and thro to drain into pump? seems odd?
Posted on Oct 22, 2008
Tip
Fuel line routing for ryobi,poulan and sears trimmers
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up against tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulb goes to top port of carburetor. that is the way they go on.it is important to make sure you have the same fuel line I.D. and O.D. are very important! also if old line dissolved it will get in carburetor and clog ports & small screen inside.clean inside of carburetor with carburetor cleaner & air pressure. to get your parts and numbers ,go to mtd parts.arinet.com, parts,791-683398,fuel line assembly.hope this helps
.hello sir,routing fuel line for craftsman,homelite, trimmers,fuel tank over engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carburetor fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carburetor fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carburetor fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carburetor when replacing fuel line it is very important to use the same ID and OD line,when the lines dissolve small pieces will get in the carburetor clogging small passages and screen,it is advisable that you clean out carburetor and use a new filter.hope this helps, DON'T FORGET THE 4 THUMBS UP,,,,any comments welcome,thank you.
on Feb 27, 2010 | Garden
Hi there, our dishwasher hasn't drained. we are assuming that it may have something to do with the pump. Is there anyway that we can see if it's the pump before we call someone in to look at it? Or...
Hi and welcome to FixYa, I am Kelly. Without your model number this is a very GENERIC response. With a MAKE & Model number I could pass exact steps as to how to go about troubleshooting. Having said that here goes. You did not mention if the drain pump was running and it was not draining so for the mopment I have to assume the motor is running but the unit is not draining. Do the following steps:
1. Remove the drain hse from the sink connection and check the drain port for a clog. This is usually a garbage disposal connection but it can be a direct connection. Re-connect the drain hose after checking / clearing the drain port.
2. If you have an Air-Gap on the back of your sink or near the dishwasher, lift the cover up and off of the Air-Gap. In the very top of the Air-Gap there is a plastic threaded nut you must unscrew to gain access to the the drain plumbing in the top of the Air Gap. NOTE the installed position of the cap as it will only install one way. Remove any debris in this area. Use a wire coat hanger and a flashlight if necessary to clean the port that exits to the sink connection. The open plastic tube you will see is the connetion from the dishwasher. This should also be clear. Reassemble the Air-Gap in the same manner as dis-assembly. Reconnect any hoses if you removed any to clear drain ports.
3. Make sure power to the dishwasher is secured and remove the lower kick panel. Remove the drain hose from the pump housing and check for debris in the pump and pump port. Clear out any debris in this area.
4. Here is where not having the model number comes into focus. Without that model number the procedures for checking the tub sump and impeller are drastically different. The bottom line is the lower wash arm and support are removed.. any sump covers are removed and the screens / fins in the sump area are to be cleared of debris. Dome units the impeller is in the sump... other units the impeller is in the motor pump assembly that has a macerator before the pump inlet. If the inlet to the pump / motor is clogged it must be cleared. On units that have the motor pump assembly directly in the bottom of the unit there can be 2 levels of water flow. Upper for dishwashing and lower for draining. All passages in this area must be cleared.
Steps 1 and 2 above fix about 80% of the drainage problems. Test for drain function after steps one and two.
Thanks for choosing FixYa,
Kelly
Jun 18, 2011 | Dishwashers
I have just purchased a used LG washing machine Model number WM2277hw. The door boot or bellow needs to be replaced due to visible and SMELLY mold/mildew. What part do I need to buy to ensure that I am...
The part number for that door gasket is 4986ER0004F.
Yes, you can replace it, it is held on by a spring clamp on both the cabinet, and the tub. The spring on the cabinet can be simply removed with needle-nose pliers. The easiest way to remove the inner spring without LG's special tool, is to remove the front panel. To do this, remove the top panel by removing 2 screws on the back, and sliding the top panel back. Then the control panel needs to be remove. Remove the dispenser drawer. Remove the 2 screws that are now visible where the dispenser drawer was. Then on the opposite side, on the back of the control panel, there is one more screw. Remove this. The control panel will now come off. It will require some prying on the upper edge to snap off. Now open the washer door. Remove the 2 screws by the door lock. Now go to the bottom of the unit. Open the drain trap door with a flat-blade screwdriver. Remove the one visible screw, and then pull the plastic housing out, There should be one more screw on the bottom. Remove it. Now go back to the top of the panel, Remove the 4 screws holding it on, and the panel will now fall forward towards you. USE CAUTION! Edges are sharp! Unplug the door switch harness plug. Now you can access the rear spring ont the door gasket. It can be removed with a pair of needle-nose pliers. The gasket will just pull off... Now reverse everything, and you are done!
May 16, 2011 | LG WM1814CW Front Load Washer
LG WM2077CW Front Load Washer Problem My LG Tromm model # WM2077CW is leaking at the bottom of the machine but not from the door. If you run your hand along the bottom front of the machine there is a seam...
MOST OF THE TIME IT IS A HOSE THAT HAS RUBBED A HOLE IN IT OR THE DOOR BOOT DRAIN HOLE. THE HOSE IS ATTACHED TO THE BOOT BOTTOM CENTER OF THE BOOT AND HAS A SHORT HOSE THAT RUNS BACK TO THE TUB..
Apr 25, 2017 | LG WM2077CW XL Front Load Stackable Washer...
Replace boot gasket
Hello, Remove the door hinges and plastic covers on the unused hinge screw holes on the opposite side of the door opening (door is reversible, so there are places to mount hinges left and right). Front panel will now snap out at top and lift off lower spring clips. One screw on each side will now release top panel and it will hinge up. Prop up with broom handle or something. Now you can get at everything. Rubber gasket is held onto drum with a cable loop and very strong spring. It rolls off the lip easily to disassemble but is VERY difficult to get back on without special tools or at least two people. Door side of rubber gasket is easy in comparison with rubber tabs inserted into slots and working the gasket into a groove. Hose clamp at bottom of rubber gasket to connect drain hose.
Thanks
Jun 10, 2010 | GE WSXH208A Front Load Washer
Replace gasket on a LG WM2077cw
can't tell you the part number but it's not to complicated. first shut off the water supply, then flush the toilet to get the water out of the tank, then remove the water supply line, then unbolt the tank from the bowl and replace the gasket. be carefull when tightening the tank back up, you want to do it evenly and only untill the tank is solid. or you can crack the tank
Aug 08, 2009 | Kohler KOHGP51487 Authorized Original...
Can i connect a presario v3500 laptop to an external momitor. @I think the display inverter is gone and i need to get some files off the lap top for work.
Yes, connect the external monitor to the port it corresponds on the laptop, usually the blue port. When you boot the computer hit the FN key located on the bottom right hand side of your keyboard and the LCD/CRT key i believe this will be the F4 key located on the top part of your keyboard this should activate the external monitor.
Tang
Feb 23, 2009 | IBM ThinkPad T23 2647 Notebook
Change rubber gasket
Remove the door hinges and plastic covers on the unused hinge screw holes on the opposite side of the door opening (door is reversable, so there are places to mount hinges left and right). Front panel will now snap out at top and lift off lower spring clips. One screw on each side will now release top panel and it will hinge up. Prop up with broom handle or something. Now you can get at everthing. Rubber gasket is held onto drum with a cable loop and very strong spring. It rolls off the lip easily to disassemble but is VERY difficult to get back on without special tools or at least two people. We used strong vice grips and much struggling and sweat, and #@*&%!&@ and finally got it on without damage to the new gasket. Door side of rubber gasket is easy in comparison with rubber tabs inserted into slots and working the gasket into a groove. Hose clamp at bottom of rubber gasket to connect drain hose.
Sep 05, 2007 | Maytag Neptune MAH5500B Front Load Washer
LG WM-2077C Front Load Washer Logo
99 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
