Question about Watches
Need a cr1240 e battery
Needs 1 Battery
How to change battery -can't open case on Nouveau quartz men's watch
Take it to K-Mart jewelry dept. and ask them to take the back off to determine the battery you need. They'll do it and only charge you for the battery.
Jul 26, 2017 | Stainless Watches
How do I turn off eol on my tag
"EOL" means "End of Life." The battery needs to be replaced soon. I agree with other post. . . if you had the battery replaced recently, it was bad. I have had my Tag Kirium Formula One for 12 years and have only replaced the battery once.
May 10, 2014 | Tag Heuer Kirium Formula 1 Chronograph...
A friend just gave me a Bulgari B ZERO 1 WATCH that needs the battery replaced. I understand that it is a special battery - Where can I get one and does this model have a "battery recharger"
The battery is not anything special but the price of the watch is. MSRP about $4300. Why do you want to risk damaging this very expensive watch? Take it to a pro. I am a pro and see way too many watches trashed by people that think they know what they are doing. Sorry to sound harsh but destroy this watch movement by trying to save 10 bucks and you risk spending several hundred (see my eyes light up!)repairing it.
May 23, 2011 | Bvlgari B.Zero 1 BZ22WSDL Watch
On my Kirium F1, the digital display keeps blinking. How do I make it stop, or is this the signal that I need a new battery?
Yup, it means it's time to change the battery. However, if it's blinking despite having a new battery, it could be because the time and date needs to be set.
Here's a copy of the manual for more info :-
http://www.mediafire.com/?qgq1p3329sbe7s1
Hope this helps.
Jan 10, 2011 | Tag Heuer Kirium Formula 1 Chronograph...
I just replaced the battery on a fossil watch and it won't work. How to you reset it? or what else needs to be done? Please help me. thanks.
mcdevito75 here, Your Fossil watch should work with the battery change, of course it will need to be re-set. You"ll have to double check the battery install, make sure the battery contacts are clean, use a piece of paper towel and carefully clean the battery contacts. Hopefully your new battery is not dead. Another thing to check for, is that the buttons contacts are lined up with the quartz movement. While you double check your battery install, carefully press 1 button at a time, and make sure each button is making contact with the quartz mechanism, many times during a battery change to quartz movement may move just slightly but enough to keep the buttons from contacting the movement, this will keep the watch from working. Hopefully 1 or all of these is the answer for your Fossil watch.
Aug 22, 2010 | Watches
Second hand moving in 4 second increments instead of 1 second clicks. Does this mean it needs service or just a new battery?
This means it needs a new battery. But if your watch is about 5 years old it is best to have it serviced. The oils in the movement will be drying out and this causes the gear train to require more power from the battery to make it move. By drawing more power from the battery, the battery will not last as long. This shortening of the battery life continues until the watch is serviced or eventually a new battery will not get the watch to run.
All watches require regular service to stay working properly.
Hope this helps,
Ken
www.YellowStoneWatch.com
Apr 10, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
Tag heuer watch
its actually a new battery needed rather than a service.
Jun 10, 2008 | Tag Heuer 2000 WK1110.BA0317 Wristwatch
Watches Logo
23 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
