I am Unable to connect my Aduio cables from the xbox 360 to my TV
I am Having troubles connecting my Xbox 360 to My Technika 22@ HD Digital LCD TV/DVD (Model LCD22-208). The Audio cables don't seem to have anywhere to connect. no sound from x box360 when connected to my technika lcd19-408 help
  • Anonymous Mar 12, 2014
    technika 22" lcd tv with dvd and ipod dock screen comes on then 3seconds later goes off
    power supply is good
I had the same problem and i bought a HDMI lead for about £12 this solved the issue
Posted on Jan 12, 2009
Have XBox 360 Elite and Voyetra Turtle Beach X11 Headset. Got new 3D HD TV and when I attached the HDMI cable to the XBox the headset stopped working. I have been told it is because the cable has an...
I myself have a 46" RCA LCD flat screen tv, which I have my xbox 360 connected via HDMI cable. If your tv has audio out "rca plugs", which im sure being a newer 3d HD tv, connect the supplied cable to the audio out (red, white) plugs, and then connect your headphones to that jack!
Dec 31, 2010 | Voyetra Turtle Beach Ear Force X11 Headset...
Xbox 360 working thru HDMI working fine. Now no sound & weird pic
it is prolly an internal problem. have to tried connecting the componet cables?
Mar 03, 2010 | Microsoft Xbox 360 Console
I was having trouble with my component AV cable. I went to purchase a new cable, HDAV component cable and connected the xbox. I had an image for a short time and now do not. Please help!
your HD settings may be too high, go to "display settings and change them, if your not on an HD tv, change the output to "TV" on the AV cord where it connects to your xbox, if you Are on an HD tv make sure the output is set to "HDTV" on the AV cord where it connects to your xbox, there is a little switch on the side that slides left to right
Jan 16, 2010 | Microsoft Xbox 360 Elite Console
No sound on Technika HD TV when using my Xbox using HDTV cable
i cant get soun when playin my xbox 360 on my technika tv. how do i obtain sound?
cheers
Jan 12, 2010 | Microsoft Xbox 360 Console
Which wires doi use to connect up my xbox with my
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Nov 23, 2009 | Microsoft Xbox 360 Console
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
May 31, 2009 | Microsoft Xbox 360 Pro System Console
1) Connect the red, white & yellow audio leads in to the 360 scart adapter and then plug this in to the scart socket on the tv
2) change the xbox 360 selector at the back of the console from HD to TV
2) Select the input of scart on the tv
You should now get pictures & sound.
Dec 28, 2008 | Televison & Video
New XBOX 360 no picture / sound
ok your lucky, you just need to by a new av cable.. or if that dosnt work you need to get the av caple connection fixed (only about $25)
thanks, Domo
Dec 23, 2008 | Microsoft Xbox 360 Console
I am tryin to connect my Phillips HTS3011/05 home cinema system to my Technika LCD32-207 tv. It works fine if i watch a dvd, but it doesnt work when i play my Xbox 360 through its HD cable, or watch normal...
My TV has a Output port, It is only output for sound, IF you TV has this, then you need to use those, But i dono if it would have them, If it dosent the you will not be able to use the surround for everything without Plugging it in as you use it,
Nov 25, 2008 | Televison & Video
Xbox 360 Elite compatible with 62' Mitsubishi HDTV?
I have it and it works great! For all TVs, the TV have to be on fixed settings on standard, dot-by-dot mapping, noise reduction off. The camera's exposure the same for both side-by-side shots. Just set it on standard and it should work...
Jun 05, 2007 | Microsoft Xbox 360 Console
Televison & Video Logo
491 people viewed this question
Top Televison & Video Experts
Electro Med Services...
