Question about Dishwashers
Our GE Profile Model pdw7880j03ss Serial. Zg780219b Control panel will not allow heated dry and pre wash to be selected at same time. Also, when a cycle is chosen, panel automatically switches to sp
    Problem Solver:
  • 18 Answers
If you have the ability to disconnect the washer from the rear or kill the power from your main breaker box do so that it resets the control board.
Posted on Nov 09, 2012
  • 3 more comments
  • Devin Boyd Nov 09, 2012
    We have a switch to the dishwasher. I have turned power off, waited, and back on but problem persists.
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    How do I reset kitchen aid dishwasher with the clean constantly flashing? dishwasher won't start.
    Hello, push the following buttons on your control panel.......Heated dry then High temp wash, heated dry then high temp wash, heated dry then high temp wash 3 times within 5 sec you will see the control panel all light up then you should be good to go. The reason it has failed is it has exceeded alloted time to heat the water to temp selected . The best thing to do from now on is to run the water at sink until hot then start the dishwasher more so in winter than summer.
    Fixrguy
    Feb 13, 2011 | Dishwashers
    I have a GE Profile Dishwasher... it's about 5 years old (Model # PDW7880J03SS). It has a front control panel. This morning, only half of the lighted buttons work. The left side does not. I have hit the...
    I have a GE profile model number pdw8200jbb . Only two lights appear on the touch panel. The stay on for a little while after opening and closing the door and then go off. Any suggestions
    Jun 27, 2010 | GE 24 in. GSD4320Z Built-in Dishwasher
    Low detergent light does not come on indicating the GE profile dishwasher is out of detergent.
    It is probably because your Smart Dispenser is full of water and there may be a clog of some type in the pump. Try purging your Smart Dispenser and see if it fixes the problem!! It fixed ours!!
    How to Purge Smart Dispenser
    The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
    Follow these steps carefully to have a successful purge run.
    For Top Control Models:
    1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
    2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
    3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
    4. Press Start button one time
    5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
    6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
    7. Open door and wipe up excess detergent from the door and tub
    8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
    9. Remove SmartDispenser cap and fill tank with water and then replace cap.
    10. Repeat Steps 1 through 9 one time.
    11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
    Front Mount Controls (same as above except for the changes in the two below steps):
    2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
    3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
    Jul 09, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
    Purging ge profile smart dispense dishwasher
    How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
    Jul 05, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
    Dryer not heating properly..taking longer to dry clothes
    If there's heat inside the drum the heater coils should be ok, however your model has 2. With the door open and the machine running, look inside at the back of the drum and look for 2 glowing element coils. If one is not working you will not have enough heat.
    Check the exhaust vent, make sure it's not kinked or squished behind the machine and that the outside vent is not clogged with lint. You should feel air blowing freely to the outside.
    If there is no heat, first check for 240V at the outlet. If you have 240V, it could be the element, the hi-limit thermostat, the thermal cut-off, the timer, the motor or a wiring issue (loose or shorted).
    Good luck!.
    Mar 06, 2009 | GE Dryers
    Ge profile dishwasher panel won't turn on
    out of the blue my GE Profile dishwasher would not turn on. I turned the circuit breaker off for 5 seconds then on and it worked! fixed! saved $200!!!
    Dec 31, 2008 | GE Profile PDW8000G Built-in Dishwasher
    Buttons won't work on GE Profile PDW7980N10SS
    You have the control lock activated. Press and hold the heated dry pad for 5 seconds and it should unlock it
    Nov 15, 2008 | GE Profile PDW8400J Built-in Dishwasher
    GE Profile WPRE6100G will not spin
    hi thanks for the question. i think the problem is with the lid switch . lifting the lid 10 times wont help if the switch is faulty check the lid switch thanks the appliance doc
    Sep 20, 2008 | GE Profile WPRE6100G Top Load Washer
    Dishwashers Logo
    175 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
