Question about Canon PIXMA MP130 All-In-One InkJet Printer
Canon pixma mp560 ink cartridge rack won't move into middle for cartidge removal
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Posted on Jun 21, 2008
SOURCE: Canon MP560 ink level override
I have the same problem, BUT once the printer detects the cartridge is either empty OR replaced by a generic, it does NOT print at all. It freezes up and refuses to do anything (scan to USB, scan to PC, scan to PC application) until you put in a genuine Canon cartridge. My previous iP PIXMA 4000 the MP560 replaced worked fine with generic cartridge refills. Had for 5 years. But the MP560 is smarter. How can you override this problem? Thanks TDK
Posted on Mar 04, 2010
pheireith244
  • 310 Answers
SOURCE: My canon pixma MP560 is
Remove your black cartridge and check that the ink might be over flow or block.... so clean it up with soft paper... thanks
Posted on Sep 01, 2011
  • 693 Answers
SOURCE: Hi, I have the Canon
Installing ink cartridges:
Make sure that the machine is turned on, lift the Scanning Unit (Printer Cover) with both hands, then pull the Scanning Unit Support (A) down into place.Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.Note: - Do not attempt to reattach the protective tape once you have removed it.do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
  1. *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  2. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)Confirm that the ink cartridges are installed properly.OR
  3. <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  4. Fold the scanning unit support and close the scanning unit (printer cover).
  5. Wait until the preparatory operation is complete; it takes about one to two minutes.
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
Posted on Sep 24, 2011
SOURCE: canon printer won't recognize new ink cartridge
did you take the shipping tape off of the cartridge? It's usually the one covering the contacts located on the underside of the Cartridge that is inserted into the receiver of the cartridge. Other wise, you may have a bad cartridge, if so, bring it back to where you purchased it and get another one. Chris Chrisab123@live.com
Posted on Feb 28, 2012
Canon pixma mp560 printer error b200
Leave the cover open, turn off, before it off, hold the reset & Start (color) until it completely off, then turn it back on. it works for me, good luck folks
Jun 29, 2012 | Canon PIXMA MP560 CLR INKJET P/S/C/F FB WL...
Ink cartridges won't move to the left, error code 6000
You will need a new carrage motor for this, better off with a we printer.
Jan 09, 2012 | Canon Pixma iP2600 Photo InkJet Printer
I am trying to change my ink, when I open the scanner the cartidge do not come to the middle so I can change it what can I do to correct this problem.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Sep 06, 2011 | Lexmark X2350 All-In-One InkJet Printer
My canon pixma MP560 is not printing black even though I have a full cartridge
Aug 31, 2011 | Canon MP560 All-In-One InkJet Printer
I bought some new ink cartrige from Canon for my MP560 but it says that my printer doesn't recognize this ink, and the error U140 appears on the screen. What should I do? I know it's the right ink...
Before trying anything else, make sure that your refill cartridge is seated firmly in the moving printhead assembly. I had one that I had to play with a while until I got it to seat properly.
If you are not using genuine Canon ink tank replacements, you will get an out of ink warning. This may not be related to your problem, but if it is, you need to buy replacements that have the little computer chip that tells the printer that it has a new ink tank if you want the printer and software to think it has a full ink tank. I use a third party ink system with a resettable chip. When the ink tank is removed it resets to tell the printer it is a new, full ink tank. The downside is that, if I remove a partial tank for some reason, it resets and the printer won't warn me in time before the tank goes dry.
Jun 20, 2011 | Canon MP560 All-In-One InkJet Printer
Renewing ink cartidge
Turn the printer on. Lift up the cover on your printer. You will here the cartridges moving, then they will stop, in your case, i guess in the center, but if not, just look and you will surely see them (they may be either in the center or on the left or right end of the printer). Then just put your hand on the cartridge and gently pull down. You will not break anything, promise :)
Apr 02, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Where can I find the serial number on my canon mp560
For Canon PIXMA MP560 printer the serial number is INSIDE the printer. Lift the lid as if you were going to change the ink cartridge. When the cartridge slides to the left, you will be able to see a small white sticker inside the track with the serial number printed on it.
Feb 11, 2010 | Canon MP560 All-In-One InkJet Printer
Just press and hold down the STOP button :) Works a treat :)
Dec 28, 2009 | Canon MP560 All-In-One InkJet Printer
WRONG CARTRIDGE and Printhead does not move MP780
your printer ink cartridge can not access (move to middle) when you open up the cover, you may try
1) try to open right side cover you move the cartridge by hand (power off) to middle position, then take out the cartridge and reinstall it then power on, the cartridge moving right, you may open up the cover again if the cartridge go back the middle position which means your printer works normal. still stop moving go next
2) check the cartridge initcial sensor at righe side, the cartridge moving to the end of right should be touch this sensor, find out it and check there is good touch (click) by the cartridge body. adjust the sensor position maybe needed.
3) cartridge is stucked sometime also check the cartridge moving rail hard moving, need to drop oil to lubricate.
Feb 07, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
42 people viewed this question
old marine
old marine
