Question about Cell Phones
What is the latest bin code for slimsat 5000 - Cell Phones
MALFUNCTION CODE COb60
Finisher bin motion failure.Unplug the finisher,sorter assy and use a copy tray.
Dec 11, 2012 | Minolta EP4000/5000 CS/PRO Copier
It says error code C0b63 what does it mean
All Cob codes on this series of Minolta copiers pertain to the sorter. Most all of the time you can simply open and close the sorter to reset the code. By open and then close I mean that the sorter must be pulled away from the copier then closed back.
Make sure there is nothing interfering with the movement of the sorter bins.
If opening/closing does not reset the code or if the code comes right back after resetting then the sorter will need service as dis-assembly/repair/re-assembly will be required. You can also unplug the large connector going from the sorter to the machine and use the copier without the sorter. If you have a 10 bin sorter that "hangs" from the side of the machine then you can leave the sorter attached and it will work fine unplugged. If you have the 20 bin sorter that sits on the floor then the sorter will have to be moved away from the copier if unplugged to prevent the machine from jamming. If you unplug the sorter be sure to turn the copiers power off before disconnecting the sorter.
Good Luck and Thank You for using Fixya.
WheatlandService
Nov 11, 2010 | Minolta EP4000/5000 CS/PRO Copier
Hi folks, does any1 hav the latest codes for telewest starview
THE CODES AV NOT CHANGED . First copy codes down on paper then goto emu screen and press default key and your codes will change then retype your old codes back in its worked for me bin looking for new codes for hours no luck so i tryed it good luck
Jul 31, 2010 | StarTech.com StarView SV221DD 2-port KVM...
24th July 09, Eurovox 5401 AREA CODES PLEASE
5a01
AA B7 D1 D9 CE 8E 83 AF
8E 80 D7 EF 44 93 02 2B
Jul 24, 2009 | StarTech.com StarView SV211K 2-port KVM...
Minolta EP 5000 error code c0b63
Hello sir; that code means sortr bins problem, I belived when you moved hit somewhere soter bin out of track( not line up).
Mar 22, 2009 | Minolta EP4000/5000 CS/PRO Copier
Minolta EP4000 Error C0b62
Hello sir;that's sorter bin problem, check the sorter bins see anyone out of track not move otherwise shift motor defect.
Jan 08, 2009 | Minolta EP4000/5000 CS/PRO Copier
Error code C0B63
All C0b** codes are related to the sorter. A C0b63 is a malfunction of the bin lower limit position sensor PC2. Most likely it is a broken bin.
Nov 19, 2008 | Minolta EP4000/5000 CS/PRO Copier
Cell Phones Logo
155 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
