Question about Boating
Engine will not stay running unless i pump the ball...
I have a 96 evinrude 150 that seems to have a timing or a fuel problem. she will not stay running unless i squeeze the fuel ball every 15-25 seconds. i have a clear fuel filter that i can watch the gas disapear from when i rev her up and not be replaced. i have all new fuel lines,filters and clamps. also the pump makes no noise when i turn the key to the first position...
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 14 Answers
Going to sound silly, but is the fuel filter properly installed? I've seen this happen when the fuel filter was installed upside down. In other words, the arrow showing flow of fuel was pointed in the wrong direction. If the fuel ball is collapsing, it could be a vacuum lock problem. Try it with the gas cap loosened and see if that helps - it could be 'too airtight' and creating a vacuum, which cuts off fuel supply.
Posted on Aug 10, 2009
Doesn't seem to use oil? Oil reservoir never seems to go down?
The fuel to oil ratio should be 50:1, which means for every 50 gallons of fuel you use, you should use 1 gallon of oil.
You should see some smoke haze at starting and during running.
Having run an Evinrude that had had the auto pump disconnected in favour of pre-mixing fuel, I would take the boat to a marine engineer to check the pump and delivery. You know it is pretty disastrous when all the oil is burned out.
Sep 10, 2015 | Evinrude / Johnson 135-150-175-200 HP...
1996 Evinrude 140hp started but ran only for about 10mins.
try removing the feed pipe off the fuel pump to the carbs and start the engine , put a pipe on the pump into a container and see if its pumping ! ?
Apr 19, 2015 | Evinrude / Johnson 135-150-175-200 HP...
1996 140hp evinrude started but stalled. will not restart
Has it been sitting up all winter? If so, you might need to drain fuel from the carb and replace the filter. It sounds like a fuel problem to me.
Apr 19, 2015 | Cars & Trucks
99 suburban starts but doesnt stay running
Our F-150 had a similar problem. It was a cam phaser, then timing sensors, I believe, had to be changed as well.
Aug 21, 2012 | 1999 Chevrolet Suburban
96 ford f-150 reg cab 302 motor
One place to start,  Spark to ignition and power fuel are two different sources.  Unless they both work off the same fuse.  The fuel pump needs power to run the fuel pump, Ignition needs spark to fire the engine. Check your fuses because in my opinion it is odd that they both went out at same time.  Good Luck
Aug 24, 2008 | 1996 Ford F150 Regular Cab
Boating Logo
318 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
