Question about Dryers
Dryer drum not turning
My Samsung dryer has developed an issue that wont allow the drum to turn after removing top panel I noticed that belt on my dryer is not running in what appears to be the intended area on the drum because I can see an area of wear on the drum & the belt is about 3/8" towards the rear of the machine & maybe the drum is not sitting square within the dryer. There is no blockage in the vent & I can rotate the drum by hand. I have been able to get the drum turning under its own power while trouble shooting, but only once & the drum did not seem to wooble or appear out of balance, nor did anything seem to be out of the norm.
    Problem Solver:
  • 18 Answers
The belt should also be running threw a small pulley beneath the the drum. If it has come off of that pulley the drum will not spin.
Posted on Nov 09, 2012
  • 1073 Answers
SOURCE: Replace belt on Whirlpool LE09508KQ1 Electricl Dryer
remove the lint fiter and remove the two phillips screws then lift the top up
you will find two screws on each side of the inside of the frount panel down about 4 inches , this when removed will allow you to swing the frount arround to gain access to the belt
Posted on Apr 30, 2008
  • 5 Answers
SOURCE: Dryer will not turn
There is a belt like a fan belt that goes around the outer tub and onto a pulley that turns the tub, it may have slipped off, you should be able to take the top off of the dryer to check it.
Posted on Mar 19, 2009
barkencoa
  • 3463 Answers
SOURCE: tumble dryer drum won't turn hotpoint vtd00
You are referring to the rear drum bearing that has worn away..
It means replacing the rear bearing and drum shaft.
It comes in a repair kit which you can obtain from Hotpoint.
It comes complete with fitting instructions.
Go the Hotpoint web site, and you should be able to order the parts on line.
WWW.HOTPOINTSERVICE.CO.UK
In the menu click on>>>>Spare parts and accessories, and follow instructions.
Please ratemy solution.
Thankyou.
Posted on Feb 01, 2010
Testimonial: "Straight-Forward answers, quick - ace!"
  • 3 Answers
SOURCE: I have a samsung dryer
This photo is from a Samsung DV409AEW, but I assume they are quite likely the same. I also turned the drum (clockwise, which is the wrong way) and the same thing happened. The thud in my case was the spring that holds the tension pulley arm in place falling to the bottom of the dryer. If your situation is the same, spinning the drum caused the belt to come off of the idler pulley and the tension spring fell off. It seems to happen frequently based on web searches.
Again, assuming the DV409Axx is the same, you can get at it from behind. There should be 3 screws (2 on the top and 1 on the bottom) of the plate that holds the vent pipe output assembly. That assembly can then be removed. There will be a vent pipe extension that comes out with the assembly.
Once inside, see if the spring is off, and if so re-attach it per the photo below. It is counter-intuitive that the spring pulls the arm down, rather than to the left. Hopefully this will be your issue.
Putting the pipe extension and outlet assembly back in can take a bit of fiddling... but if you lay on the floor, you can actually shine a flashlight in the crack to see what you're doing.
Hope this helps!
Posted on Dec 01, 2010
  • 291 Answers
SOURCE: have a samsung dryer model DV209AEW/XAA. I "hand
Check to make sure your child lock is off first. Hold the time and signal buttons simultaneously for three seconds. Unlikely, but do check. Some of these dryers have a safety switch that the idler pulley has to engage to allow the dryer to run. I tried to find a schematic for this model but could not get one to tell if you do have a safety switch. Look at the arm of the idler pulley and see if it is contacting the switch actuator correctly. When a belt breaks or pops off, sometimes the arm of the pulley will move to the other side of the switch actuator and will not allow the dryer to run once a belt is reistalled. I would also look to see if a wire was knocked off of the motor switch when your belt came off. Good Luck, Appliance Specialists
Posted on Dec 03, 2010
We have the LG Tromm DLE2512W dryer. It was working great until one day it sounded like a big thud, and the drum stopped spinning. We can turn it on and set and start it, but the drum isn't spinning at...
It is your belt that has broken and will not allow the drum to spin, you need to replace your belt on the dryer. I do not have instructions for your dryer, but maybe the instructions for another dryer will give you the idea how to fix your, it is normally an easy fix.
http://www.applianceaid.com/images/belt-config.JPG
If you hear a loud bang while your dryer is working, and you notice that the
drum has stopped turning, chances are the drivebelt has snapped.
Fortunately, replacing the belt is a fairly straightforward operation that
can be handled with a few simple tools.
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Jan 07, 2011 | LG Dryers
Installing the belt
facing down.
Please RATE me
Jan 06, 2011 | Whirlpool Dryers
I was drying and heard a kind of banging pop noise and the drum stopped spinning now all the lights will come on but when you push the button to start nothing happens.
Installing the belt
facing down.
Please RATE me
Jan 03, 2011 | Samsung DV218AEW Electric Dryer
Drum will not turn-it just hums
Installing the belt
facing down.
Please RATE me
Jan 02, 2011 | Amana NDG7800AW Gas Dryer
Our 400 series electric dryer was making a really loude sound the day before it quit it'd bang against the washer as if the drum was loose the next day tried to use it the light comes on and stuff but...
You could have two problems.
1...Broken Belt, no allowing the drum to turn
2...Flat spots on your drum rollers are making your noise
1....http://www.applianceaid.com/images/belt-config.JPG
Installing the belt
facing down.
2...ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Dec 31, 2010 | Kenmore 400 6943 Dryer
Try to hit the start button to dry and it wont do anything just makes a low noise
Installing the belt
facing down.
Please RATE me
Dec 29, 2010 | Estate TEDX640JQ Electric Dryer
The drum will not turn, I can hear the dryer (heating element) but no turning
Installing the belt
facing down.
Please RATE me
Dec 27, 2010 | Crosley Dryers
Hotpoint tumble dryer VTD001 (31330) had snapped drum belt with drum not turning but motor making humming sound. Have replaced belt but still not working. Any advice welcome.
Installing the belt
facing down.
Please RATE me
Dec 27, 2010 | Hotpoint Dryers
Inside wont spin, it kinda was, but then quit, still heats and all just not spinning
Installing the belt
facing down.
Please RATE me
Dec 21, 2010 | Roper RES7646KQ Electric Dryer
Dryer wont turn, just "humms"
Installing the belt
facing down.
Please RATE me
Dec 21, 2010 | Whirlpool Dryers
Dryers Logo
187 people viewed this question
Top Dryers Experts
