Question about Invacare Supply Group Invacare XPO2 Portable Oxygen Concentrator - Supplemental Battery Pack
My dad has an invare xpo2 the machine will shut off for no reason it may run for 5 minues and shut off or run foor an hour and shut off you never no
  • chuck Nov 10, 2012
    this concentrator has 5 settings to put out the amount of o2 needed. Yesterday it was on 4 litters of 02 and stopped running constantly. It would restart right away after pressing the on button. I changed it to 3 litters hopping my bdad would be ok and never shut off once.
My comfort pro / brand new /300 hours shuts down twice a day and 4 or 5 times a night restarts right away and runs for hours hate waking up all night to restart what's up?
consult your supplier for support .
WHEN ANY COMPUTER RESTARTS ON IT'S OWN AND THE INSTALLATION OF UPDATES IS NOT THE REASON WHY THE FIRST THING TO CHECK FOR IS THE SHUTDOWN TEMPERATURE SETTING IN THE BIAS.
It may be that the processor and the system board are exceeding the temperature that has been set for the system to shut down. There is a need for such a system in order to protect the machine from dying from overheat.
It may be that you have a component level fault that needs a repair but, either way, the supplier should handle the issue.
Jul 10, 2015 | Computers & Internet
Trying to find a owner's or user's manual for the
Go to brother.com, click on support, poke around there you will find a manual.
DickyO
Sep 05, 2011 | Brother ML-500 Typewriter
Good Morning, I have a Hunter foor standing,
Hi medoody...
Sounds to me like you need to disassemble,clean and oil your fan.
After 5 yrs of running it probably needs it badly.
Please take time to rate me
Aug 11, 2011 | Hunter Floor Stand Fan Stand (Pedestal)
GOT THE HEATER RUNNING FOR 5 HOURS YESTERDAY BUT WHEN I SHUT IT OFF AND THEN TRIED TO TURN IT BACK ON IT WOULD NOT START. THE RED LIGHT IS BLINKING SLOWLY, IT USUALLY IS ALWAYS ON! BARRY
Hi Barry,
Turn off al power... drain the header manifold. Remove the top cover and remove the pressure sensing line from the pressure switch. Clean out the line and the manifold fitting with a piece of wire. Reinstall manifold drain plug. Reconnect rigid pressure sense line to manifold and pressure switch. Make sure the sense line does not leak or it can cause the unit not to heat at all. Leave the power for the heater off and circulate water for a few minues to flush header manifold then Test the unit. If this does not correct the problem... respond with the complete model number and we can continue troubleshooting.
Thanks for choosing FixYa,
Kelly
May 24, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Machine shuts off and says NOT READY. It will not work again until it is unplugged for a minute. Plug it back in, water heats and READY. It is not set to shut off. It shuts off soon after using for no...
Sorry to read about your problem, I hope this helps you out.
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
dad
asd
Dec 17, 2010 | Keurig Platinum B70 Coffee Maker
My Dolphin Dynamic used to run a 8 hour cleaning cycle Now it runs foor maybe an hour and shuts down. I took it in for repair and they told me I needed a new motor for a cost of $875 and a couplke of...
The motors, as they fail, can run for some time before shutting down. At some point in the near future they will fail all together. I do not think the dynamic residential motor cost as much as they claim and they must not be a service center since they are charging over $100 for labor. You may want to send it to a service center that is authorized to fix Dolphins. For a list, go to the Maytronics website at www.maytronicsus.com. In the end the repair should be lower than your estimate so far.
If you want a price to replace the motor with labor, please contact us thru our site at www.arrowpools.net. I'll get you an estimate on the motor with labor and return freight charges.
John
Dec 06, 2010 | Dolphin Maytronics Advantage
Washer is stuck at 45 minues
Check the inlet screen on the cold water hose. Turn off the cold valve by the inlet hose, disconnect the hose from the back of the machine, and look for a plugged screen inside the hose thread nipple on the back of the machine. Remove screen, clean it out, replace screen, hose, and turn water back on.
May 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Spark plug wire sequence foor a 3.1
No 3.1L but choose the one that is yours.....
2.5L Engine Firing order: 1-3-4-2 Distributor rotation: clockwise
1999-04 4.0L Engine Firing order: 1-5-3-6-2-4 Distributorless ignition system
4.7L Engine Firing order: 1-8-4-3-6-5-7-2 Distributorless ignition
5.7L Engine Firing order: 1-8-4-3-6-5-7-2 Distributorless ignition
Oct 09, 2009 | 2002 Jeep Grand Cherokee
Invacare Supply Group Invacare XPO2 Portable Oxygen Concentrator - Supplemental Battery Pack Logo
44 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
