Question about Kitchen Appliances - Others
GE Profile washing machine--- spinning does not stop.
Last spin cycle does not stop. and not draining water.
    Master:
  • 545 Answers
Sounds like the water pump may be faulty. That would keep it from pumping the water out, which might keep it spinning in an attempt to empty the drum of water.
Water pumps are generally accessible from the rear, via an access panel. Check it for debris or a worn bearing. It should be obvious.
Posted on Nov 10, 2012
2 Suggested Answers
  • 21 Answers
SOURCE: The motor does not spin
This machine should still be under warranty, contact the store where you bought it to find out how to get it either replaced or fixed. Any attempts to fix this by anyone other than a certified repair person will void your warranty. Hope this helps you. Good luck!
Carol.
Posted on Apr 15, 2009
My Ge Eterna washer will not drain the water but will spin on spin cycle
You got no clear question here. Does the spin cycle pumping out water or not. If it is spinning but water was not pumping out so the issue is from the pump. It is either blogged or out of order.
Oct 15, 2013 | GE Profile WPRE6100G Top Load Washer
Our ge washer will not drain water out before it goes to spin cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 23, 2011 | GE Profile WPSR3120WWW
GE top load Profile washer. Spin cycle not
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Ge WASE4220A0ww will not drain or spin
hI!!! You seem to have a bad transmission or a bad motor they are all expensive to repair..Good luck..
Jan 03, 2009 | GE Profile WPRE6100G Top Load Washer
Ge washer # WBVH6240FWW
We have a GE washing machine that works fine with no load, but will not finish the cycle with a full load.
Aug 15, 2008 | GE Profile Prodigy WPSE4200A
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
