Question about LG LS-L1210CL Mini Split Air Conditioner
Hi my split airconditioner is leaking water inside the house
    Problem Solver:
  • 8 Answers
YOU DRAIN IS STOPPED UP, FIND WHERE YOUR WATER DRAINS OUT AND CHECK THE END AND SEE IF IT IS BLOCKED OR YOUR DRAINED IS STOPPED UP INSIDE WHERE THE COIL IS.
Posted on Jan 06, 2009
Why does my split ac unit leak inside the house?
This happens when the drain pipe is too high, or kinked. The pipe must be lower then the drain pan in order for the water to drain. This is a common problem.
Jul 27, 2014 | Sanyo Heating & Cooling
I have a LG plasma gold airconditioner. water leaks from the inside panel. can I fix it myself?
remove the front cover some wire inside the drain line
replace the cover and clean the filter.
Jul 08, 2014 | LG LS-L1210CL Mini Split Air Conditioner
Water dripping from airconditioner inside the house
Water leak is the common issue in split a/cs. Due to coil,air filter, drain pan dust blocked, less rpm of blower motor, short of gas.
If service for the unit is more than 4 months, please do it first. And then check rpm of blower motor, if less replace capacitor.
Check gas pressure. Must be 60 PSI @ 98*F, of ambient temp. If less than that find leak and arrest and do gas charging. Thanks.
Jan 28, 2011 | Fujitsu 24C1 Air Conditioner
Hi, i have kelvinator split system in my house.but...
Sounds like a clogged drain pan. You will need to have the unit professionally cleaned.
Hope this helps I take the time to answer your question so please rate me
May 19, 2010 | GE Zoneline AZ38H12DAD Split System Air...
My weathermaster airconditioner is leaking water inside the house
either your unit is tiped inside too much or it may need to be cleaned. you need to remove it and take the shell off and spray it down with a hose to make sure the drain hole is clean. good luck!
ERIC
Jan 26, 2010 | Carrier Heating & Cooling
Our carrier reverse cycle airconditioner is leaking inside the house after a hour of use. how can we fix this? we have cleaned the filters in the inside unit and it still leaks,it works fine as a heater...
Did you blow out the drain? If so pull the front off of the air handler unit. Ckean out drain pan. This drain pan had small holes on either side that run from the sode drain clean those out. Also if your coil is dirty it will pull water back and cause it to leak. Try cleaning coil and dain pan plus blow out drain. Rus
Dec 13, 2009 | Air Purifiers
I have an airconditioner a Kelvinator KSR20C Split system
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
Nov 16, 2009 | GE Zoneline AZ38H12DAD Split System Air...
My airconditioner is leaking inside the van. last
YOUR AC CONDENSTAION DRAIN IS PLUGGED, CLEAR IT. THE DRAIN IS ON THE PASWSENGER SIDE UNDER THE CAR BOTTOM OF FIREWALL.
Aug 09, 2009 | 2003 Chevrolet Venture Passanger
Water leaking into the house - model AOT24RWGL
Either the drain line is clogged, or there is a hole in the pan.
Get a powerfull wet/dry shop vacume.
Attatch it to the end of the drain pipe and seal it tight and pull out any dirt, mold crud blockages.
Take the panel off so you can access the drain pan under the evap coil. Clean that out as well with the vac.
Once its nice and clean, poor a gallon or so of water into the pan bein g carefull to not pour to fast.
Make sure that the line is drainign well and look for any spots where there may be a crack, hole etc in the drain pan where water may leak out
Jan 01, 2009 | Fujitsu 24R1 Air Conditioner
LG LS-L1210CL Mini Split Air Conditioner Logo
307 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
