Question about Brother HL-2040 Laser Printer
Paper looks dirty and grey after coming out of printer
Toner is not that old and no light or indication to change toner
  • 133 Answers
Seems like your printer is just too dirty, please go buy a duster to clean up your printer. Specially the drum.
Posted on May 23, 2009
Samsung printer printing grey
The exit mirror of the laser-scanner unit is dirty. There is a gap above the toner cartrigdge, where the laser beam is comming from. Try to clean with dry soft lint-free cloth.
Apr 08, 2012 | Samsung SCX-4300 All-In-One Laser Printer
Page looks "dirty" print is not clear
this is normally one of three things in my experience with these printers.
- either the printers drum unit has come to the end of its life and needs replacing
- the toner unit is coming to the end of its life or is a very cheap replacement cartridge not a brother original
- the fuser unit has become fouled up and is marking the page.
both of the first two parts the drum and toner are replaceable, i would recommend getting the original brother parts as they tend to work a lot better than most refilled cartridges i have seen for sale.
this should solve the problem, as its basically excess toner sticking to the drum due to age greying up the papers color.
if neither of these solve the problem you can get kits to clean the fuser unit, but i have never used one of these, as our company keeps a small stock of replacement parts for these printers in case we need them.
Dec 29, 2009 | Brother HL 1440 Laser Printer
Printing black on paper
Some of these machines will allow you to printe a grey scale test copy.
This will readjust the fax machine back to a nominal mode.
Not knowing how old or how long the machine has been serviced, background can be caused by dirty optics somewhere in the machine.
A remanufactured drum unit can cause this type of problem, (defective unit)
Competitive toner in the toner unit can cause poor copy quality.
Reinstall the old cartrige and see if the problem changes.
Not knowing if the machine has a seperate drum unit and developer housing, it would be hard to answer anything else.
Oct 15, 2009 | Brother IntelliFAX 4100 Laser Fax
Problem with ink coming out on paper
Replace the toner cartridge with a brand new one. There's no such thing as refilling toner cartridges. When it's empty, the drum unit is finished and it should be replaced, not refilled. Remember that the drum unit is sensitive to light, and will also be damaged if exposed to a great amount of light over a perid.
If a new cartridge does not solve your problem, remove the cartridge and check out the charge roller. It's located in the upper part of the "cartridge-room". It's a grey roller. lower the front cover the get easy access to it.
If it looks nice and clean, just leave it. If it is dirty and smutsy, you should remove it and try to clean it with hot water. If it is damaged in any way, it should be replaced.
Still problems ?
Check out the fixing unit. Remove the fixing unit and look at the the big rollers that put out the paper. If they look nice, put the fixing unit back in. If they are burned and dirty, replace the fixing unit.
Good Luck.
Jul 29, 2009 | Lexmark T632 Laser Printer
Dirty Pages
your fuser may need to be changed. The fuser fuses the toner to the paper. sometimes it will get a build up on it causing "dirty pages" as you described.
May 22, 2009 | HP LaserJet 4300tn Printer
Grey streaking on printed pages
Laser printers are charged using a drum which produces an electrostatic image. The drum could be unable to hold all of the 600v charge or be be scratched if the streaks are always in the same position the the drum is not holding the charge for the toner to attach to and therefore the drum is faulty and beeds to be replaced
May 20, 2009 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
551 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
