Question about Polaroid FLM-2601 Television
Not support with ps3
When i plug my playstation 3 into my polaroid tv using a HDMI cable it comes up with not support, but before the ps3 was sent away for repair it was working on the tv perfectly.
  • 1 more comment
  • hippies_rule Jan 05, 2009
    how do i do that?
  • Lamont3000 May 11, 2010
    Im using a PS3 on this TV but using HDMI to DVI to the TV, I hope thats what you meant for this TV don't have HDMI
    What ever they did when they fixed it changed something
  • Anonymous Mar 29, 2014
    Trying to connect roku 3 to the above and cannot see where to plug in the hdmi cable - please help
  • 335 Answers
That's a software firmware issue which needs updating in your tv.
Posted on Jan 05, 2009
  • Circuit World
    Circuit World Jan 10, 2009
    If there were any digital cards installed in your ps3 as part of the repair process this may require a resetting of your ps3 data format. Whoever repaired your ps3 let them know the problem your having they should fix it back.
Playstation 3 works fine useing the av hook up but won;t work with hdmi cable hook up.
First, make sure your TV is on the appropriate input for the plugged in HDMI cable. Once this is completed, turn your ps3 on. If the screen comes on and is black, turn the ps3 to standby (red light is on) and hold the front power button until the console beeps a second time. This will usually force the ps3 to recognize the hdmi input and will bring up the menu to configure the AV settings.
Aug 13, 2014 | Sony Playstation 3 (PS3) Console
Playstation 3 turns on, but TV does not display anything. I plugged in my Playstation 2 and it worked. Help please.
Is your A/V or HDMI cable working for your ps3? Thats most likely your problem. Make sure that they are connected fully to the back of Your PS3 and your TV. If it possible try to use someone else A/V or HDMI cable to make sure.
Jun 17, 2012 | Sony Playstation 3 (PS3) Console
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    When i plug my hdmi cable to playstation and the tv, i get no signal! when i plug that 3 different colour cable. i get good graphics.. how to fix my hdmi input for Ps3
    plug both cables into tv select the input on tv that has the three different color cable plugged into it use this connection to navigate the menu on ps3 go into display settings and choose the option for 1080 p or 1080 i and then choose the input method of hdmi after doing so your picture will go blank you must then select the input on the tv that has the hdmi plugged into it your screen should then show the picture you must do this quickly because you only have 30 seconds or so to save the new settings before it resets back to the old output settings. click your x button to save and you should be well on your way to better graphics using the hdmi on your ps3!!
    Dec 06, 2010 | Sony Video Game Consoles & Games
    How do i use my PS3 with the hdmi cables only?
    ,Turn TV on, select HDMI, Plug into HDMI jack on TV plug into PS3, turn PS3 ON.
    Feb 21, 2010 | Sony Playstation 3 (PS3) Console
    Can i get my ps3 to play through my suround sytem as well as the tv?
    what type of cable are you using to connect the ps3 to your surround coposit rca, hdmi, fibopt,
    more than likely your using a hdmi to the tv and a fibopt to the surround wich should sent sound to both
    Sep 24, 2009 | Sony Playstation 3 (PS3) Console
    Cant tune ps3 to lg tv
    Be sure you have the HDMI cable in the correct slot for the input channel you are trying to connect. Try another input channel like HDMI 2, 3, or 4 depending on how many channels you have. If you have another TV with HDMI, try plugging it in the other one to see if it is a problem with your TV or the PS3.
    Mar 02, 2009 | Sony Playstation 3 (PS3) Console
    Hd tv as no hdmi plug
    There are PS3-components cables available out there (the Red/Green/Blue one) you can use to connect your PS3 to your TV and still get HDTV on your TV system. You should be able to get it where you bought your Playstation. Got one for 39.99$ CAN
    Cheers
    Dec 22, 2008 | Sony Playstation 3 (PS3) Console
    HDMI green screen
    1-HDMI is available in several versions. The PLAYSTATION 3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PLAYSTATION 3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
    The HDMI cable is not included with the PLAYSTATION 3. If you are using an HDMI to DVI converter, you may wish to remove this adaptor.
    2- The resolution output (i.e., picture quality) of the PLAYSTATION 3 will depend on three factors:
    The type of cable used and the inputs available on the TV or display monitor.
    The maximum resolution the TV or display monitor can support. The PLAYSTATION 3 can output two types of resolution: HD and SD. Refer to the TV or display monitor's owner's manual to check which video modes are supported.
    The maximum resolution programmed into the source material (movie or game). Refer to the software packaging for information on maximum resolution details or contact the publisher directly.
    3- Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HMDI setup and/or equipment.
    4- Disconnect any coaxial cables at the point closest to the television. Signals sent through coaxial cables may cause interference with the sound and picture outputted from the PLAYSTATION 3 which results in buzzing and humming noises from your display and speakers.
    Nov 29, 2008 | Sony Playstation 3 (PS3) Console
    PS3 no longer communicating with TV
    All: Try this -
    P
    erform the following steps to reset the Video Output Settings.
    1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
    2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
    3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
    NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
    As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
    If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
    With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
    If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
    1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
    3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
    4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
    5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
    6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
    7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
    Dec 16, 2007 | Sony Playstation 3 (PS3) Console
    Polaroid FLM-2601 Television Logo
    365 people viewed this question
    Top Polaroid Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
