Question about Whirlpool Designer ACQ088MR Wall/Window Air Conditioner
ACQ088MR I got this a/c unit last june for my trailer up north--worked great--cold as ice--.Took it out for the winter, brought it home,stored it in the basement upright,just like in the window. Went up last week and out it in . Went in great.Slight tilt outside for drainage just like last year. Its cool but not cold. Went to bed and it was 82. Woke up and it was 78. tryin to fix it with out taking it out and luggin it home to the place i bought it . Any suggestions i could try before i take it in would be appreciated.. THANKS
  • Whirlpool Master
  • 909 Answers
One needs to check if fans are running correctly otherwise, gauges need to be connected onto system.  assuming the condenser(radiator) is clean.
Posted on Oct 24, 2007
SOURCE:
LG LW2416HR window AC / heat unit problem. Compressor will not shut off or cycle. It runs all of the time. Please see below for details.
Has to be a stuck relay or contactor. I'm sure it's a relay on a circuit board so likely the whole board will need replaced. Never opened one up and don't see a wire diagram. But, if you need heating, unhook the compressor. Obviously wrap any bare wires, obviously cooling works but will have to turn off breaker to shut down. Temporary fixes obviously but will get you by. Best wishes!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 15, 2017 | LG Heating & Cooling
I live in the northeast, can a mini pomegranate tree survive the winters?
The tree should have no problem surviving the winter as long as it is in a pot that you can bring in side. During the cold months, the tree should be brought in and put next to a window, preferably the sunniest one in your home. As soon as it starts to warm up, bring it outside. Mini pomagranates tend to blossom and produce fruit in late June/July/August.
Aug 05, 2013 | Garden
(Land Rover Headlights Fail in Cold Weather)
Sounds like a bad headlight Relay. If you have an Owners Manual you can look up the correct Relay in the Powerbox. You may find that Autozone,com has chassis and fusebox diagrams. Register for FREE on their site and then you can toggle down to diagrams and print or view what you need.
Feb 12, 2012 | 2001 Land Rover Discovery Series II
What type of tires would you recommend for winter driving?
latitude-x-ice.jpg Latitude® X-Ice®
Winter
Winter Tires
Better Starting Grip in Icy Conditions.
A special Winter Flex Compound, specially formulated to maintain its grip under the most extreme cold-weather conditions, including snow and ice, to help deliver better starting grip and shorter stopping distances.
Better Traction In All Winter Conditions
Cross Z-Sipes Technology uses a specially designed curve that locks the sipes in place, helping to provide improved grip on snow and ice. And because the sipes are full-depth, their grip lasts winter after winter.
Quiet, Smooth Ride in Cold-Weather Conditions
Dec 02, 2010 | 1996 Jeep Grand Cherokee
RV AC unit won't cool, blows chuncks of ice
It's most likely an airflow problem, you say you had the vents closed? Icing up is normally caused by lack of load (air flow) or loss of refrigerant charge. Make sure all your vents are open to allow for as much airflow as possible and that your filter is clean. Some units do not work well on low airflow setting when the outdoor temps cool down at night.
Sep 09, 2009 | Dometic Rooftop RV Air Conditioner
No start up
No its not. Bad valves are caused by dirty filers,dirty coils that cause liquid refrigerant to slug compressor and knockout the valves. Rus
Aug 17, 2009 | Ruud UAMB Air Conditioner
Fridge not cold but freezer working great
I had the same problem, and it turned out to be a cooked fan motor.
I couldn't find a reasonable (less than $150) replacement motor from Haier places, but I just took the motor out and took it to an appliance repair center (in North Denver)
They said it was a standard part, charged me around $22 for a new one and I was all set.
For my replacement motor, it was a reversible design, and was initially set to go the wrong way, so I had to reverse it.
Apr 04, 2009 | Haier HTQ21JABWW Top Freezer Refrigerator
2001 cherokee windshield washers not working
Can you hear it make a "buzzing" pump noise when you press the fluid button try it with the key on and the engin off so you can hear better? also do you live up north and is it or has it been below freezing? and if so are you using winter non freeze formula?
1, if there is no pump noise then first check the fuse box, unfortunatly it could be the pump had burned out from dry running.
2. MORE Likely if your in the North, people often forget to put in winter washer fluid espically if the car has been down south. ice crystals form in the hoses and block the fluid, easy fixes is to park in a warm garage over night once thawed spray all the fluid out and put in winter formula otherwise it will happen again.
3. you could have a dirt blockage in the hose if the pump is working and your not in the cold north, see if you can gently remove the hose near the bottle and have somone press the button see if fluid comes out then reattach and repet these steps till you find the blocked fluid hose.
Good luck.
Nov 24, 2008 | 2001 Jeep Cherokee
Heating & Cooling Logo
120 people viewed this question
Top Whirlpool Heating & Cooling Experts
Bill Long
Norman Al-Anbar
Dennis Boxerman
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
