Question about Toys
My new Estes WE2012 is fully charged but won't lift and fly, is there any way to fix that
It spins around, but basically doesn't fly!
4 Suggested Answers
  • 65 Answers
SOURCE: My Airhog will not lift off of the ground and fly.
trim adjust
Posted on Mar 31, 2010
bayyagg
  • 1672 Answers
SOURCE: my green air hog helicopter
There is a problem on the motor gear, check the underside where you could see a big gear that should spin when you try to lift the helicopter. Check both big gears if they rotate/spins.
Usually the problem is the small gear on the motor shaft that is not aligned to that big gear. Check on it and adjust the small gear of the motor.
Hope that copter flies high.
Thanks for asking FixYa!
Posted on Aug 09, 2011
197jacobs
  • 226 Answers
SOURCE: I have a S107G Gyro
battery need to be replace charge life is over
Posted on Aug 12, 2011
What cause the car want start even if u jump it it just cleick
Start with the basics, here. Check that battery cables are not loose and are CLEAN, on the battery AND the starter. Beyond that, check the battery charge with a volt meter. Fully charged should be 12.5 volts or higher, you will lose starter spin at 10 volts. If the battery is low, hook it up to a charger and charge it up completely. If you don\'t have a voltmeter, go to the store and buy one. If you\'re going to try and fix things like this, you have to have one. If you can\'t do that, remove the battery and take it to someplace like AutoZone. They will charge and test the battery for free. If you can\'t take the battery out, or don\'t have a friend that can, have the car towed to your mechanic.
Here\'s the thing- I can\'t tell you exactly why, but some cars you just can\'t jump start. Happens more on side mount post type batteries. Because you can\'t jump your car doesn\'t mean it won\'t start with a fully charged battery. Now there are other things that could be wrong with you car, that it won\'t crank over and start for you.....but we begin the diagnosis with the battery.
Mar 17, 2014 | 1993 Oldsmobile Eighty Eight
Estes quadcopter does not fly up; only left, right, back and foward
How old is the quad? Maybe the gear shafts are dragging. (Not spinning at full potential)
Jan 10, 2014 | Estes Dart Quad Copter RTF ESTE4605
LSR6132E agitator doesn't work, won't spin?
open the lid,on the right side you'll see a hole in the top panel,stick a screw driver into the hole,you should hear a click or close the lid,lift it up an inch or two and close it down,if it doesn't make a clicking sound the lid switch is bad part number 3949247 and it's around 45 dollars.
Sep 03, 2011 | Whirlpool Washing Machines
We have lost our instruction manuals for our rc heicopters. is the small tail propellar supposed to spin? we can't get them to liftoff the main propellars seem to be working fine.
Sadly, Bob is incorrect here. In a coaxial helicopter, the main rotors spin in opposite directions, equalizing the centrifugal force and allowing the craft to hover without spinning, fine-tuned by the adjustment of the trim control. The counter-rotating main blades and internal gyroscopes provide a stable hover, while the tail rotor serves only to push the rear of the chopper up or down, providing the forward/backward thrust. If you are not moving the right joystick, you tail rotor should be stationary, or perhaps moving lazily from the wash of the main rotors. Sounds like a charging issue. What type of charger are you using? Also, Li/Po batteries are not meant to be fully discharged. Fully draining a Li/Po too many times, ESPECIALLY when they are new, will ruin them. Luckily the batteries on an 032 are easily replaceable. Available on Amazon and many other online retailers, and replaced in about 1 minute with only a small screwdriver. With a new Li/Po, charge them FULLY with the correct charger, and always stop the flight as soon as you are having to give it full power to maintain altitude. Also CRUCIAL is you MUST MUST MUST let the battery rest and cool for after a flight, wait a good 10 minutes BEFORE you connect the heli to the charger, and another 10 minute cool down after charging before you fly.
Hope this helps
r
Aug 19, 2011 | SYMA Toys industrial Syma S032 Ready to...
Hi, I have a Walkera CB180d and there doesn't seem to be enough power for the helicopter to lift higher than my shoulders. I replaced the main rotor with a new one after I noticed a gap in the...
The gap is causing you to loose power transfer. Replace the main gear and you should be back in the air. The CB180 is a fixed pitch, so as long as the blades are intact and straight, you can't do anything esle to them. Also make sure your battery is good and fully charged.
Aug 12, 2011 | RC Remote Control Helicopter Ready To Fly
My green air hog helicopter is spinning on the ground, it won't lift and fly, how do I fix it?
Aug 09, 2011 | Air Hogs Havoc Heli Helicopters
Trying to start the car I get "instant draw-down" of the battery and the car won't start--the battery is fully charged
the battery may be fully charged but that doesn't mean that it doesn't have a weak cell, next time you go to start the engine remove all of the battery filler caps (if it has any) & get someone to look into the holes to see if they can see if any of the cells are bubbling,if any are the battery is faulty & needs to be replaced......hope this helps......cheers.
PS. don't get your eyes to close when looking into the holes of the battery,it might be safer to use a mirror.
Jun 28, 2011 | 1990 Plymouth Horizon
Brand new unit forward and reverse seems very slow moves a little then just hovers.
Make sure you're charging fully, until the light on the charger doesn't get ANY brighter when you unplug the helicopter. Also, battery must be allowed to cool 10 minutes after flying AND another 10 minutes after charging.
Most crucial is that you must never fully discharge battery. Fully draining a Li/Po even once (especially when it's new) can cripple or ruin your battery. As soon as you are unable to maintain altitude, land copter and power it off. Also, there is a button on the remote, labelled "tail motor speed switch" located near the trim control. With it in the "off" or up position the tail motor is much slower allowing for more precise control. When button is pushed to the down or "on" position, tail motor moves faster giving more tilt, and thereby much more forward/reverse 'thrust'. Verify that tail rotor is moving when right joystick is actuated (and that it reverses when right stick is pulled in opposite direction) and that it isn't loose on it's shaft... this can be tested by verifying tail rotor spin in one direction then reversing joystick... tail rotor should instantly start spinning in the other direction with NO hesitation, if it slows and then starts spinning in other direction or anything like that then it's loose. Turn helicopter upside down then VERY CAREFULLY apply a small drop of super glue where the shaft meets the tail rotor, be very cautious to not get any glue near where the shaft comes out of the motor, and do not turn right side up until glue is fully dry.
Hope this helps,
r
Jan 07, 2011 | SYMA Toys industrial Syma S032 Ready to...
Toys Logo
168 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
