Question about HP Officejet 4110 All-In-One InkJet Printer
Error 0xf0af8002 cycle power
The printer works for about 1.5 pages and then the light starts flickering red, with the message "Error 0xf0af8002 Cycle power". The light stops flickering red once the power button is pressed and reboots. I have tried the OK+CANCEL power plugged in reboot, but has not helped. Please advice.
hashir4u
  • 79 Answers
SOURCE: Cycle Power
instead of # and 6 try
unplug the power cable, press and hold :
OK and CANCEL, while keeping them on hold put the power cable back in ... it ll do a full NVRAM reset on it ..
It ll be fixed .
Best of luck
Posted on May 27, 2008
SOURCE: align cartridges error
This means one of the cartridges is defective, they cant align if they cant print.  What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center.  When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in.  I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black.
Basically you align the cartridges and then swap them so the printer thinks they are still aligned.
The color still doesnt work and it is probably a defective color cartridge.
Posted on Sep 13, 2008
  • 3 Answers
SOURCE: HP 4700
Try this
Remove all EIO devices and memory Dimm's execpt the firmware dimm.
Start the printer. If the error is gone then place the dimm's / EIO devices one by one.
(Don't forget to switch off the printer.)
If the error is still there then you might have a faulty firmware dimm.
Posted on Dec 29, 2008
SOURCE: printer will not start
This is likely a hardware problem. However you can try a sem-full reset to factory default conditions by 1. unplugging the power cord while the printer is powered on and 2. press and hold the OK and Cancel buttons while plugging in the power cord. If this this does not clear the error you probably have a hardware issue. On my printer, after going through a diagnostic procedure with the HP Chat Tech and concluding a hardware issue I did a bit more research and then took the printer apart. It turns out that a fairly common problem is for the large white gear on the left side of the printer that drives the ink pump comes off the shaft. I reassembled it to the shaft and put the printer back together. When I plugged in the power cord the printer started and did about a 5 minute maintenance procedure and now works fine.
Posted on Jan 29, 2009
SOURCE: Ink system Failure Error Oxc18a0001
Hold the number 9 key and the key down at the same time, then pull the power cord. Then put the power cord back in while holding the 9 and # key. You will lose your settings, but the ink system failure message should go away.
Posted on Mar 11, 2009
How to get printing threw pos system
Sir/Madam
PRINTER ERROR CYCLE POWER
Control Panel Message
61.x PRINTER ERROR CYCLE POWER
Event Log Error
Service Message 61.0x.00
The printer encountered a parity error when accessing either internal memory (x = 0) or SIMM memory (x = 1-4).
Required Action
  1. Cycle power.
  2. If the message persists: Verify that the SIMM module is installed correctly.
  3. Turn off the printer, remove the SIMM module, and then turn on the printer.
  4. If the message does not display, replace the defective SIMM.
  5. If the message continues, turn off the printer and remove the next SIMM module, then turn on the printer.
  6. Repeat this step for the remaining SIMM modules until the problem is isolated.
  7. If the message continues without any SIMMs installed, replace the Formatter PCA.
If you Still Having Hp Printer Problem Then Visit official HP Printer website Below Link URL:
http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?sp4ts.oid=25474&spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-bpl70117-1%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken#N10C53
Or
If You Still Facing Problem Then Follow Us For HP Printer Online Help On: HP Printer Support
Feb 12, 2014 | HP (EY023AA) Thermal Printer
DIMM Error HP P3005n
Are you usingoriginal HP Dimm chip?, does machine turn on and come to ready when it is standing on it own (not hooked to p.c.) if not can you tell me exact light patten displayed
Dec 13, 2007 | HP LaserJet P3005n Printer
How do I fix a paper jam in a Brother MFC-7860dw printer?
Try resetting the printer.
~Menu
~4. Printer
~4. Reset Printer
Jul 02, 2012 | Brother MFC7860DW AllInOne Laser Printer
Lexmark x544 108.02 printhead error
1. Power off the printer/MFP, wait 30 seconds, and then power it on again. Did the error message return?
Yes: Continue to Step 2.No: Print a test page. If the page prints, the printer is working correctly.
If possible, connect the printer/MFP's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.Did the error message return?
Yes: Contact Lexmark @ 1-800-(539-6275) No: Print a test page. If the page prints, the printer is functioning correctly.
Aug 16, 2011 | Lexmark X544n All-In-One Laser Printer
HP Color LaserJet 8550N control panel message "Out of memory job cleared." How do I free up, or clear the memory?
Power cycle the printer and reprint the job.
If error occurs again, install more memory in the printer.
Is it just one job that causes the error or is it everything that you print
How much memory is in your printer?
If you don't know, print a config page.
Feb 17, 2011 | HP Color LaserJet 8550n Printer
Error message "service error 5200"
Hi Good day!!!
follow this hope it helps you
1 unplug the power n usb cord
2 keep the headprint inside the craddle
3 try to move the headprint into full right-corner(headprint
cleaningside)by moving-left the craddle belt until u heard
some "snapp" sound
4 plug the powercord again5 if u heard "cleaning progress" then u r printer going to respond
5 try to print 'printer test page' or 'nozzle check'
6 if it succeed, try to print some 5-10 pages continously
Thank you for using FixYa
Nov 23, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Solid orange light and blinking green lights
To check the light Pattern of your printer
Click on Light and Error HP Laser jet 1012 Printer
Check the error details from the above link
Condition of the printer Action/Description Ready
The printer is ready to print. No action is necessary. Processing
The printer is receiving or processing data. Wait for the job to print. Processing...(job name) Ready LED is blinking.
This message is displayed while the printer is processing a current job, but has not begun to pick pages. Processing...(job name) From Tray XX Ready LED is blinking.
This message comes up for any job, once the printer starts to pick paper. Manual Feed or Continuable Error
The printer is attempting to Manual feed, media is not loaded in the paper tray, media loaded is the wrong size or type. Verify that the correct media is loaded.
Press and release the GO button to continue printing. Out of memory
The printer is out of memory. The page you are printing might be too complex for the printers memory capacity. Try lowering the resolution. See Understanding print quality settings for more information. Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Printer initialization
A printer initialization is taking place. No action is necessary. Fatal error
All lights are on.
  • Unplug the printer for 30 minutes, and then plug it back in.
  • If the printer still has an error, contact HP Support.
All lights are off.
  • Verify that the printer is turned on.
  • Make sure that there is power.
  • Unplug both ends of the power cord, and plug them back in.
Job Cancel
All the LEDs cycle. Canceling...(job name)
The Job Cancel button was pressed and the job is aborted. Power ON
All the LEDs cycle. Checking Paper Path and Checking Printer
This only occurs at power up. Cleaning mode/Engine test
A cleaning page or engine test page is printing.
All the LEDs cycle. Cleaning Page prints
Wait until the cleaning page is finished printing and the printer is in Ready mode. This could take up to two minutes.
Wait until the engine test page is finished printing and the printer is in Ready mode. Clearing Event Log
All the LEDs cycle.
This will happen automatically during an NVRAM Init and a cold reset. No message will be displayed. No Action is Necessary. Power On
Initializing
This occurs when the product is powered on and coming out of EDOS. No Action is Necessary.
Jan 03, 2010 | HP LaserJet 1012 Printer
Laser Error Error message 061-370 for Xerox Phaser 6125
From the service manual:
Troubleshooting Procedure Table
Step Actions and Questions Yes No
1 Check the Laser Unit for correct
installation.
Is the Laser Unit correctly installed?
Go to step 3. Reinstall the
Laser Unit. Go
to step 2.
2 Cycle the power.
Does the error still occur?
Go to step 3. Complete.
3 Check the wiring harness connectors
P/J40, P/J41, P/J411, and P/J412
between the MCU Board and the Laser
Unit.
Are the connectors securely
connected?
Go to step 5 Reconnect the
connectors. Go
to step 4.
4 Cycle the power.
Go to step 5. Complete.
5 Replace the Laser Unit (page 8-31).
Replace the
MCU Board
(page 8-59).
Complete.
Jan 31, 2009 | Xerox Phaser 6125 Laser Printer
The led screen shows genera error
you need to reset your printer try doing this
  • Press and hold “Stop”, “Maintenance”, and “Power” buttons for about 10 seconds. A message will come on the screen saying counter is reset and to turn the printer off. The R200 and others don’t have a screen so just wait until the 10 seconds is up.
  • Turn the printer off, unplug the power cord. Wait about 1 minute and power the printer back up. The counter will be reset. That’s all there is to the reset procedure.
Nov 24, 2008 | Epson Stylus Photo R300 InkJet Printer
Printer trouble
Power cycle the printer. If problem remains, try a partial reset. You can do the partial reset as follows:
1. Unplug and replug the unit.
2. when lights flash on power up, hold down the ON/RESUME and PAGE SIZE buttons together.
3. When only the ON/RESUME button light flashes, you can release the buttons.
4. When the lights stop flashing, the reset is all done!
If problem remains, you are fully justified to ask HP to replace the unit for you (well, if you're still in warranty!). Good luck :)
Jan 18, 2008 | Office Equipment & Supplies
HP Officejet 4110 All-In-One InkJet Printer Logo
77 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
