Question about Behringer EUROPOWER EP2500 Amplifier
How can i replace power supply ep2500 - Behringer EUROPOWER EP2500 Amplifier
3 Suggested Answers
  • 108 Answers
SOURCE: My EP2500 died, the capacitors are swollen on the
Unless you are a qualified audio service technician, you should refer repair of this unit to an authorized Behringer service depot. The capacitors you refer to can store lethal amounts of electrical charge. Also, Behringer service manuals and schematics are notoriously difficult to get.
Posted on Oct 07, 2010
petraman7
  • 1175 Answers
Find a tech that can fix tvs or guitar amps or stereos. Have them replace the swollen caps.....With no power , these amps will loose all high voltage in a day at the most.
The "Capacitor plague" has affects millions of products. Yours is one
Posted on Dec 16, 2014
My EP2500 keeps on blowing a fuse on the right channel and I opened it and realised that the two horizontal caps are a bit bigger.
They wouldn't blow the fuse. You are looking at the main devices that power the channel. If you put an ohmmeter on their terminals (assuming they are transistors) then it will show like you have touched the two test probes together. If it does replace the part(s).
Oct 24, 2013 | Behringer EUROPOWER EP2500 Amplifier
Constant hum from speakers
You will need to replace the large capacitors in the power supply it sounds like they are letting the 50hz mains hum in.
Mar 20, 2013 | Behringer EUROPOWER EP2500 Amplifier
My EP2500 died, the capacitors are swollen on the top in the power supply.
Oct 07, 2010 | Behringer EUROPOWER EP2500 Amplifier
Both fuses burnt and both clip and signal led on? seems to have full power behringer ep2500
Suspect an overload in either the power supply section or the devices on the main heat sink. In the power supply you are either looking at a transformer problem or semi-conductors associated with it. However since the clip and signal lights are on, I would go to the amp devices on the heat sink. If they are transistors test them with a Ohm Meter on the 1K setting in circuit even! You will soon notice which ones are gone! The meter will show like you had touch the test probes together!
May 15, 2010 | Behringer EUROPOWER EP2500 Amplifier
What are the Behringer EP2500's output stage transistors?
Faichild/Toshiba make the output transistors for the ep2500, part numbers 2SA1943 and the 2SC5200. Beware though there are a lot of dodgy fakes around on ebay. Profusion are excellent. Heres the links for them.
http://www.profusionplc.com/pro/gex/pcatdtl0?ipartno=2SA1943-O
http://www.profusionplc.com/pro/gex/pcatdtl0?ipartno=2SC5200-O
Nov 27, 2009 | Behringer EUROPOWER EP2500 Amplifier
Power supply problem in Behringer pmp 3000 mixer
Just try to resolder all component parts in power supply section,maybe there is a loose connection or cold solder joints that causing of abnormal voltage or missing voltage.Also check the resistor for cange value causing the voltage trap.Check also all electrolytic capacitor for leak. Hope it may help you;;
Jun 08, 2009 | Behringer EUROPOWER EP2500 Amplifier
Power supply problem in a pmp 3000 behringer miker I have + - 56 rail voltage but no 12 v ? to supply the pre amp when you turn on the unit the mixer lights up briefly then dies,this is a switch mode...
I am not familiar with the particulars of your specific model, but with switch mode supplies in gereral, look for defective filter caps on the output side or a defective Zener Diode. If you can post a few photos of the power supply section, I may be able to guide you to the likely parts. Dan
Behringer EP2500 trips immediately when turned on
Power supply section is overloading probably because of audio power amp problem.
Paul
Mar 31, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer Eurorack Pro 12 input rack mixer (Passive) Got no power supply. How do i fix them?
Hi
you mean no power? if no power check the primary fuse! i can teach how to fix that, if you are a electronic technician?
Thanks!
Sep 22, 2008 | Behringer EUROPOWER EP2500 Amplifier
Behringer 3282 mixer
any luck with the test. Let me know here Id like to know how you got on.
regards
Graeme
Feb 10, 2008 | Behringer EUROPOWER EP2500 Amplifier
Behringer EUROPOWER EP2500 Amplifier Logo
26 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
