Question about HP Photosmart R607 Digital Camera
Camera will not turn on - HP Photosmart R607 Digital Camera
Camera will not turn on, says turn off camera and turn on again, but does nothing else
Click on the link below to fix the Camera issue. This link will be helpful for you in future too
Troubleshoot Camera Issue
Regards,
Suhail
May 16, 2012 | Pix Cameras
Every time I turn on the camera it sais Error 99 could anyone explain it to me .thanks chris
According to ehow:
Turn off your camera and remove the memory card, lens, battery and time/date secondary battery. The secondary battery is a small, round battery about the size of a dime found in the same compartment as the main battery. It is located in a vertical slot. Slide out the secondary battery by pressing your finger on the battery and pulling it toward you.
  • Place the body cap on your camera to keep dust out. Attach the front and back lens caps on your lens to prevent scratches and other damage.
  • Let the camera sit for 20 minutes. This will clear the camera's memory.
  • Place the date/time secondary battery and a fully charged primary battery in the camera and turn it on.
  • Press the shutter release button (the button you push to take a picture). If you are still receiving an Error 99, the problem is most likely caused by the camera body itself. The camera body must be serviced by a professional camera technician.
  • 6 Turn off the camera and insert the memory card. Turn the camera back on and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the memory card. Turn off your camera and insert a different memory card. Turn the camera back on and press the shutter release again.
  • Turn off the camera and reattach the lens. Turn on the camera and press the shutter release button. If you receive an Error 99, turn the camera off and remove the lens.
  • Turn the camera so that it is face down, and gently clean the lens contacts on the camera body with a number 2 pencil eraser or soft cloth. The lens contacts are the eight small, gold pieces on the bottom of the lens mount. Be careful not to let any of the eraser scraps fall into the camera body.
  • Turn the lens so that the side that attaches to the camera is upside down. Use the eraser or soft cloth to clean the lens contacts on the lens, being careful not to let any eraser scraps fall into the lens.
  • Reattach the lens to the camera. Turn on the camera and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the lens. Take the lens to a professional camera technician for repair.
  • May 11, 2011 | Cameras
    Camera says turn off and turn on panasonic lumix dmc-fs5
    While you are turning the camera on, hold the lever which you use for zooming in. The lens should extend before you get the annoying message about turning the the camera off and on. Then, gently apply pressure to the lens as if you wanted to push it back to the camera. While you are doing this, turn the camera off (lens should come back into the body of the camera). This will solve your problem.
    Thank you!
    May 17, 2010 | Panasonic Lumix DMC-FS3 Digital Camera
    The camera turns off
    allienment of lens unit with the mother board/may be problem with the sensors of the lens unit
    Mar 02, 2010 | Kodak EASYSHARE M763 Digital Camera
    Camera turn off
    dear top Experts. I have digital camera DC E30 BENQ .I do turn on my camera after seconds turn off.first please help me.secndly for repair my camera I need manual repair. thank you very much
    Apr 09, 2009 | BenQ DC E30 Digital Camera
    Camera stabilizer is not available
    check menu options is reasonable and first solutions. maybe is stabilizer turned off and you got the message. read the camera manual carefully, there is described how to turn on and turn off stabilizer. in manual, troubleshooting chapter has many solutions for camera and try to find one for stabilizer.
    if all this can't help you go to service, something is wrong with camera software.
    Mar 25, 2009 | Casio Exilim EX-V7 Digital Camera
    M527
    my camera lens doesnt work every time i turn it on the screen stays on and then the lens error: M527-22 error comes up can you help me
    thanks
    Feb 25, 2008 | HP Photosmart M527 Digital Camera
    Can't take picture
    Needs to go back to Panasonic- an inherent fault.
    Aug 16, 2007 | Panasonic Lumix DMC-LZ7 Digital Camera
    HP Photosmart R607 Digital Camera Logo
    22 people viewed this question
    Top HP Cameras Experts
    Fred Sops
    teddyboy
    Lawrence Oravetz
    Are you a HP Camera Expert? Answer questions, earn points and help others
