My emachine has always had issues being slow sometimes freezing up and not shutting down...n e way I had it less than two years n its been my first computer in years so I did virus scans and all...ok today I start it up and the sound it was making was so loud so I shut it down tried three more times and the same last I tried I had it on less than five mins and it was so hot...too fast...idk about computers n e more...oh and it if very dusty I didn't realize cause u hadn't used to do being sick n recently started using regularly again...fan? What do u think...
    Master:
  • 545 Answers
Loud fan noise and heat are symptoms of a dusty machine. Use canned air or a blower and dust it out. You'll want to have the machine open for this.
Posted on Nov 09, 2012
  • Gjanas Nov 09, 2012
    So do you think the sound is.the fan being I have no money to fix it makes me stressed...so some one told me to clean it with a vacuum I did and looked inside with the flashlight and its all messed with dust in the fan area ...help!!!!!
graysand
  • 558 Answers
SOURCE: Sometimes when starting up computer freezes, I use
go into the bios f2 and choose the maintenance option load the defaults.save and exit.
Good luck
Posted on Sep 22, 2009
  • 3940 Answers
SOURCE: Inspiron 1100--fan has recently started running
sounds like the heat exchanger is clogged. Try using canned air blowing in both the air intake and exhaust to unclog the heatsink and also make sure the system has the most current BIOS version.
Posted on Sep 26, 2009
  • 12 Answers
SOURCE: Fan not going on and interface really slow
turn it off for an hour see if that works could be overheating
Posted on Dec 21, 2008
  • 6771 Answers
SOURCE: my laptop Sony Vaio CS
Remove the bottom pan to expose the cooling fan, clean all dirt out of the heat sink and fins,and clean fan, next remove the heat sink to expose the processor ic, remove the old thermal grease with rubbing alcohol, and apply fresh thermal conductive compound to the heat sink and processor, "not to much! just enough to cover the critical areas and assemble. In most cases this will solve the shutdown problem.
Posted on Apr 15, 2011
willem52
  • 359 Answers
SOURCE: My Acer Aspire 5517 keeps shutting off...
1. Check if the air duct inlet and outlet are free and free of dust.
2. If needed, clean it with a hard brush and vacuum cleaner.
3. Check if the fan is rotating, if not replace the fan unit.
4. Check if the fan is clean of dust, if so clean it.
Posted on Nov 16, 2011
A slow laptop
Many things can slow a laptop down. First, how old is this machine? Older machines must work harder to run today's websites and applications. If the machine is not that old, check to see how much RAM the machine has. Many laptops only have 2GB or less. This makes them run slower with the newer software and websites. Consider upgrading to at least 4GB if the machine is capable. Next, look at the hard drive. How much free space does it have? If there is less than 10GB free, you could be having space issues causing slowdowns. The OS and applications use free hard drive space during operation, but if the space is not available, this can slow down or freeze applications. Next, check the Recycle Bin. If there are a lot of files in it, it takes up space that can be used for the OS and programs. Clear it out, or better yet, empty it. Next, check the ventilation holes and fan assemblies for the unit. if the vents are clogged and/or the fan is not working, this will cause the CPU to run hot. This will slow down processing and possibly cause freezing and eventually, failure. Next, look at your browser. How many add-on toolbars does it have? Many programs add stuff to the browser without your even being aware. Each of these takes a little speed of the browser at work. Consider removing any toolbars that you aren't using or don't want. You can go to Remove Programs under Control Panel and see these there for removal. Last possibility is Virus or Malware. Even the best antivirus software won't find everything. You can download a free version of Malwarebytes at malwarebytes.com. This will find almost anything that is not desired. Any one of theses issue, and often, a combinations of them, work to slow down laptops to a crawl.
Aug 31, 2016 | Computers & Internet
Have issues with desktop freezing up and or slowing after I changed power otions. It used to cut out all together. It is an Emachine T5048
You should check your fan isnt clogged up with anything.
If its still slow it may be a virus problem. Scan your computer .
If this still continues then re-install windows
May 20, 2010 | eMachines T5048 PC Desktop
Dell computer, less than a year old, XP Pro, having problems freezing, especially when using applications like some browser-based games (my wife plays Happy Island and that stuff on Facebook), and also...
If your computer is less than a year old, you should be able to contact Dell technical support for help (support.dell.com)
It sounds like it's a driver issue - most likely video drivers. You can check the support website for updated drivers for your video card.
Jan 22, 2010 | eMachines T3604 PC Desktop
I have an emachine that is 5 years old. Always
YOUR PSU (POWER SUPPLY UNIT) MAYBE THE CULPRIT. If the power to your cable which fits the computer is ok, then the supply unit is usually at fault. You can buy these pretty cheaply on ebay and they are very easy to fit, or if you are not into that find a mate who can! beleive me... its pretty easy.
Jan 04, 2010 | E-Machines eMachines Desktop PC
Blows cold but shuts down no freeze up
Check the capacitor. It should be a dual capacitor , runs both compressor and fan. This sounds like your problem only because both the compressor and the fan go out together. Good Luck Hope I helped
Dave
Sep 16, 2009 | Dometic Rooftop RV Air Conditioner
Emachines w2828 keeps shutting down reboot/Screen Freeze
I dont thing this is a virus problem but a heat problem. if you dont mind getting inside the box see how clean it is and put your hand on the power box case .. then unplug all the hardware except the mother board then turn the unit on, if it goes on then plug 1 hardware at a time.
Sep 04, 2009 | E-Machines eMachines Desktop PC
Stays on for less than 60 seconds
Blow out the computer with canned air. If the heatsink is full of dust then its overheating. Dont leave it on over night either.
Jun 04, 2009 | E-Machines eMachines Desktop PC
E-machine computer will not shut down
When you say "it will not shut down", are you referring to clicking on start and then shut down?
You could try forcing a shut down by holding the power switch down for about 5 seconds.
Jan 18, 2009 | E-Machines eMachines Desktop PC
Emachine T6420 Motherboard??Turns off light flashes,very slow
This could be any number of things. Try removing and reseating the hardware - video card, memory, processor (power disconnected of course). The symptoms you describe could be cause by a faulty motherboad component, video card drivers, other operating system corruption, power supply problem, memory problem. I generally try to run a memory test or swap in known good components to eliminate things one at a time and hope to get lucky, but most likely you won't solve it without spending more time and effort than the computer is worth.
Dec 28, 2008 | E-Machines T6420 PC Desktop
Erratic behavior with Acer Aspire 9300
How about just reinstalling the OS and seeing what happens. If you are running Vista it is most likely just a bad original install. You should have installation discs supplied and you should have been encouraged to make your own reinstall disc when you first run the machine. If you did not then check your handbook to find out how to do it. It will make a disc from the ghost partition on the hard drive. use this to reinstall and take drivers from one of the original discs supplied with machine
Dec 09, 2008 | Acer Aspire 9300 Notebook
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
