Question about HP Photosmart C5180 All-In-One InkJet Printer
HP C7280 keeps "initialization process resuming" "wrong cartridges", but initialization was done several years ago.
  • 75 Answers
SOURCE: CARTRIDGE PROBLEM
check ur cartridge if they have ink left, or replace new ink cartridge.
Posted on Mar 07, 2008
SOURCE: HP Deskjet 1280 : The resume light keeps on blinking.
Can I get the reply now? I have a whole lot of documents waiting to be printed.
Posted on Oct 11, 2008
  • 59 Answers
SOURCE: cannot install cartridges to initialize set-up
take it off the tape in the ink cartridge maybe work
Posted on Dec 27, 2008
hsanfor
  • 71 Answers
SOURCE: HP photosmart c7280 printing photos with purple hue
Does the c7280 use seperate Magenta and PhotoMagenta cartridges? If so make certain the right cartridge is in the correct slot.
Posted on Jun 20, 2009
nirikip
  • 56 Answers
SOURCE: HP Photosmart C7280 color ink running out despite not using it?
  1. Unplug power cable while the printer is ON.
  2. Press and hold the '#' and '3' buttons, and plug the cable back into the printer.
  3. Continue holding the buttons down for 20 seconds, and then release it.
if doesn't initialize successfully repeat
on step 2 press and hold the '#' and '6' button and plug in the power cable.
Posted on May 13, 2010
C7280 HP Printer. Both Magenta catridges wont print. ERROR states that they need to be replaced , but have been replaced several times and still have ink. Message also says print in blak only. click on...
I have been told that HP printers have a built in program that will make printer fail after a set number of pages have printed,
and if the NV Ram is reset this will reset the page count,
page count resides in the transparent, image or drum kit.
I dont know how to find this or reset page count but if anyone knows i would like to do this on my hp printer
please any help.
May 06, 2011 | HP Photosmart C7280 Printer
Can you please deswcribe potential solutions for "ink system failure"
There can be several reasons to get the Ink System Failure Error on the printer screen. They are
1. One or more Cartridge install by date has expired or the printer has detected that either one of the cartridge expiry date is due.
2. This can also be hardware failure issue ( Printer Life time )
These are the steps you can try to fix this issue :
1. Open the front access door where you find all the cartridges installed
2. Remove all the cartridges and clean the electrical contacts/golden contacts you find on the cartridge and also inside the printer cartridge slot
3. Check for Date on the cartridge, If any cartridge has date less than current date, you can try replacing the cartridge ( but again this is giving it a try )
4. After cleaning the cartridge contacts, install the cartridges back into the printer and close the door and wait for the printer to go through initialization process.
Reference Link : http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01081814&tmp_track_link=ot_recdoc/c00850047/en_us/c01081814/loc:3&lc=en&dlc=en&cc=us&product=3204785
If you still get the same error, try a reset on printer ( doing the reset will erase printer memory like fax logs, printer will loose wireless network connection or bluetooth connection disconnected )
To do the reset :
1. Disconnect the power cord from back of printer while the printer is power on
2. Press and hold # and 6 key and connect the cord back ( Connect the cord while you are holding the # and 6 )
3. Release the buttons after 4-5 seconds once you have connected the cord
4. If the printer is off, Power on the printer by pressing the power on/off button.
5. Wait until the printer goes through initialization process
If the above steps does not fix the issue, assume it could be hardware failure issue.
If your printer is on Wireless network and you followed the Reset, Please run the Wireless Setup Wizard from printer to connect the printer to Network again.
Sep 07, 2010 | HP Photosmart C7280 Laser Printer
Hp deskjet c7280 giving a error 0xc180501 what to do?
I myself have not tried this, but apparently it came from HP.
HP Photosmart C5180 show ink system failure message
This was what I was told to do for my C5180. First they told me to do a power drain. This is done by pulling out the power cable and then holding the on/off button for a minute, then putting the power cable back in (this didn't work).
Then we did a master reset. Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. This sorted it.
Have to say it looked like this whole process used up shed loads of ink, so by the time I had finished I needed to replace 3 cartridges!
Thanks,
Bhautesh.
Aug 21, 2010 | HP Photosmart C7280 Printer
May 13, 2010 | HP Photosmart C7280 Printer
I have an HP Photosmart C7280 Laser Printer and received error Oxc18a0001. I have been using refilled ink cartridges. Turning it off or unpluggind does not fix it. Can you help?
Hi there
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
1. Press the On button to turn the printer off.
2. Unplug the power cord from the back of the printer.
3. Remove all the ink cartridges.
4. Wait two minutes.
5. Plug the power cord into the back of the printer.
6. Press the On button to turn the printer on.
7. Install the ink cartridges when prompted.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 23, 2009 | HP Photosmart C7280 Laser Printer
Error 0xc18a0105 - ink faillure for HP c7280-help
Go to our web site at : www.ccl-la.com/ and click on the printer service section. We have a walk thru that will get you back going. The problem you have is caused by air in the ink feed tubes and the repair guide will show you how to do a feed tube purge.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Sep 23, 2009 | HP Photosmart C7280 Printer
Jun 20, 2009 | HP Photosmart Pro B8350 InkJet Printer
Cannot install cartridges to initialize set-up
Dec 27, 2008 | HP Office Equipment & Supplies
HP Laserjet 1020 - prints blank documents
in my printer the resistor R348 on the motherboard printer was broken. The value that must have is 10 ohms. I have changed and the printer has resumed work.
Dec 05, 2006 | HP LaserJet 1020 Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
43 people viewed this question
Seeker5211
Seeker5211
