Question about Garden
5hp Briggs mower. Over heats
Lawn Mower mows for about 15 to 20 mins the overheats and shuts off. Could it be the coil
  • 430 Answers
What do you mean by 'overheats'?
If it runs for a period of time then dies but will restart after it cools back off the ignition module is suspect.
Run it with the airbox cover and air filter removed. when it fails immediatly spray a shot of carb cleaner in the carb and try to restart. If it wont start its the module if it does start and you can keep it running on a prime then its a fuel issue.
Posted on Nov 19, 2012
  • 211 Answers
SOURCE: my lawn mower will not turn off
Hi
From under the flyweel comes a wire(probably black).check it.It is connected with the off position of the trotle.
best regards savumihai71
Posted on Dec 22, 2008
SOURCE: lawn mower motor just stalls for no reason
Check for water in gas tank and filter.
Posted on May 09, 2009
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
nobby63
  • 10 Answers
SOURCE: lawn mower stalls when engine is hot
first thing is to check that plug is not fowling up when hot due to motor burning to much oil.
Posted on Jul 26, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
Mower dies after 5 min. of mowing
check for spark when the engine dies you might have a bad coil
Aug 15, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
Bits of burnt stuff coming out of lawn mower
that was burnt carbon coming out and you did overwork that lawn mower not dangerouse but keep mowing long grass you will end up buy anew one soon
Dec 04, 2011 | Briggs & Stratton Briggs Stratton...
My 1147 mower blades shut off every time I have to go into reverse. After mowing for 45 minutes, something must heat up because I can't get the blades to come back on. There is a problem that could be...
As for the blades shutting offf when you go in reverse, it should have a reverse mow safety switch. Some mowers have them, some do not. In regards to the electric PTO switch, and you would have to take electical measurement when it happens, the coil in the electic PTO clutch may be starting to go bad.
Sep 22, 2011 | Cub Cadet Street Sign- tractor lawn riding...
My parents have a self propelled...front drive...walk behind 22in cut mower purchased at Home Depot 3 seasons ago.....I do the maintance on the mower....sharpen blade....change the oic/plug &...
Does the mower die right away (cuts out) or does it sputter to a halt. Sputtering out would indicate a fuel problem. If it just cuts out when hot, then more likely an ignition problem. Your coil may need replacing. Take a close look at the coil wire (spark plug wire) and its routing. Make sure it's not touching part of the engine where it's heating up and has caused a "leak" to ground it out when it gets hot. If all is well then check your spark when the engine is hot and cuts out. Make sure you have a very good blue spark and not a weak one (check it cold first and then compare!). Again, indicating a possible ignition coil problem. Hope this helps and best of luck to you.
James
Sep 14, 2011 | Toro Power Lawn Mower
Lawn mower won't start with out being jump started . Changed battery. After jump starting mower and while mowing engine stalls while mower deck engaged . If mower deck is shut off before it looses...
HI jLAFORCE 1.
Other possible causes include: Loose, Dirty or Disconnected Spark Plug in Your Lawn Mower: Check it out, clean off debris, re-connect and tighten. Fuel Not Reaching the Engine: Tap the side of the carburetor to help the flow of gas. If this doesn't work, you might need a new fuel filter.
Top 5 Mower Troubleshooting Tips ' Briggs & Stratton
https://www.briggsandstratton.com/eu/en.../top-5-mower-troubleshooting-tips.html
Lawn mower won start Google Search
Nov 30, 2017 | Simplicity Vacuums
Need wiring diagram
There is a safety switch under the seat as well as attached to the clutch pedal
Jul 26, 2010 | Yard Machines 155 Torque Briggs Stratton...
ACCELERATOR HAS STOPPED WORKING ON BRIGGS & STATTON PETROL MOWER
when the lawn mower suddenly stop working,first you should check the fuel. i think the Self-propelled device was broken. You can take the Self-propelled device off and try again with it.
May 03, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
149 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
