Question about Visual Land V-Touch Digital Media Player
When plugged in it turns on, but when plugged off it does'nt turn on
    Master:
  • 545 Answers
Most likely, the battery is no longer holding a charge and needs a replacement.
Posted on Nov 10, 2012
My jvc does'nt have sound coming but it humes when turned up
test the power supply, filter, diode, fuse. c.breaker, audio i-f detector, output amp, see the block diagram attached.
God bless you
Oct 11, 2012 | JVC Televison & Video
94 Toyota Corolla engine problems
Take a compression test on # 4. It may be a little oil burning w coolant getting by the head gasket. POSSIBLE faulty injector or not firing on time. Ck for any oil in the anti freeze or anti freeze in the oil.
Mar 04, 2017 | 1994 Toyota Corolla
Hi, i have a fujitsu siemens v6535 with windows 7 ultimate & my wirless switch doese'nt work, it may be broken, i tryed every way to turn it on from windows(fn+f1 & other ways) ???? how ca
Have you tried turning it on manually? Look on both sides and in front of the laptop for the switch.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
May 10, 2012 | Computers & Internet
I have a dell inspiron 560 with 6 wires from the front panel power switch. which wire is yhe positive for each set? the color for each set are as follows power switch colors are 1) blue and brown 2)power...
Led's only work one way, so it does'nt matter what colours they are. The led's that they connect to will only work when the plug is the correct way. You wont do any harm if they are wrong, you just turn them round. Plug them in one way and if the led for the hard drive does'nt come on then it's the other way. Same with the power light. The power switch when pressed just makes a momentary connection across 2 pins, so it does'nt matter which way, it's just like touching the pins quickly with a piece of metal.
Feb 11, 2012 | Dell Inspiron 560 PC Desktop
T6216
There should be 2 rows of pins in parallel usually around the bottom edge of the motherboard. The markings for which is which should be next to them on the board. HDled+, HdLed-, PwrSw, PwrLed, or something similar.
If you do find them but the hard drive Led does'nt come on it's because the plug for it needs to be turned around the opposite way, Led's only work one way as they are diodes. Same for the Power Led.
If there are no letters near the pins then you would have to find the motherboard manual.
Jan 28, 2012 | E-Machines eMachines Desktop PC
I replaced pl ugs and wires on 2003 taurus w/3.0 dohc and it shows misfire on number two cylinder.Any suggestions?
If this vehicle has coil on plug ignition, then the coil is faulty and will need to be replaced.
Mar 29, 2011 | 2003 Ford Taurus
Xj 900 1985 not firing on one cylinder
try swopping over the plugs .it may be a pl;ug breaking down.And check you have fuel getting to the non firing cylinder.
Mar 31, 2010 | 1985 Yamaha XJ 900 F
Not supporting to yahoo mobile & not able to send photo
visit http://www.getjar.com and download the supported version for your handset.
May 14, 2009 | Motorola Mobility L6 Cellular Phone
Visual Land V-Touch  Digital Media Player Logo
Top Visual Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Ed Mac
Are you a Visual Audio Player and Recorder Expert? Answer questions, earn points and help others
