Question about Kwikset 985 15 SMT CP Double Cylinder Deadbolt Featuring SmartKey
Cylinder removal instructions for model # 553MNH LIP 15 SMT
How do I reassemble kwikset lock set LIP 5 SMT?
Contact:
Consumer Services
19701 Da Vinci
Lake Forest, CA 92610
1-800-327-LOCK
It's difficult to know without seeing it in person or with good pictures.
Aug 03, 2014 | Kwikset Locks & Locksmithing
How to tighten kwikset #991LL
Remove inside lever by loosening the setscrew and pulling. Carefully pry off the inside cover. Make sure both screws are tight. Replace inside lever. With door unlocked, the outside lever can be removed in the same way as the inside. All that is necessary though is to be sure the setscrew on the outer lever is tight. Check to be sure the lock is tight and operating correctly before closing the door and locking it.
The deadbolt inside turnbutton is held on with a small setscrew. Remove it and the inside cover. Be sure the screws under the cover are tight. Check the lock operation, replace cover and turnbutton.
Jul 07, 2014 | Kwikset 991ll 15 Smt Cp Lido Entry Lever...
How do you remove cylinder guide hitachi nv45ab2 roofing coil nailer
Cylinder guide fits very snuggly into cylinder and generally does not need to be removed unless visually broken. If you have a leak and suspect the orings under the guide, re-post a question. If however you want to pull anyway, I use one arm of a large two arm puller. Remove the outer ring, pull out the cylinder, then gently tap the under side of the guide with the lip of the single arm. Move the arm from one side to the other and it will come right out. Second method is to remove lower half of the gun and push out with rod or hardwood dowel. I have remove many by tapping up with lip of puller and have not damaged any. This part is quite strong, however have not ever needed to replace the orings under this part. Good luck
Nov 24, 2012 | Hitachi NV45AB2 Roofing Coil Nailer
When I enter the code the lock opens but the unit flashes ten times...is this ok?
To find your answer you can visit and download a manual @ http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HieMAAS.aspx. . :) Best of luck!
Sep 12, 2012 | Kwikset 909cnt 15 SMT CP SmartCode Single...
I Have a new Kwikset 909 LO3 SMT CP unit - How do I change door handedness?
In section 8 of your instructions is the "Door handing" programming instructions
Link here: http://s7d5.scene7.com/is/content/BDHHI/Website%20Content/Kwikset/Resources/KwiksetSmartCodeManual.pdf
You need to carefully go through this programming routine without interruption. That should fix it for you. Good luck!
Jul 05, 2012 | Kwikset 907 L03 Smt Cp Powerbolt
Help - I am trying to reset the code on my 909 15 SMT. No luck.
Here's the installation instruction link for your lock:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Jul 01, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
How do you reset password for SMT-190? It doesn't accept the default (4321).
Try this .
Cut the SMT-190Dx off using the switch. Let it stay off a few seconds and turn on again. In doing so, the unit's password will resort back to it's default both login and password. Then you can go back in and reset it to whatever you like.
There doesnt seem to be a code for this model. but follow this instruction hopefully it will help.
Nov 13, 2009 | Samsung SMT-190 19" Flat Panel TFT LCD...
How to remove the lower panel, GAS AMANA DRYER, model LEA 30 AW
generic instructions.... remove screws through lower panel bottom lip, panel lifts straight up and out.
........................or.....................
Use a putty knife to release the front clips (one near each front corner) and pop
the top to view belt.
Need model # for exact instructions
Feb 10, 2009 | Amana ALG331RAW Gas Dryer
MR2 after 2 mins of starting the smt light comes on.
it sounds like the clutch actuator is worn out.
The clutch actuator has 2 parts:
1. the clutch master cylinder
2. the clutch slave cylinder.
Try to replace the slave cylinder first, and if it is still not solving the problem, then try to replace the clutch master cylinder
Good Luck
Feb 06, 2009 | 2003 Toyota MR2 Spyder
Kwikset 985 15 SMT CP Double Cylinder Deadbolt Featuring SmartKey Logo
43 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
