Question about Toro Garden
How to put back on drive belt on lx427 toro tractor
  • 41 Answers
SOURCE: yard man mtd 20hp 46
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Posted on Jul 12, 2009
  • 203 Answers
SOURCE: How do I get instructions on replacing both upper
You can go to Toro.com and look at the lower left side for "Homeowner" or "commercial" parts. If you enter your model number you can get an owners manual online. I tried your LX425, but didn't come up. Maybe a different number?
Posted on Oct 25, 2009
  • 61 Answers
SOURCE: adjust the drive belts,
if you have the belt installed correctly, the idler pully is the only adjustment and thats automatic. i trust you have installed the correct belt.
Posted on Apr 29, 2010
SOURCE: Does anyone have a diagram
Hello LMR,
Please visit the link provided below ;
http://www.ehow.com/how_6419031_change-lawn-mower-drive-belt.html
http://www.partstree.com/parts/?lc=toro_consumer&mn=72083%2C+266-H+Yard+Tractor%2C+1994+%28SN+4900001-4999999%29
Posted on Apr 30, 2011
  • 147 Answers
SOURCE: looking for a diagram of
this link will help you http://www.manualsonline.com/https://www.shoptoro.com/Comergent/en/US/adirect/Toro?cmd=ToroOnlineModelLookup
Posted on May 13, 2011
I have a 1990 toro wheel horse classic 312 8 lawn tractor, it has a 42 inch side discharge deck, What's the deck drive belt size of this mower, model 31-12K801, I have searched for hours
If the belt is in one piece, put a chalk mark on the back of the belt and measure the length by running a tape measure from one side of the mark all the way around the belt until the mark appears. Take that measurement, subtract an inch for stretch and that number is the number of the belt you need. If it's broken in two, not three, then simply measure the length of the belt.
May 28, 2016 | Garden
How do I replace a drive belt on a toro ride on mower model CV18S
+check with dealer, the service manager may help cheers.
Jan 12, 2015 | Toro Garden
How to fix LX427 toe-in back to factory alignment.
Your owner's manual tells you how. If you don't have one go to and get free manual www.managemylife.com
Feb 25, 2012 | Toro Garden
I HAVA A TORO WHEEL HORSE MODEL 71223, I PUT A NEW
The problem sounds like the tranny if the belt is correct.Thanks for asking and I hope it helps.
Jul 18, 2010 | Toro Garden
I have a Toro LX466 riding mower. The drive belt
How to replace the drive belt on a Toro LX466 Lawn Tractor
1. Jack up the front of the mower-place a couple of blocks under the front wheels (retaining wall blocks from your flower bed work great). Block the back wheels so the mower won't roll off the front blocks.
  1. Remove the battery and battery compartment from under the seat. You can now see the cooling fan blade under the seat. The belt runs from the pulley directly under the fan to the front of the tractor.
  2. Lower the mower deck to its lowest position. Remove the deck hanger rod from the slots in the front of the mower deck.
  3. Remove the metal rod guard below the engine pulley. It's held in place on one side with a bolt, and the other side with a cotter pin.
  4. Take a large pair of channel lock pliers (about 18 in long work great) and clamp them down directly on the engine pulley, but not so tightly you distort the pulley.
  5. Remove the bolt from the pulley. It's a right-handed bolt, so turn it counter-clockwise to remove.
  6. Slide the pulley down the shaft until you can work the belt off. If the belt is too tight, then remove the spring from the idler pulley under the tractor. It's hooked on a bolt near the side of the tractor. You can remove it by grabbing the end of the spring with a pair of needle-nose vise-grips and slipping the end off the bolt. Then remove the old belt from the tractor.
  7. Take a new belt (preferably Kevlar) and start at the back of the tractor (with the pulley under the cooling fan) and thread it through to the front of the tractor. The flat side of the belt rests against the idler pulley with the flat sides.
  8. Work the belt over the engine pulley and slide it back on the shaft. Tighten the bolt on the engine pulley hand tight. Then check the belt to make sure it hasn't slipped out of the groove on the cooling fan pulley.
  9. Clamp the engine pulley with the channel lock pliers and tighten the bolt.
  10. Make sure the belt is routed correctly on the idler pulleys. If you had to remove the spring on the idler pulley, replace it. You can do this by grabbing it with the needle-nose vise-grips and placing it on the bolt-make sure it's above the washer. Then remove the vise-grips and gently pry it over with a small screwdriver until it slips into place.
  11. Replace the metal guard below the engine pulley. Hook the mower deck back onto the deck hanger. Replace the battery compartment and battery. Unblock the mower.
Jun 15, 2010 | Toro LX466 22HP Lawn Tractor 13RT61RH244
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Mower drive slips , not belt clutch, assembly. any adjustment? or anyway to fix it?
I hate to tell you this,but not much you can do. I had a toro wheel horse 12.5 hp the drive belt would slip,made it a little better by putting on new belt w/belt dressing,but would still do it especially under load or up hill,or starting in higher gear. Unfortanately,it was one of toros downfalls on a lot of models,and FYI if you think altering the tension pulley to hold the belt back more will solve it,your wrong,all that will do is make you lose use of your clutch.
Aug 08, 2009 | Garden
Garden Logo
183 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
