Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
What do the flashing lights mean when you hold the "device" and "menu" buttons?
I read the posting about the problem with the lamp, and I'm having the same issue. So I held both the "menu" and "device" buttons at the same time and got a series of 3 and 4 blinking lights. The only problem now is that I have no idea what that series means. Please help if you can, thanks.
    Genius:
  • 1,153 Answers
Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002.
Posted on Oct 06, 2007
SOURCE:
We have a Mitsubishi TV model# WD-60735.. we have changed the lamp because it was flashing red but now its flashing yellow and the tv will not turn on..
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Nov 18, 2015 | Mitsubishi Televison & Video
Flashing light mean yellow
Jan 15, 2014 | Mitsubishi WD-60737 60 in. HDTV
My mitsubishi flashes a red light what does that mean
Red light is usually lamp indicator---may be time to replace the lamp--they have a 2000 hour life span except for generic ones which last half that long----when was lamp last replaced? also the set does have a self check:
Oct 30, 2012 | Mitsubishi WD-60737 60 in. HDTV
RED FLASHING STATUS LIGHT
Possible lamp failure but lamp light not status should blink-I have suggestions but want you to try the self check first--if set has been unplugged plug it up and turn on and when it fails:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
33 = Air filtercover is open.
44 = DVI cablebetween FMT and Engine disconnected
Jun 11, 2012 | Mitsubishi WD-62525 62" Rear Projection...
We have a mitsubishi WD-62525 tv and we turned it on and after a while it turned itself off and then we got a continiously flashing red status light! what does this mean & what do we need to do to fix...
Mitsubishi wd-73739 turns on then turns off with a red constant led
The set has a self check--try this(posted by another expert here):
"Here's something that might also be useful. After you turnon the set, and get the regular red blinky lights, hold down the Device andMenu buttons together for about 5 seconds.
44 = DVI cablebetween FMT and Engine disconnected"
Jun 03, 2012 | Mitsubishi Televison & Video
RE: Mitsubishi 52525 still green light
May 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Flashing red lights as trys to turn on
Dlp tvs Do Not have convergence I/cs....Sounds like the caps on the power board have swelled and leaking.
Jan 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
How do I reset the replace lamp message
Do you have a picture? If so the only way to reset this unit is to get a Zenith programmer remote. With this remote you can get into the service menu and reset the lamp timer and that will reset the unit.
Dec 31, 2006 | Zenith D52WLCD 52" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
57 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
