Question about Dryers
Dryer won't dry clothes
    Problem Solver:
  • 18 Answers
First check and see if your heating element is working by holding down the dryer door switch and turning on the dryer too see if you get a glowing from the rear inside of the drum. If it does glow then check to see if you have a kink in your dryer line or check to see if you have a clogged vent outside the vent to the dryer. Also you may want to try resetting your power to the dryer by unplugging the dryer and turning off and then backb on the breaker to the dryer then plug the dryer back in and see if that works.
Posted on Nov 09, 2012
Dryer heats but won't dry clothes completely
Inspect and clean the dryer is what I would do. most times it is a faulty blower wheel causes your symptoms.
Feb 16, 2013 | Amana Dryers
the heating unit must have been broken. go to near by mechanic shop.
Jan 31, 2013 | Dryers
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
How to check the timer:
Sep 26, 2012 | Whirlpool Dryers
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
My cloth dryer won't dry. It is not hot.
is it gas or electric, vent could be clogged. could need starting device. solonoid, or ignitor.
May 20, 2012 | Whirlpool Dryers
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
WON'T DRY CLOTHS..NO HOT AIR
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'';';
Jun 27, 2011 | GE Dryers
Dryers Logo
61 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
