Question about Acer ASPIRE 5720-4649 Notebook
My acer aspire 5720 has no power and does not open when connected to a wall socket
When i tried to open it, the power LED lights, and the fan rotates but then suddenly stopped, without opening the monitor and continues that way. i've tried to connect it to a wall socket but the same problem occurs. then i tried removing the battery and connecting to a wall socket then turning it on. Then the power LED does not light and the computer is dead. it deos not turn on or shows any lights upon pressing the power button of the computer..
  • Jhougeois Mcburgen Nov 09, 2012
    is it possible to fix it if the problem is on the mainboard???
  • 13433 Answers
SOURCE: Acer Aspire 3100 Laptop Monitor will not turn on
1. Mainboard failed
2. Vga adapter failed
I wouldnt be suprised if the vga failed, my acer broke down on me 2 times, on the 3rd time it was too much and I sold the laptop.
Posted on Mar 28, 2008
ghoff1
  • 167 Answers
SOURCE: acer aspire 5562 have no power and won't turn on
what repair shop does work at no cost?? ok first check the voltage from the power adapter, if you have or can borrow a test meter. i have seen these go bad and still seem to work!( incorrect amperage and- or voltage). or you simply have a failed motherboard .good luck !
Posted on Feb 19, 2009
  • 329 Answers
SOURCE: acer aspire 4330 will not boot up
Can you plug a external monitor into the machine, most laptops have that serial port. If montor comes on, you have bad display or connections, If not you have problems with laptop....Good luck
Posted on Apr 23, 2009
tbirdfan1
  • 3051 Answers
SOURCE: My Acer Aspire 5720 laptop won't charge while it's running
Hello there:
try removing the battery from the computer and turning on the computer to see if the power cord works correctly if it does inspect the battery and clean the terminals on the battery and computer and put the battery back in while it is still on now you should see the battery show up on the taskbar if not right click anywhere on the desktop and go to properties and than go to than go to screensaver than look towards the bottom and you will see power click on it and you should see the options for the battery ok sorry this was so long but i needed to explain it in full
please dont forget to rate this
best regards mike
(usn retired)
Posted on Aug 04, 2009
  • 4090 Answers
SOURCE: Can't turn my lappy on
Damaged Bootstrap You need to take it for repair
Posted on Aug 16, 2009
Check cable connection acer 4739
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Mar 23, 2013 | Acer Aspire 5500 5570-2609 Laptop
What's your problem?how to fix battery not charging on acer aspire 5742Z-4512 notebook
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's power socket.If the power/battery LED light flashes and in a certain position this LED lightstays firm, then the power socket is either faulty or it has a dry solder jointwhere it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jul 07, 2012 | Acer Aspire 5742z-4512
CHARGING POINT BROKEN ON ACER ASPIRE
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 08, 2012 | Acer Aspire 5551 Notebook
Acer 5315 wont turn on and wont chare, no lights at all on laptop but charger fully working.if i eventually get it to turn on it turns straight back off
Nov 04, 2011 | Acer Aspire 5610-4648 Notebook
My Acer Aspire One AOD260 not charging the battery, can you help me?
Nov 28, 2010 | Computers & Internet
My Acer Aspire 5720 wont power up, i have tried it with and without the battery, power goes to the power buttons led and fan for 8-10 seconds and then it cuts out ?
Motherboard problems. It's an Acer and they're notorious for having these exact issues about one year to two years after being bought.
Jul 26, 2010 | Acer Aspire 5720-6661 Notebook PC
Acer Aspire 5720 Laptop issues.
It could be the battery. So i'd try to find a store that sells batteries and replace the battery.
Manny laptops will shut off when the battery is dead. So if your laptop works without the battery and only connected to the wallsocket, it's definitely the battery.
With kind regards,
Jeffrey
Feb 16, 2010 | Acer Aspire 5720-4984 Notebook
Acer 5920 aspire wont start
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well.
2. Make sure AC Adapter is not yet connected to the laptop. Pressand hold on the laptop’s power button for 10 seconds to drain the powerflea.
3. Connect the AC Adapter for laptop to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
6. Before replacing the motherboard there is one checking needs todo. If you can open your laptop bottom part then good, do this whenlaptop is not connected to any power source. Try to reseat the laptopCMOS battery then try to power on laptop after, if still fails thenreplace motherboard. I hope this helps.
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
Power supply jack on Acer Aspire 3680 Laptop not macking connection. checked power supply and it is putting out 19.2 volts. How do I go about changing jack?
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot fix this yourself then I suggest you get a quote first.
Nov 03, 2009 | Acer Aspire 3680 Laptop
Acer Aspire RAM
There are 4 screws holding the cover on the bottom of the computer that allows access to the RAM modules. (This is the same cover that also covers the fan. The same cover with the ventilation slots.)
Simply remove the screws and lift the cover by the indent to the right of the battery lock.
Nov 22, 2008 | Acer Aspire 5720-4230 Notebook
Acer ASPIRE 5720-4649 Notebook Logo
97 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
