Question about Coffee Makers & Espresso Machines
What liquid affected teeth the most - Coffee Makers & Espresso Machines
    Master:
  • 545 Answers
Hydrofluric Acid affects teeth by completely dissolving them.
Posted on Nov 10, 2012
01 vw jetta tdi 1.9l 4 cyl diesel manual trans. 1st problem car is really hard to start and once started will die as soon as peddle is released. 2nd problem I am now on the 5th starter. The...
indicates a problem with the ring gear teeth
the only thing that will damage the nose of starter motors is bad teeth of a ring gear that affects the proper engagement such as badly burred teeth or metal stuck in the teeth at which point the pinion is pushed violently sideways resulting in a broken housing
next problem indicates that the injectors need reconditioning and the fuel control module needs checking/replacing
There should be a fault code for the not continuing to run probel
Apr 22, 2018 | Cars & Trucks
Can i cut metal with this saw
Please share the make and model of the saw, however, the cutting of metal depends largely on the kind of blade.
Metal cutting blades have both a different "set" of teeth and number of teeth per square inch.
You will also be getting different teeth for different kinds of, and thickness of, metals.
By and large, the thinner the metal, the more teeth per inch.
Your motor speed will also affect how well your machine will cut metal.
God bless your efforts.
Jan 25, 2016 | Saws
Abs light comes on while driving found oil inside teethed rotor case is it the problem?
as the teeth are a small magnet it probably is not the cause
if the air gap is too big or too small , that will affect the signal
run the fault codes as it may be faulty wiring or sensor
May 29, 2015 | Vehicle Parts & Accessories
Plastic stuck in my Fellowes shredder blades!
Sorry, but no. There isn't really a way, unless you are very technically minded, to take the teeth apart and clean them. You might try, using a paperclip, I find that I have to do that on occasion to clear out the pieces that get caught in between the teeth.
or maybe, just a thought,?... You can use a product called goof off, it does come in a aerosol can as well, in addition to small bottles of the product in liquid form. Good luck.
Mar 31, 2015 | Fellowes Powershred PS-65C Shredder
Could a nonessential corrective dentistry herts specialist change the length of my teeth?
The orthodontist might propose a blending of corrective dentistry herts and lacquers or crown stretching. Encountered orthodontists work with a system of different experts who can cooperate to attain the effects you need.
Dec 03, 2013 | Computers & Internet
How many teeth blade can i put on a circular saw
You can put any blade in your saw as long as the diameter of the blade isn't bigger than your saw is made for and the hole in the blade fits the arbor properly. The number of teeth only affects the speed of cut and how smooth the cut is. Fewer teeth cut faster but leave a rougher cut edge. More teeth cut slower but leave a cleaner cut surface and edge.
Jun 14, 2012 | Saws
Seems like motor has lost power
This sounds like the black rubber coupler has broken. The teeth often get knocked off. Have a look at the part shown in hte pictures here:
http://kitchenaidblenders.co.uk/Home/tabid/36/p/Two-%282%29-KitchenAid-Blender-Coupler-%2b-WS-Fitting-Tool-9704230_2plusWS/ProductID/175/Default.aspx
Jan 22, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Agitator halves are not in sync
yes it is replce them usually 4 and you'll be as good as new
Apr 03, 2009 | Whirlpool Washing Machines
Magnavox TV Model FP4640
The picture tubes in these models (red, green and blue) use a liquid coolant to keep them cool. In this set usually the blue and green fluid will become contaminated which has a major impact on picture clarity and brightness. If you take the screen off and look directly into the lenses you will see directly how bad the fluid looks. The Red usually is not affected by this problem.
The buzzing could be a noisy coil or possibly a high voltage leak. There may also be some leaking fluid involved in this as I have seen fluid gather around the high voltage cup (underside of the tubes) and cause the high voltage to arc a bit causing noise as well.
This repair is not for the faint of heart as it involves removing the affected tubes, disassembling, draining, sanitizing, reassembling, refilling, reinstalling and realigning them. The glycol based fluid is messy and it's easy to get into big problems if there are any leaks, as the leaks will usually end up on the main pc board. Our shop charges about $350 for this repair.
Dec 20, 2007 | Televison & Video
Coffee Makers & Espresso Machines Logo
16 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
