Question about Bose Companion III Computer Speakers
How to prevent Bose Companion III speakers from turning off when computer sleeps?
I want to receive Skype calls overnight, but my Bose speakers go into sleep mode when the computer does. But they don't wake up unless I manually hit a key on keyboard.
  • moon man
    moon man Mar 12, 2014
    This might help, had the same problem with the companion 5http://meyoubrains.blogspot.com/2014/03/...
    New Friend:
I had the same problem with the bose companion 5 try this
Evenly Broken Rules Bose Companion 5 sleep mode standby issue SOLVED
with the bose companion 20 if you hold the touch pad on the control pod for 6 seconds you will hear two beeps that turn off the mute feature. this might be the same with the bose companion 3
Posted on Mar 12, 2014
SOURCE: bose companion speaker stopped working!?
What happened to you is probably mere coincidence with your cousin's use of the headphones and this is throwing you off. I own the Bose Companions also and they stopped working as well. However, I traced the problem to the "wall wart" power supply. Not sure why but Bose is now using an interchangable plug on them. If you look at the power supply you will see a "PUSH" button. If you depress it the plug can slide out. When it is slid back in and locked in place the connection between the plug plate and the power supply is not a good one. Try fiddling with it. But even if the connection is not the culprit, something in the power supply is. I swapped another power supply with the same connector and spec's ( amps must be the same ) from another item and the speakers worked perfectly.
Posted on Dec 14, 2008
SOURCE: Bose COMPANION 2 Speaker case disassembly?
yes..the only solution is to pop the front panel with screwdriver...to do this more efficiently (without breaking the front panel) ...first insert the thin screwdriver in the gap in front lanel on side wall...and rotate the screw driver 90 degree..this will pop that side....repeat it on other sides too...i did it last night only.....
my problem was that when i dropped the speaker....its magnet fell down...and its no longer working...i am trying to find another broken bose speaker to replace mine...from e bay,,but no luck till now :(
Posted on Jan 26, 2009
SOURCE: Bose Companion II Computer Speaker: The AC power adapter burnt
My puppy chewed through the cord for my a/c adapter, I just took the speakers into Circuit City, and they found me a workable replacement (the replacement isn't BOSE, but it works just fine).  Hope that helps!
Posted on May 07, 2009
DosHog
  • 168 Answers
SOURCE: Bose desktop speakers stopped working suddenly
Make sure that the power is plugged into both the wall or strip and the back of the speaker.
Posted on Jul 17, 2009
  • 71 Answers
SOURCE: Samsung TV and Bose Campanion 3 speakers
Are these PC speakers? OF so you need a stereo RCA to min-jack cable, assuming the TV has a set of RCA audio outputs.
Posted on Jul 26, 2009
My Bose Companion III Computer Speakers have stopped working.All connections are fine but no sound is produced
This may sound obvious and you might have checked this already, but check all of your mute keys. If the speaker's volume control is down, that's one. If there's one on your keyboard you could accidentally hit, that's one. If the sound properties on your computer insist sound is coming out, try a different set of speakers, or try the speakers on a different device like an iPod. Get back to us if you still have problems. Hope this helps =]
Mar 03, 2011 | Bose Companion III Computer Speakers
My Bose Companion 3 coputer speakers are 2 years
i hav the same problem but all three shut off ,and i have to shut off and turn on again
Jul 29, 2010 | Bose Companion 3 Computer Speakers
Does the Bose companion 3 have an internal fuse?
Yes. The companion 3 system can be repaired for $75. Call Bose at 800-367-4008. They will also give you a new 1 year warranty.
Jun 19, 2009 | Bose Companion 5 Multimedia Speaker System...
Used CCCleaner and deleted my Bose Compainon 3 Drivers, NO AUDIO
From what i read you want to get drivers for your computer. What kind of computer do you have and what is your operating system?
Jan 14, 2009 | Bose Companion III Computer Speakers
Bose Companion 3 series II speakers aren't producing sound (imac)
from what I've read, the imac has a 3.5mm (.138) jack while the Bose jack is 1/8 (.125). very small difference in size (.013), but enough to cause problems.
Dec 26, 2008 | Bose Companion III Computer Speakers
Bose Companion 3 Series II not working (Mac)
The speakers seem to be muted by default - you'll see that the LED is yellow/amber. Tap the control pod - the LED will turn green and speakers will work. I felt like such an idiot after I spent almost an hour trying to figure this out. (This feature should be more prominent in the manual.)
Dec 20, 2008 | Bose Companion III Computer Speakers
I have the same problem but I can't figure out how to fix it
Mar 26, 2008 | Bose Companion III Computer Speakers
Left speaker sometines has no sound? Please help
I bought a set of Bose companion 3 speakers and the darn RCA jacks are cheap and wiggling loose. The cost to send back and repair out of warranty is about $125!! BOSE companion speakers may sound good, but for my money, I'd rather go with more reliable computer speaker systems like Creative or Logitech. BOSE IS WAY TO OVER-RATED, but HEY....they suckered ME out of $275!!!
Feb 06, 2008 | Bose Companion III Computer Speakers
Bose Companion  III Computer Speakers Logo
2,327 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
