Question about Sony VAIO Y Series Notebook VPCY118GXBI
I have a Sony Vaio Y Series laptop with message - Funnel Seek Test did not pass (E-HDD-003). Run - check disc to recover the wrong sector (E-HDD-005). Still comes up with same message! Can anyone help
  • J Downie Nov 09, 2012
    Thanks for your reply
    Master:
  • 545 Answers
This sounds like your hard drive is going bad. I recommend getting a replacement and backing up anything important ASAP.
Posted on Nov 09, 2012
SOURCE: Sony Vaio aftermarket battery
i have the same problem with the aftermarket battery. my sony is VGN-S48GP which i have for 3 years.
there are a few posting about this on the web on how to solve them. some people are successful and some are not.
there is a .exe file call ISBmgr.exe which is contained in the start up sequence of windows XP, when the XP is installed with factory disk from sony. this programs checks the battery and does not allow non-sony battery to work with the notebook. i ask XP not to load this program and now i can use the battery.
THIS IS HOW:-
go to Run
type MSConfig
look for startup tap
find ISBmgr.exe
disable it
reboot
i like this method because the action is reversable. there are other posts on the web which ask you to delete the ISBmgr file. i did not choose that way.
Good Luck.
ecj
Posted on Sep 27, 2008
yboyandrei
  • 828 Answers
SOURCE: I can't boot up the Vista install on a Sony Vaio VGN-NR160E
go to your BIOS Setup, see to it that there is a Hard Disk Boot Priority, maybe you didn't put it there.
Posted on Jul 21, 2009
HW_Dude
  • 87 Answers
SOURCE: Sony Vaio VGN-SZ460N - freezes on System Recovery
I put my money on that you have a CPU over temperature problem, and/or intermittent RAM problem.
Be sure you are ESD safe when working on the electronics as follow !
I suggest, using a eye piece magnifier and a wooden tooth pick and carefully touch each pin of your RAM sockets and see if the soldering is bad, allowing the pin to move slightly. If that happens, well it needs re-soldering there, make sure you use leaded solder, not the ROHS crapp.
If that turns out to be ok, then check your processor. It might over heat.
You may want to observe if the CPU fans runs at all and if it runs at full speed most the time, even if you don't run any 'heavy' programs. This usually would indicate poor heat dissipation. Most Sony Laptops have a piece of thermal foam pad is used for heat transfer from the CPU chip into the heat sink. Over time this pad shrinks, effectively impeding the heat transfer causing the CPU to over heat and intermittent shutdowns ect. I suggest, find a new piece of thermal pad or replace that with a piece of copper sheet material and use Thermalloy transfer paste.
Posted on Aug 01, 2009
yboyandrei
  • 828 Answers
SOURCE: I need to replace my sony vaio VGN-N series laptop
Here is some instructions:
www.yboyandrei.com/VGN-N
Please rate me.
Thank you.
Posted on Sep 02, 2009
SOURCE: recovery error 320 on sony vaio laptop
Ketanvasu your an idiot....If he's trying to recover the laptop obviously the thing isn't working...so how the hell is he supposed to burn cd's genius?
Posted on May 18, 2010
SONY VAIO CS ..DAMN ..NEED HELP.. My vaio cs just keeps geeting worse...its not responding well.. I clean my heatsink and.place a thermal compound.for the cores...but the problem is i caanot run the safe...
If the hdd is the normal mechanical (not SSD) I would scan that for bad sectors using HDD Regenerator on Hiren's Boot CD 11.5. While you're at it, scan the ram (module, module if you have more than 1). That way, you're eliminating errors on removable hardware...if problems persist I would say problem is with the motherboard or could be a driver problem. Try install a different OS (like XP rather than Win7 just to test). Hope this helps!
Nov 09, 2013 | Computers & Internet
Samsung r530 bad sector hard drive. Did not come with operating software disc.
Remove the HDD and test, replace if necessary. You can contact Samsung, with your laptop Serial Number, and purchase a Factory Recovery DVD. Or, you can buy a Windows Installation DVD and do a Fresh install on the new HDD.
Jan 06, 2013 | Samsung R530 Notebook
Error 58 unable to write to boot sector
Run CHKDSK, if you see a message "The drive contains one or more unrecoverable problems", you need a new hard drive.
If you cant get on to Windows try a fresh install. If that fails buy a new HDD should fix it.
Nov 26, 2011 | Sony VAIO VGN-A230P PC Notebook
I am trying to restore to the original state with the three recovery disks my Vaio VGN-NW350F but it first showed an error 320 and then an error 330. Afterwards I cannot even run the program to restore...
1. For Error 320 or 330 , if possible, run the RAM hardware diagnostics to determine if the RAM has failed.
2. Disconnect all external hardware that is attached to the computer.
3. Reset the BIOS to the factory defaults.
4. If the RAM passes the test, only the HDD requires service.
This error also may occur if you are performing a system recovery on a new unformatted hard drive or if sector 0 of the hard drive was cleaned.
Select the "Restore Complete System" option from teh recovery discs and during the installation wizard choose YES for the option "Do you want to keep the factory default hard drive size?".
Jan 25, 2011 | Sony VAIO VGN-NR498E/S Notebook PC
What is the error code during recovering
That is either a currupt partition or bad sectors on your hdd.
You will need to run the recovery media and see if you still get error messages to know if it is a failing hdd.
May 02, 2010 | Toshiba Satellite A100-S8111TD Notebook
I get the error code 2000-0146 only when i run the f12 diagnostic
The 2000-0146 error code indicates a read/write failure of the hard drive. There is at least 1 sector that is failing on the drive. While it is working at the moment, the drive is failing and will over time degrade and eventually fail completely. Backup any important data, then replace the drive.
Dec 11, 2009 | Dell Computers & Internet
Recovery Error 320
I had error 305: 69 when I tried to repair my sony vgn-ns160d using the recovery disc1. I called sony support and they told me that me hard drive was defective and needed to be replaced. they did not want to send me new recovery discs beause I was out of warranty. I copied the recovery disc at slow speed on another computer and tried rebooting the sony laptop with my fresh copy of the recovery disc. and it WORKED! it was not my HD that was defective it was their recovery disc! sonys support is non existent! trying to sell me a new hard drive!
Jul 07, 2009 | Sony VAIO VGN-NR498E/S Notebook PC
Recovery error 320 on sony vaio laptop
May 09, 2009 | Sony VAIO VGN-NR498E/S Notebook PC
Hard disc not working
yah its possible to recover the data from hdd.
just baught a recovery tool cd and recover your data
hdd may has a bad sectores .u run a bad sector recover soft ware .
May 02, 2009 | Computers & Internet
Sony VAIO Y Series Notebook VPCY118GXBI Logo
450 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
