Question about RMR-C450 Radar Detector
I have 2 rocky mountain radar detectors, and both of them are RMR 450, one needs a speaker and the other one will lite up but will not work, what does it cost too get these detecctors reworked
Just want too know what it will cost to get these detectors reworked
2 Suggested Answers
  • 36 Answers
SOURCE: I NEED A MANUAL FOR A ROCKY MOUNTAIN RADAR C-450
You can get a tiny speaker from a laptop or Radio Shack.
Posted on Dec 25, 2009
How to choose the best BGA rework stations in India?
To choose the right BGA rework station, you need to know complete details about it. BGA rework is an important part of the procedures at electronic assembly and repair houses across the world. An enormously challenging procedure, the BGA rework involves high skill levels, as well as a touch of creativity displayed by the technician executing it.
The equipment with which an electronics assembly and repair technician conducts the BGA repair is called a BGA work station.
Actual rework involved in the BGA rework station is basically conducted following the assembly of electronic printed circuit boards or PCB. PCB assembly involves a long procedure of detail oriented and careful work execution involving steps such as soldering and desoldering of joints to assemble the perfect PCB. See more http://www.sumitron.com/products/automatic-soldering-for-pcba/bga-rework-station
Apr 13, 2016 | Boating
Marklin repair southampton pa
Sounds like the GPU needs replacing not just re-soldering as it will keep on happening. Using lead free solder is not recommended as the solder doesn't tin always.
Jul 31, 2014 | Sony VAIO VGN-FZ470E/B Laptop
Md 3006 metal detector
Try hitting the reset button to center the needle in the meter then adjust the sensitivity knob to lower the sensitivity. Double check all your switches to make sure they're where they should be.
Finally, remove the batteries completely. If they're not alkaline, replace them.
If none of this helps, check the web to see if Famous Trails offers customer service or technical support. If they do, contact them to see if they know how to solve the problem.
The third option is to take it to a local electronics repair shop. The circuitry on metal detectors, especially the low end ones like Famous Trails, is not terribly complicated and a good electronics guy should be able to fix it fairly inexpensively.
Be sure to get a repair estimate then weigh the cost of repair against the cost of replacing it with a new one.
I've had this happen to my low end metal detector and when I went through all of the original set-up steps, I was able to clear the problem up myself.
May 11, 2014 | Famous Trails Discriminator Ii Metal...
A/C IS NOT WORKING, MECHANIC ASKING TO CHANGE THE PISTON.
Please check to change only if the rework is going to be warrantied as after doing the work if the compressor is not pumping to the desired level , it would be a big mistake.
So estimate the cost of the rework to the cost of a new compressor and make your decision.
After all the Ac must do the job well in cooling and any let down will be a waste of money.
Aug 28, 2010 | 1993 Toyota Corolla
The power deflection board is messed up will it be better to invest in a new tv?
Only you know this answer. The refurbished boards on some of these TV are no longer available. You would need to send the current board to PTS Electronics to have it reworked. Approximate cost would be about 200 bucks! Good Luck!
May 24, 2010 | RCA HD65W140 65" Rear Projection...
I am looking for a rearview mirror mount for my sensoro traveller radar detector and suggestions?
you can login to www.gottobuy.net and there you can search for Sensoro Traveller II Radar Detector, it will show you the samples and cost and you can order it.
May 17, 2010 | Traveller II Radar Detector
MF12568AEB lights flashing and ice door flapping
Sounds to me the keyboard or the control panel has shorted out. If you want to get some assistance I will help you and possibly have a service manual for your model. Let me know, Thanks, Sea Breeze
Dec 22, 2009 | Maytag MFI2568AE Side by Side French Door...
I have a k 40 stealth mounted radar unit - it keeps faulting and giving me beeps like every 30 secs
if the beep is one beep every 30 secs then the front radar detector is defective. If it beeps 2x every 30 secs the rear radar detector is defective. If under warrantee you are good. If not, take to any dealer and cost $225 to get it replaced.
Dec 15, 2008 | 2000P Radar Detector
RMR-C450 Radar Detector Logo
42 people viewed this question
Top Rocky Mountain Range Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Rocky Mountain Range Vehicle Part and Accessory Expert? Answer questions, earn points and help others
