Question about GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
We have a GE profile ps123sgna bs side by side that is around 10 years old. Niether side is staying cold enough and frost is accumulating in the freezer. Does this model have a defrost timer? If so, what part # would that be? Thanks for any help you can give
  • 1 more comment
  • Kathy Madison Nov 09, 2012
    Are GE defrost timers interchangable between models?
    I've been doing some more research and I think the model # must be PSH23sgna bs
    Would a board be required instead of a defrost timer?
    Top Expert:
  • GE Master
  • 9,472 Answers
The defrost timer is part of the control board. If the unit is not defrosting, you will need to replace the board. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Posted on Nov 10, 2012
Bgillespie
  • 89 Answers
SOURCE: GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Wow, so you dropped some money into it, eh? I would take a look at the damper door asslb(DIFFUSER). located at the very top left of your refrigerator section in back. It has a motorized door that opens and close's and it may be stuck open. More than likely it is broken and needs to be replaced. GOODLUCK!!!!
FYI: All your cold air in your refrigerator comes from your freezer!
Posted on Dec 17, 2007
SOURCE: GE Profile Side by Side is getting too cold on the fridge side.
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
Posted on Mar 01, 2009
  • 291 Answers
SOURCE: GE GSS22SGMC BS s x s freezer frost build up and I
This problem is usually caused by a blown defrost heater in the freezer. Unplug the refrigerator, remove the back lower panel inside the freezer. Defrost the aluminum evaporator coils. At the bottom of the evaporator is your defrost heater with two wires going to it. Remove the two screws holding it on and pull the heater out carefully. You will usually have to jockey it from one side to the other to remove it. It is a glass tube heater with an element running through it. If it is blown, it usually is black. You can do a continuity test on it also, to be sure. If it is good you can easily see the complete heater inside the glass. One of the wires goes up to the defrost thermostat which is usually clamped onto the top of the evaporator. Inspect this also to see if the top has seperated from the round base or if it is pushed out. Replace if it has blown. You can only do a continuity test on this if the defrost thermostat is colder that 50 degrees. This is a very common repair, I carry two of the replacement defrost heaters, and I always check for this first when I see a defrost problem with this model. Good Luck, Appliance Specialists
Posted on Feb 03, 2010
Sea Breeze
  • 4655 Answers
SOURCE: Refriger not cold but freezer is cold
Your defrost timer is inside the fresh food compartment and behind and inside the control panel. Part number WR09X0489. I will show you a photo location. Be right back, Sea Breeze
Posted on Apr 08, 2010
  • 228 Answers
SOURCE: Freezer n refrigerator is warm at 78 degrees
If the compressor is running it either has broken valves or the refrigerant has leaked out. Without knowing more than the information you've provided I would start with the basics. Does the fridge have power? Can you hear both the condenser and evaporator fans running? Have you checked the coils under the fridge to see if they are clean?
Posted on Jun 21, 2010
Ge profile arctica model #ps123sgna bs, leaking water from fresh food side?
Plugged or frozen drain pan located under the evaporator (cooling coil), located in the freezer.
Aug 31, 2014 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator is too cold (28 degrees)
this is likely one of the thermistors on the fresh food side has failed. They are usually located under a small cover inside the fridge. They should have a reading of 15.5k-16.5k ohms at 72 degrees. They are easy to check and replace. Here is a link that should help. You can also enter your model # for diagrams and illustrations of your specific model. http://appliancehelponline.com/sxsfreshthermistor.html
Jul 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Jun 21, 2010 | GE Profile Arctica Stainless Steel Top...
Water Filter Freezes
The filter is building up ans excess of water. When this waters freezes it expands and breaks the filter. Do you have a way to extend tubin, and install filter on the outside of unit?
Jul 20, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
GE Profile not keeping items cold or frozen
Does'nt sound like your compressor.sounds like you may have frost build up,and the tubes may be partially blocked.Try defrosting the whole unit.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 21, 2009 | Refrigerators
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
May 02, 2017 | Refrigerators
Ge side by side not cooling enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting,
Sep 07, 2007 | GE Profile PSS26NGS Side by Side...
GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
307 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
