Question about Honeywell Programmable Thermostat Heater
Honeywell 8000 snowflake flashing - Honeywell Programmable Thermostat Heater
5 Suggested Answers
  • 340 Answers
SOURCE: flashing snowflake on display
That is a Time delay normal to keep the condensing unit from turning of and on to fast really save the life of the equipment
Posted on Jun 17, 2009
  • 232 Answers
SOURCE: honeywell thermostat display has flashing
the flashing snowflake is it telling you its in % min delay if it doesnt stop flashing within 5min it may be a bad tstat. if it goes solid and the unit is still not working its probably not the stat
Posted on Sep 12, 2009
  • 2006 Answers
SOURCE: theres a snowflake type symbol
When the snowflake is blinking it usually indicates something is wrong with your AC. The first thing you should do is to verify that the power is there and don't forget the switch to the blower next to the furnance.
Then see if the exterior fan is working/spinning. If it isn't, then it could be the contactor-relay or the capacitor or the compressor. I always recommend that the contactor-relay and capacitor be replaced at the same time because they have similar failure rates and if you replace one now, the other might fail shortly later, but use your best judgement. They aren't that hard to replace, but make sure the power is off before you do it.
You can find the contactor-relay and capacitor from this site: http://www.hvacpartsoutlet.com/Goodman-45/5-mfd-370-Volt-Round-Dual-Run-Capacitor-CPDRG455.aspx and if you aren't sure which one to order ask the site and they will help you.
Now if the compressor is bad, which you can check with an ohm meter, then you will need a professional to change it since there is freon to be captured and then to charge the system.
Posted on Aug 17, 2011
SOURCE: Honeywell Thermostat RTH110B
It probably has stopped outdoor unit and the blinking is to be done when working anamoni.afto heating and not to bring in cold air flashes the LIGHT as long heated air into the condenser.
Posted on Nov 04, 2011
What does the snowflake mean on a Honeywell thermostat in cooling mode. Also had the problem in the heating mode.
The snowflake means it's cooling. If the outdoor unit is not running then the problem is likely outside.
May 21, 2017 | Honeywell Heating & Cooling
Flashing snowflake
The flashing snowflake means it is in the cooling mode, but is waiting for itself to 'time out' after a call for cooling. It should be about a 5 minute delay then should come on automatically. At that poing, the flashing snowflake becomes steady.
Try it one more time and set the timer on your smart-phone to ten minutes before you touch it again. If that time elapses and no cooling and it is still flashing there's possibly a problem in the thermostat that will necissitate replacement.
Aug 02, 2014 | Honeywell Heating & Cooling
Honeywell fault codes
Not an operating system error.
Terry
Jul 15, 2014 | Honeywell T8411R1002 Electronic Heat Only...
Nov 01, 2011 | Honeywell Electronic Programmable...
What does it mean when the snowflake flashes?
a flashing snowflake indicates a time delay in cooling and a flashing flame indicates heat delay and both are normal
Oct 08, 2010 | Honeywell Programmable Thermostat Heater
Flashing snowflake symbol and a/c is not blowing upstairs
flashing snowflake normally means it is in a time delay. give it five minutes and see if it continues.
Jul 20, 2009 | Honeywell Electronic Programmable...
Flashing snowflake on display
Jun 16, 2009 | Honeywell Programmable Thermostat Heater
Honeywell thermostat display has flashing snowflake /ac not working
Jun 13, 2009 | Honeywell Electronic Programmable...
My Honeywell rth230b thermostat continues to give me a flashing snowflake signal and will not allow the AC to turn on.
Your snowflake should flash for about five minutes, that is the time delay built into the thermostat. It should stop after that and your system should begin to function.
May 28, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
75 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
