Question about Sony Handycam CCD-TRV408E Camcorder
Instruction manual says there is moisture in unit is it repairable
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
Yes you need to go buy some rice take out the battery open all acss to it put it in a big bowl por the rice over the handycam let set for 24 hours this should dry it up and with the battery out that should reset it but win you first cut it back on cut off agan take batter out put back in that will reset the code for you i hope this works i had to do the same thing to mine it might take a few times just repet it will work glad to help :}
Posted on Nov 09, 2012
How to recharge a dehumidifier with refrigerant
Good Afternoon Friend,
I understand your Frigidaire dehumidifier, model# FDF50S, is not removing moisture from the air, and you are wondering how to recharge it with refrigerant. First, I suggest making sure that there is a minimum of 12 inches clearance around your dehumidifier. This will help for the air flow. Secondly, make sure that the temperature where your appliance is located is between 41 degrees F and 96 degrees F. If it comes down to you having to recharge your dehumidifier, this is typically not a do it yourself fix, as there are no step by step instruction manuals for this. I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FDF50S Dehumidifier
Rapitest digital plus moisture meter manual
www.lusterleaf.com/img/instruction/1825_instruction.pdf
May 23, 2014 | Measuring Tools & Sensors
What a mess. The instruction manual (really lacking in detail) does not have part numbers or model description. Excess moisture dripping in refirgeration portion of unit (top freezer; bottom...
Yes it could, you will have to check your defrost water drain, if its plugged defrost water won't go to condensate pan under unit, instead will make its way down to refrigerator section
Jun 29, 2011 | Maytag Refrigerators
Bucket not filling, unit seems to be making more noise
If you are running and not pulling moisture first check air flow. Vacuum the front and back grills and make sure the coils are clean. If you have good air flow the cause of the problem is most like a sealed system issue. This is most commonly a refrigerant (freon) leak. check your use and care manual to find how long the warranty on the system is, sometimes it is as long as 5 years. If it is out of warranty then the repairs are more costly than a new unit.
Jul 24, 2010 | Whirlpool AD65USL / AD65USM Dehumidifier
My zen creative
My guess is there might be moisture damage to the unit. I'm afraid it's game over as repair costs are too high to attempt service.
Apr 19, 2010 | Beond Creative Technology ZEN X-Fi ...
How to fix a system error?
A system error indicates a possible software or firmware problem. If the unit is in warranty, contact Toshiba about a software upgrade (possible).
If it is out of warranty, the cost of repair is likely more than a new unit.
A system error can be caused by moisture (#1), physical damage (#2) and a possible software update issue. Your Toshiba Gigabeat Room software for your computer may be able to get upgrades for your MEG-F10K. Check the owner's manual. If you cannot connect to the unit with the computer to transfer songs and movies, it is likely not repairable for a reasonable cost.
Mar 22, 2010 | Toshiba Gigabeat MEG-F10K MP3 Player
My Maytag air conditioner won't turn on.
The red light on this model indicates, like a dehumidifier, that the internal condensation "tank" is full. This unit normally discharges excess humidity through the exhaust vent. When humidity is excessive the unit cannot evapoate all the moisture out the vent pipe. There is a black rubber plug in the back bottom of the unit. Get a very shallow pan that will fit under the unit and pull the plug. After it has drained completely, run the unit on fan only to continue to dry out the internals. After 30 minutes or so, switch to cool and it should run. If the unit shuts off again after about 10 to 15 minutes, you have some sort of blockage that is causing the moisture to backup and trip the sensor. You will have to take the back off the unit and remove the blockage.
Aug 20, 2009 | Maytag M6P09S2ACOM Air Conditioner
Will not reset
Per the operators manual you have to reset it. 1. Unplug the unit
2. Remove and refill the water tank, being sure to follow the Daily
Maintenance Instructions. Replace the tank onto the base.
3. Wait 5 minutes for the Automatic Shut-Off to reset.
4. After the 5 minutes, plug in the unit and turn the unit on to HIGH
(HI). The RESET light should now be off (if not repeat steps 1 through
3). In about 2-3 minutes, the humidifier will begin to produce
moisture.
Jan 03, 2008 | Holmes Products (048894556579) 4 Gallon...
Won't record or play back
Usually letting the unit open for a day in a dry environment is enough to resolve this problem. If you have done this and still get the message your moisture sensor is bad and needs replaced. It is in the vicinity of the video drum assembly. I don't know if you are capable of making this repair but any good repair shop should be able to fix it for less than $100 US. Good luck.
Jun 06, 2006 | Sony Handycam DCR-TRV240E Digital...
Sony Handycam CCD-TRV408E Camcorder Logo
21 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
