Question about Pioneer PL-990 Turntable
Wiring for sound to vintage Panasonic RS-8175
My vintage speakers (Sanyo SXF 1113) and the vintage Panasonic Receiver RS-8175 are working wonderful with AM/FM...however, I am not getting any sound to my turntable as it spins.
  • Tom Chichester Nov 10, 2012
    You are not getting any sound input from the turntable?
5 Suggested Answers
robotek
  • 1512 Answers
SOURCE: I just bought an old
Any luck with checking antenna connections? I have a service manual if you need it. Tuner section in this old girl predates the LM7001. Uses ha1137-38 chips, bit more complex to repair.
Posted on Jun 09, 2008
  • 4 Answers
SOURCE: THE SPEAKERS FRONT LEFT AND RIGHT IS NOT WORKING ON DTS and 5.1
Do you have the manual if not go here.
http://www.hammerwall.com/Manuals/Pioneer/Description/VSX-D608/Pioneer%20Home%20AV%20Receiver/L0020200/
Posted on Aug 21, 2009
  • 87 Answers
SOURCE: I have a Pioneer DQ-4000 receiver. Honestly I am
I think what you are looking at is referred to as a banana plug connector. You do not need to buy these connectors to make this work. If you unscrew the plastic connector out far enough, a hole from the side opens up so you can put your copper conductor through and tighten the plastic peice down. The banana plug is probably better for easy connection but using this method is just as good.
Posted on Oct 28, 2009
  • 259 Answers
SOURCE: no sound output from turntable on sx-780 receiver
do you have in connected to a phono input? be sure you haven't connected it to another input..........turntables are low-level (20ma) output, cannoit drive high-level input (200ma).........good success, meder's tv service
Posted on Dec 18, 2012
How can I stop my AM/FM receiver from over-loading my speakers and fuses?
do you think your receiver could be a electron tube type ? (that's old) if so your problem could be impedance .
most modern speakers are set to take an impedance of 4 ohms ,, when if your amp has tubes its set to use a 16 to 32 ohm impedance (speakers and amps impedance has to match or distortion will result ) impedance matching transformers can be used to help match load to amp
also speakers need to be rated for there use in wattage , if your speakers have only three amp fuses in them assuming there 8 ohms impedance then they are rated for a max wattage of 88 watts(peak to peak) any more and the voice coils will be damaged from overheating (putting twenty amp fuses in them are a sure way to do exactly that)
also a simple test one can do to older amps is to temp shunt the input together with a speaker connected as a load on output , then slowly increase the volume , no sound (hum / buzz) should be heard or any damage to speaker should occur , if either then there are parts inside your amp that is defective and is damaging speakers
Oct 20, 2015 | Panasonic Vintage Technics Sa-202 Am/fm...
Panasonic sb wa920!! my receiver broke and im wondering how to use the the speakers without the receiver?
How bypass to get sound through the sub I don't have that cord to sa - Ht 920
Apr 23, 2014 | Computers & Internet
No FM in vintage technics receiver
Connect a long wire/antenna wire to the respected fm antenna screw on the back of the receiver.
Mar 11, 2014 | Panasonic Vintage Technics Stereo Sa-500...
Kenwood receiver speakers static pop
Your volume emitter needs to be replaced. And or the resisters on both sides of it.
Apr 18, 2012 | Kenwood Kr-5600 Vintage 70s Am/fm Stereo...
Will 12 watts run these speakers? I'm thinking of buying a vintage Panasonic RA-6600 Receiver and read it only has 12 watts per channel. Thanks George
No, furthermore, UNDER-powered amps are more dangerous to speakers than over-powered ones since they begin to distort badly at much lower power outputs. Distortion kills speakers.
Mar 01, 2010 | JBL ND310 Main / Stereo Speaker
Low volume on left channel of Sony STR-GX4ES
The headphone is tapped before the final stage of the amp, so knowing that those work properly helps to isolate the problem. I think that this model uses an IC for the voltage amp section prior to the final amp stage. That being said, the IC is probably an UPC2598 (if memory serves). I'll confirm tonight. Try resoldering any connections that appear to be grainy or have rings. Let me know what you find.
Dan
May 08, 2008 | Audio Players & Recorders
Pioneer PL-990 Turntable Logo
63 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
