Question about Pace Type 30-0060 1121-0369 D1 .060 D2 .188
HD BOX SETTINGS
IN PICTURE SETTINGS IN THE HD BOX I HAVE 720P 1080I AND AUTOMATIC CAN YOU TELL ME WHAT IS AUTO FOR
MR G HAM
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 62 Answers
The Auto setting does exactly what it sounds like. It detects what the native signal is coming in e.g.(480i, 480p, 720p, 1080i, 1080p) and auomatically sets the box to the optimum setting. P=Progressive scan. I-interlaced. Progressive is much better than interlaced. 720p actually has more clarity than 1080i. Basically 1080i=520p! So I would set it at 720p if possible. But automatic is the easiest with the least amount of configuration. If you set it for 720p, then odds are you will have to set yout tv to 720p also.
Posted on Jan 08, 2009
Why is there sound but no picture?
According to the owner's manual page 2.7 (and this is an OLD [by HDTV standards] set), the TV can only handle input resolutions of 480p or 1080i on the composite inputs. Most HDTV programming today is 720p with some 1080i and 1080p on certain channels (like some Discovery shows about nature). It is possible that your set will not process the 720p signals being sent.
Nov 03, 2015 | Samsung TSL3294HF TV
Will not display 1080p from cable company. i have a hd box hooked up
Most cable HD-boxes output either 720p or 1080i, not 1080p.
Set your TV to 1080i or 720p.
Set the HD box to the same resolution.
Mar 16, 2014 | Sony KDF-50E3000 Television
I have a Mitsubishi WD-73737 73-Inch, the picture format keeps changing automatically. for example, the format will be set at 720i wide and it switches back and forth to 720i normal. any ideas?
I've seen that happen on equipment that has automatic signal detection. Usually this option is available when connecting the equipment with an hdmi cable. The setting can either be on the television or the cable/sat box or both. You have to disable the automatic signal detection signal on both the television (if the television has one in the setup hdmi menu if there is one) and on the cable/sat box. Further you have to choose a resolution on the cable/sat box normally 1080i or 720p fixed. Disable the 4:3 override if there is one. Save and lock in the settings and you should be all set.
May 07, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
When hooking up HD Cable box I get "not supported
You most likely have to set the Cable Box to a specific resolution. Because that model only provides 720p/1080i, the box must be set to match that. You may need to use the yellow/white/red Composite output on the box to the tv first, so you can access the boxes menu and set it to 720p or 1080i, then I recommend using Component cables (Red/Blue/Green with white/red for audio) out of the box in to the TVs "Component 2" input. Now you should get a good HD picture. If you still can't get it to work, give me a reply with details and I will get back to you.
Jan 14, 2011 | Samsung HLN617W 61" Rear Projection HDTV
Keep losing picture on my hitachi hd channels only. when i put it on antenna mode, we have a picture. can u help???
You need to change the output format from 1080i to 720p or 480p in your cable box. this set may no support 1080i.
Dec 18, 2010 | Hitachi 51S500 51" Rear Projection...
Hi, I just got the DCX3400 HD Box from the Shaw, But I could not get more better HD quality picture, not 1080p30, this box only show 1080i on all HD channel, Is it the Box problem or the technical problem...
1080p is not avalable on much right now, you will find it as a stp up option on some of the pay movies but HD is only 720p not 1080p yet. 1080i is the best you will get for now
Dec 16, 2010 | Televison & Video
TV set always starts up indicating 420p. How do I get it to 1080?I have Bell expressvu HD
is your cable or sat in HD(720p, 1080i, 1080p) over the air broadcast in the usa is in digital so it should start at the highest res available in your area
next are you using HDMI or composite for your cable or sat going into your tv if not your not going to get higher than 420p because A/V and S-video do NOT support HD
check your cable/sat box is it HD(high def) or SD(standard def) if SD going through cattv/attn in your only going to get 420p
now for changing the resolution its automatic it goes to the highest setting on its own
you can control the resolution through your cable/sat box, blue ray/hddvd player and other HD devices connected to the tv through the options menus of those devices BUT only when connected through
HDMI(supports 720p, 1080i, 1080p)
composite(supports 420p, 420i, 720p)
A/v and S-video(supports 420p)
cat tv/attn in(supports 420p, 720p, 1080i, 1080p) only supports what the tuner will do
i=50hz
p=60hz
Feb 11, 2010 | Hisense LHD3204US 32 in. LCD HDTV
I have the NS-PDP42 42" PLASMA 720-P and I would like to know how to change the screen resolution for hdmi devices. In the user guide it says to change it to 1280 x 720p but it does not tell how to...
There's no way to tell the HDMI input whether it should take 720p or 1080i input on this set. The best thing to do is experiment. Set your Comcast box to 720p and watch it that way for a while, then set it to 1080i and watch it for a while. The PDP42 has to do a little picture manipulation in either mode, but I think you'll find that the 720p mode will work best for you. I have this set with Verizon FiOS and I have the FiOS output set to 720p. Looks great, no complaints.
Jul 23, 2008 | Televison & Video
Ilo 42" plasma tv
Go the the settings on the cable box. look for output resolution, then change it to 1080i and 720p. now turn the box off and back on your tv will now display the input of wither 1080i or 720p depending on the hd channel your watching.
Dec 26, 2007 | Televison & Video
Sony 57 Inch XBR 2001
I don't have the XBR, but on my sony, using the cable box remote, I had to go into menu/display/etc. and mark the 1080i, 720p, and 480i settings. you usually get a "if you can see this" comment if your tv accepts the settings. for standard tv i set the screen to normal, and when the upper channels go to HD, they auto go to full screen. Sounds like you are using the component cable, and also make sure you are on the video port of remote, and the the TV input. The above worked for mine. Hope it helps.
Dec 04, 2007 | Sony KP-57XBR10 57" Rear Projection...
Electronics - Others Logo
169 people viewed this question
Top Pace Electronics - Others Experts
Are you a Pace Electronics - Other Expert? Answer questions, earn points and help others
