Question about Casio TV-880 2.3 in. Handheld Television
Do Symphonic WF2703 TV's have digital tuners?
Do Symphonic WF2703, Phillips Magnavox 19PR21C1 have digital tuners or will we need a digital tuner box?
Is the Magnavox TFT LCD 17 MF200v/17 have a digital or analog tuner?
I believe it has an analog tuner (NTSC) only. The original remote is pictured here: http://www.replacementremotes.com/philips/buy-313923807911-remote-control.html . The TV is listed as having been available in 2004 from Amazon.com. The manufacturer didn't have to include a digital tuner until 2005 for 36"+ models. For a 17" TV, they didn't have to have a tuner until 2007.
I hope this helps.
(You'll need to have a set-top box (digital-to-analog converter) to watch over-the-air signals.)
Jan 25, 2016 | Magnavox Televison & Video
Sebrent usb 2.0 tv tuner & vidio capsher box wolnt work with windows 7
This page has all of the Sabrent drivers available. I could locate the exact driver if I knew the particular model # of your box. Is it the TV-USB20 or the TV-USBHD with digital and analog tuners?
http://www.sabrent.com/downloads.php Do you need the video capture software?
Jul 10, 2014 | Philips TV Tuner Video Capture PCI Card -...
I have a symphonic wf32L6 and i dont want to buy a digital adapter box, doesnt this tv have a digital tuner
Yes it has a Digital Tuner/ HDTV Tuner. Go into the setup menu of the TV and do a digital channel scan. If you still have an issue, post a reply/comment and I will help you further.
Jun 01, 2011 | Televison & Video
Vcr/dvd combo recording problems
I would need your exact model # to get very specific, but in general:
The "External tuner" will need to come from your TV or a cable/sat box, generally. If your TV has a Video OUT or a Monitor OUT (most television don't), you can hook a yellow AV/RCA video cable from the TV to the Magnavox. You will also need to hook a red/white audio cable from the Audio OUT of your TV to the Magnavox.
Your TV probably doesn't have a Video OUT, so you will need to buy a box. A digital cable box for your cable service would be the best investment. Alternatively, if you can find a digital-to-analog converter box (but these are iffy). Once you have one of these box types, you will need to hook a red, white, and yellow AV/RCA cable from the video/audio OUT of the box to an available video/audio in on your television.
Once your connections are correct, the general rule with tuner-less recorders is: If you can see the channel that you want to record on the television screen, then you will be able to record it.
One final note about Feb 17, 2009: Thanks to Congress, the digital transition date was moved to June 12, 2009 - many areas have already switched, but there is at least a chance that you are in an area that hasn't switched yet.
Let me know the exact model # of your television, and I can tell you if it has a video/monitor out - or, let me know what type of box you decide to buy.
-Tha Mp3 Doctor
Mar 19, 2009 | Philips Magnavox DVD/VCR Dual Player
Does a magnavox model 27ms4504/17 have a digital tuner? Manufactured September 2005
Hi, Sorry it does not. It has an NTSC tuner which is analog. It will work after the change if you have cable or satellite. Hope this helps!
Feb 05, 2009 | Philips Magnavox 27MS343S 27" TV
How do I tell if my tv is analog
Hi Dru,
Good news, your 42 inch Phillips has a built in digital tuner, all you need is an antenna.
Please post the model of your other Tv and I will check on the tuner type.
I have provided a link to a site that has good info on antenna types and the channels you will be able to recieve.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if this was the information you requested and please rate this solution.Lone99star
Jan 25, 2009 | Philips Magnavox 42MF521D/37 Television
Do I Need A Convertor Box?
No, your television has a digital tuner built in. You will not need a converter box. When the switch to digital is made, simply use the auto scan feature to program all of the new channel locations. Instructions found in the manual here - http://www.p4c.philips.com/files/2/26pf5321d_37/26pf5321d_37_dfu_aen.pdf
Dec 27, 2008 | Philips TV Tuner Video Capture PCI Card -...
Is My TV ATSC or NTSC?
Yes, you will need a converter box if you are currently getting TV off-the-air with a rooftop or indoor antenna. This TV does not have a digital tuner. You don't need a box if this set is being used on a cable or satellite system (unless your service provider tells you otherwise).
Dec 10, 2008 | Philips TV Tuner Video Capture PCI Card -...
Does my TV have a digital tuner?
no that TV does not have a digital tuner on it, it does support digital signals via a digital set top box
kind regards and please don't forget to rate us
Nov 28, 2008 | Televison & Video
Casio TV-880 2.3 in. Handheld Television Logo
166 people viewed this question
Top Casio Televison & Video Experts
Henry  Thomas
Henry Thomas
mikeuk
Lawrence Oravetz
Are you a Casio Televison and Video Expert? Answer questions, earn points and help others
