Need schematic wiring for 240 volts
  • 7,627 Answers
Wrong catagory
Posted on Nov 09, 2012
Wiring schematic for a 1971 Reuland 3 phase # Hp. electric motor for a grinder pump
Its going to depend on whether you are connecting to 240 volt or 440 volts...
It also depends on whether it is a 'wye' wound motor or a 'delta' wound motor.
A nine wire motor is probably a multi-voltage motor capable of running on either 240 or 440 volts. For operation on low voltage, 240 v, the windings must be connected in parallel whereas hi voltage operation makes it necessary to have the windings wired in series.
I will not give the details on the winding connections because the process to determine whether it is a 'delta' or 'wye' wound motor is too involved to derscribe on a forum. But..... if it is a 'wye' wound motor, there will be three additional wire connections 10, 11, and 12, that are wired together and under the end bell and not accessible.
We don't want to 'smoke' your motor, so let the suggestion be to contact a reputable and qualified electrician who you trust to determine what's required and to connect it without the potential for damage.
Nov 24, 2014 | Air Tools & Compressors
How to install workhorse super flow pool pump
see what voltage is coming in 240 or 110 look at schematic on the side of the motor most motors are wired 240 volt if 120 volt you probably will have to change some wires to work on that voltage
Aug 10, 2014 | Pool & Spa
Do you have a schematic for a GE TC10323R?
The GE web site or the help line would be the fastest help source.
www.ge.com
Jul 30, 2014 | GE 100 Amp 240-Volt Non-Fused Emergency...
How do I wire a new cord to my speck a91 pool motor?
check to see incomming voltage 120 vs 240 then read schematic on the side of the motor some motors need to change wires for 120 volts
Jul 19, 2014 | Pool & Spa
My LG Tromm dlg5988w dryer won't heat. I am trying to reset the heat sensor but can't find it. I have removed the front cover but not sure exactly what I'm looking for.
Make sure you have 240 Volts going to the dryer. The motor runs on 120 Volts, but the element needs 240 Volts. If that checks out, you would need to trace the wiring using the wiring schematic. That could be fun.
Aug 09, 2011 | Dryers
I am installing a 240v heater in my downstairs bathroom. The heater schematic has a single BLACK 240v live input wire and a WHITE 240v neutral output wire, plus a yellow/green stripe ground wire. I have...
you dont need all that wht is 120vt blk is 120vt thats your 240 their is no neatral on 240 volt ont a 120 volt circuit it sounds like it is wired correctly you may have a wire not getting good conection
Sep 18, 2010 | Heating & Cooling
Intertherm furnace heat pump combo had a small fire in the control wiring when a contactor for the heating elements burnt. I am an electrician by trade and have replaced all the wiring and contactors but...
ok the transformer has a common which is black the second wire red is coming from the contactor side at 240 volts the last wire on the side opposite the common and 240 connection goes to the 24 volt side of the contactor. Hope this helped
Dave
Oct 13, 2009 | Heating & Cooling
Compressor not wired, no schematic or instruction in manual
There is a schematic under the cover of the elecrtrical connection box. Remove the top of the box ( typically one nut on top of the pressure regulator) and look under the cover you removed.
Good Luck
Jan 14, 2009 | Campbell Hausfeld Single Stage Air...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
