Question about Digimerge Home Security
Digimerge dvr stuck at 99%
Recirded up to 99% and won't rerecord
There should be a settings in recording.. its either something like Linear or circular.. select circular and it will record over the earliest footage on a continuous loop.
Posted on Nov 09, 2012
It tells me I cannot access the dvr at the shop to get live view. How do I fix this problem?
Check the connection from the DVR to the router. You may need to reset the router.
Oct 14, 2014 | Home Security
How do i reset password for h264 dvr
Hello, There are two things you can try, the default password for the system should be 000000. If that is not the password if you go into the System Menu under the "General" tab there will be an option that says Factory Defaults, this will reset the settings to the default and should remove any password that is in place, but be warned that this will possibly wipe the dvr.
May 08, 2014 | Digimerge H264 16 CHANNEL DVR WITH USB CMS...
My digimerge d300 dvr wont boot up how to get to finish booting ip
You might have a hardware problem, as I think those things just do POST, and then boot up.
Do you have anything plugged on it while testing ?
Mar 16, 2014 | Computers & Internet
Swan dvr wont record
It sounds like a problem that might be an easy fix. Since the system CCA board doesn't see the HDD. Can you view any previously recorded images? How are the connections to the drive? Bad IDE ribbon cable (yes do do fault), power to the HDD and how about the drive? Some of my DVRs require the manufacturer drive, not a simple off the shelf (i.e. Lanex or Verint).
Try that and reply back. :)
May 22, 2013 | Home Security
Need help please. I have a Digimerge DH200 DVR with one camera. I've set is up and can view my camera locally over the internet and on the CMS DH software. Now I need to view it remotely. I have a
I have the ame problem. also need help with email setup. digimerge will not help. horrible co. they say I have to pay a tech to come out. no support whatsoever.
Oct 12, 2012 | Computers & Internet
I NEED AN INSTRUCTION MANUAL FOR THIS PRODUCT.
The installer manual and the operator manual for the D204161 are both available here: http://www.digimerge.com/Security-DVR-D204161/ . Click on the Download tab. The direct link for the operator manual is: http://www.digimerge.com/images/file/76/Operators%20Manual%20for%20the%20D204%20Series.pdf .
I hope this helps.
Mar 29, 2011 | Digimerge 4 CH TRIPLEX/NETOWRK 160GB HDD...
How do i store an event ? LOST THE MANUAL
Strangely enough, its right here on Fixya!
http://www.fixya.com/support/p910122-digimerge_dhu516252r_16_ch_5plex_networ/manual-36440
Feb 01, 2010 | Digimerge 8-CH DVR 5PLEX W/DVDRW 500GB...
I am attempting to repair a Digimerge VCE 308301 (the 8 channel network DVR system) The client is able to view the setup menu but unable to to get an output signal from the cameras. The system runs it is...
The problem did not have anything to do with the DVR (Digimerge VCE 308301). It did however, have everything to do with the cameras' power supply system.
First, I contacted the company's (Digimerge) tech department; and they were of no help since the DVR system is obsolete. There are no replacement/spare parts available; e.g. mainboard and daughter boards...and of course, they don't have schematic diagrams for the DVR either. And due to its obsolesence- there is no tech support. (It makes me wonder why, though, how security and electronic vendors can in good conscious sell this obsolete model DVR for $1,400 and upwards of $2,200.00 to the unsuspecting consumer/end-user.)
Since I was able to boot up the DVR system and access the BIOS menu; and considering that the screen was showing that it was in record mode- and the system BIOS was keeping the proper date and time, I believed that there was something else going on with the security system.
I contacted the customer and went out to their home- as I was about to hook up the cameras to each input behind the DVR- by happenstance, I checked the power supply panel to make sure that the power supply had been turned off (which the home owner failed to do). Having turned off the cameras' power supply, I then made all my camera hook-ups to the DVR. When I turned the power supply to the camera system on, I was able to get a video signal, hence a nice clear picture. I did check the voltage draw on each power terminal at about 12.5 vdc and a visual check on the infra- red led's on each of the security cameras were lit.
Problem solved, right!?...WRONG!
Several hours later, I received a call from the homeowner that his security system was not working again. The first thing I noticed as I pulled into the customer's driveway was that all the cameras' infra-red led's were out. I immediately placed my volt meter on the output side of the transformer at each of the cameras' power terminal- and waddya' know- I was barely reading over 1 vdc. Apparently- over time, the transformer starts to overheat and the voltage drops out. After it cools down though, the voltage resumes to 12.5vdc to power up the cameras.
This is my first experience working on a secuirty camera system so I hope this has been as much of a learning experience for you novices as it has been for me!
Oct 01, 2009 | Home Security
Home Security Logo
114 people viewed this question
Top Digimerge Home Security Experts
Are you a Digimerge Home Security Expert? Answer questions, earn points and help others
