Question about RCA DRC8040N DVD Recorder
Rca dvd recorder DRC8040n frozen with red rec light allways ON and it does not do anything now. I unpluged it and it still does same thing stuck frozen with red light. I have pressed buttons and nothing works it just froze up. Any Ideas On how to fix this?
atlasuk2007
  • 85 Answers
SOURCE: RCA DRC-285 DVD Player won't respond
hi, 2 things usually cause this kind of behaviour 1-the dvd+r have been burnt at a high speed 2-the dvd player itself is a bit old when you burn your dvd+R always burn them at a lower speed lowest if possible it'll take longer but it's well worth it and you wouldn't have a problem playing them back
Posted on Aug 22, 2007
SOURCE: Unit totally locked up
I called the secondary 800# as the number in the manual has a recording for "if you are calling about the drc8335 call 877-805-0519" how bout it? A separate number just for this unit?
The guy said to unplug the unit for at least 30 MINUTES & that I would have to rescan in all the channels I have spent alot of time scanning in by rotation of the antenna. Geezzz I wish I had returned it to the store before the 90days were up... (price has dropped below $150 was 219 last year?)
Posted on Mar 19, 2008
GSAN
  • 106 Answers
SOURCE: rca dvd\vcr locked on hello
The hello issue is most likely a faulty DVD-RW. These go out on thse models more than usual. Reset is a combination of 2 buttons. Press and hold the play and disk tray open or the power and play ( i forgot the exact sequence but you get my drift, press 2 buttons for about 10 seconds). You can also update the firmware...or atleast could before from RCA.COM but they no longer support this midel. I do have the software update on CD but it won't do any good on Hello issue. If worst comes to worst, open the player up and replace the DVD-RW drive.
Posted on Jun 19, 2008
Mike Adams
  • 19 Answers
SOURCE: RCA DRC8312 DVD/VCR player is stuck on Hello
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20 minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Posted on Nov 27, 2008
umasatish
  • 3 Answers
SOURCE: When turned on stays stuck in Hello mode and nothing works.
You cant solve this problem . This is internal problem . So you first contact the experienced mechanic. do first
Posted on Jun 02, 2009
How do i record with my dvd player/recorder?
You have to go to Menu Page select timers and from there you can record your programs to record at any time. If you are watching something you want to record click on REC on remote it should have a little red dot on the button,then it will take you to where you program how long you want to record.
Hope this helps Donna
Feb 19, 2011 | RCA DRC8052N DVD Recorder
How do i connect dvd player to dvd recorder
you need a tri-color (red,white & yellow) rca cable wire w/ gold tips.....either on the front or back of dvd-rec ....connect wire to the in (line 1 or line 2) coming from the play out on the dvd-player....your dvd rec is still connected to the tv right...on the dvd rec using remote select line 1 or 2 which ever is connected...(test..by playing a dvd in the player..if you see the picture plus hear the audio this means its connected correctly and can be recorded)...note some Disney dvds are not recordable...hope this is helpful.............feel free to rate
Jun 14, 2009 | RCA DRC8300N DVD Recorder/VCR
Dvd player/recorder wont work
I had the same problem with my sansui san0218-160 dvd recorder, i found a capacitor had failed on the power supply board, i replaced the capacitor and it now works perfectly.
Feb 20, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
My Magnavox MWR20V6
If unit is still under warranty return it. If unit is still sold at the orginal place of purchase buy another and return the first one stating it wont work and get a refund
1) power source is good? (receptical on the wall or power unit. Locate DVD rec. to another receptical and check Rec. again)
2) power cord going to unit is good, no cuts or melted spots
3) power setting on unit is correct (small red slide type buttong for different country voltage settings)
4) internal fuse, change it even if it doesn't look bad.
5) Weigh the cost of a new one to the repair cost of the old one. If you buy a new one get a good brand RCA is still one of best and longest lasting.
Jul 18, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Sansui dvd recorder SAN0901
turn the power on. to get rid of the red light you need to press the timer/rec button on the remote until it turns off. the red light means it is programed to record.
Dec 01, 2007 | Sansui VRDVD4005 DVD Player/VCR
Not Able to Record/Playback
can't record on the my Olympus VN-1000
+ I press rec button and it just shows rec in display (no recording time is shown ONLY rec)
+ there is no play back  or stop function
+ i can only stop  rec by removing batteries (stop or play will stop rec only ONCE - but there is no  useful function - such as play or stop or rec.)
+ I tried all trouble shooting tips in manual  with no effect
+  i cleaned the spring contacts inside battery compartment that interface with the  batteries
+ it was barely used - and has not been used for a 1 year ( no batteries were inside it )     it was inside a drawer
THANK YOU
Jun 16, 2007 | Olympus VN-1000 Digital Voice Recorder
My RCA 8310 DVD+R/+RW -VCR Combo will not format and record on a +R disc
I purchased this RCA 8310 about 2 years ago. I have recoreded hundreds of dvd's. If I try to use anything but a Imation brand DVD+R, 8+ speed, I get the same error. It will not work with a 16+ dvd.
May 23, 2007 | RCA DRC8300N (DRC8300NWITHREBATE) Burner
RCA DRC8040N DVD Recorder Logo
54 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
