Question about Canon PIXMA MP830 All-In-One InkJet Printer
Won't print black and color is really bad - Canon PIXMA MP830 All-In-One InkJet Printer
  • 7,627 Answers
Replace ink carts.
Posted on Nov 09, 2012
  • 6 Answers
SOURCE: my mp830 will not print black only color
I had the same problem. I went through all the troubleshooting of cleaning the printhead several times. The Nozzle check (found under Printing Preferences/Maintenance tab) kept coming out without the PGBK section (Black) printed on it. All the colors printed. If your see any of the colors missing, it is probably the same problem---it needs the Print Head replaced.
Part # QY6-0061-010. I was able to find it at Canyon Computer Supplies in Phoenix, but you can also order them via the internet from multiple outlets. Mine cost $59.57 with tax...much cheaper than a new printer. The replacement is very easy...Canon has info on how to do it at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804#SupportDetailAct ...if the link doesn't get you right there, search MP830, Support & Service, then search print head & you should find it. Once you remove all the print cartriges (printer ON), the gray lever on the left side lifts up and releases the print head...which is the unit that houses all the print cartridges. I just put the new print head in, replaced all the ink cartridges, did a nozzle check...and it worked!! I love fixing things myself.
Posted on May 30, 2009
57 varieties
  • 1653 Answers
SOURCE: My MP830 leaves white horizontal
You need to continually clean and deep clean and realign the black until the results are acceptable. Try manual alignment if the auto does not work. Also clean around the exit hole of the black ink cartidge with a cotton bud and isoproyl alcohol.
Posted on Nov 07, 2009
  • 328 Answers
SOURCE: The black print won't print, but colour does,
your black ink cartridge got bad sprayer nozzles now you gotta replace it
and why the other color one is not bad yet cus printer as will known will depend on black ink far more so the black cartridge is heated up more times
Posted on May 27, 2011
  • 68 Answers
SOURCE: In the last 2 weeks
Unfortunately these are considered disposable printers.
If it won't power on at all even in a known good power outlet there isn't much you can do as the cost to repair it out of warranty would cost more than to simply replace it.
Other than checking the power outlet and the power cable nothing else to do.
Posted on May 31, 2011
Testimonial: "Thanks !!!!"
  • 693 Answers
SOURCE: Installed new ink on ip4200.
The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
  1. Confirm there is no orange tape across the top of the ink tank
  2. If the orange tape is as shown in Figure (A), it is properly removed.
  3. If the orange tape is as shown in Figure (B), remove the remaining tape to the level shown in Figure (A).
  4. Make sure each ink tank is snapped into the printer.
Posted on Aug 26, 2011
HPS 6500 all-in-one won't print
uh,faulty ink carterige, buy another one & don't forget to remove the clear tape seal..on the carteridge
Feb 09, 2013 | Office Equipment & Supplies
Color won't print - Deskjet F4210
you are having a defective printer head so just got it replace or get another printer
Feb 04, 2013 | HP Deskjet F4210 All-In-One InkJet Printer
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
How to turn off color ink in Epson Stylus R300
There is a place in the printer driver (epson part) that hays checkboxes for "color" and "Black & White". If you are trying to do this becasue you are out of one or more of the color inks, and can't print- you still won't be able to until you replace the empty ink(s), even though you told it black & White
Aug 30, 2012 | Epson Office Equipment & Supplies
Need only black to print from HP Color Laserjet 4700 printer
on the print page just before printing , go to properties and make black the default color
Jun 04, 2017 | Office Equipment & Supplies
How do I print a color page in black in white so i won't use up the color/
Open 'Printers and Faxes'.
Right-click your printer and select properties.
Click 'Printing Preferences' button (Close to the bottom of the dialogue).
Click 'Paper/Quality' tab from top.
Select 'Black & White'.
Click 'OK'.
If you want to use B&W cartridge for all documents, Click 'Printing Defaults' button from advanced tab and change the same setting.
Sep 04, 2011 | Canon PIXMA MX310 All-In-One Printer
I want to print using my lexmark X6170 but I don't want to print color so I didn't put a color cartridge in. It keeps coming up with an error message and won't print at all.
Some printers require you to have the color cartridges in them even when you are printing black and white. You usually can in your print options choose black and white over color.
Sep 03, 2011 | Office Equipment & Supplies
My MFC290C printer will not print in black. I changed the ink and it still won't print black. I changed the color of the type and it will print in colors, just not black. I ran the cleaning cylce...
You need to call Brother at 1-877-brother and tell them your mfc is "missing black". They will tell you where to take it to get the print head replaced under Brothers' warranty. This is a VERY common problem and Brother will cover the cost to repair it.
Aug 10, 2011 | Brother MFC-290C Printer
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
The black print won't print, but colour does, although very lightly. I have refilled the ink cartridges at Island Inkjet, so there is ink,..but black won't print at all.
May 27, 2011 | Canon PIXMA MP610 InkJet Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
12 people viewed this question
old marine
old marine
