Question about Kenmore 98702 Stacked Washer/Dryer
Just about all the water is out of the tub. when you pull the knob to pull it on, sounds like it is trying to pump the rest out, but it does not move.I sure hope that you can help!
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of the unit?
Look under the washer lid or inside the dryer door.
Posted on Nov 09, 2012
Washer didnt drain all the way and now i keep gettin a code. n the light for the door lock wont come on
If water is in tub and the control tries to drain tub but water doesn't drain, then the unit will not operate. Most LG have a drain pump clean out located behind the access door on lower side of washer. Open the door and you will see a black tube with a cap and a round knob. First, get a bucket, pull the black tube slightly out and remove cap. The water in the tub will start to drain and you may have to fill bucket many times to get all water out. Next, unscrew knob and a little screen will pull out. Inspect this screen and inside of pump chamber. Your looking for any thing that could block the pump. If pump hums and still doesn't drain, the drain pump is more than likely bad. Good Luck
May 25, 2016 | LG Washing Machines
Water does not come out of the bathtub faucet, but the rest of the faucets throughout the house are just fine...what is going on... Help...
You need a new faucet. Try popping the cap off the center of knob. Then take the screw out pull knob and lok to see if the insides are stripped out.while handle is off try turning valve with pliers if it works you need a new knob if not bew faucet
Feb 21, 2015 | Plumbing
The engine runs but the water will not come out under pressure
You must have blown out the cones (thats how the water gets compressed inside of pump) in the water pump-
You could try this though on the back of the washer right on top of the water pump is a black knob about the size of your hand that knob will adjust the pressure try turning it and see although I doubt that is the problem-
A pressure washer is not like a compressor you HAVE to pull the trigger every minute NEVER let it just sit there running without pulling the trigger to release the pressure that Dewalt 3800 psi washer you have is a great machine in fact we own 4 of them and they are pretty powerful and easy to damage if left running alone.
TY,
Perry Tradesman
Sep 05, 2014 | Dewalt 3800 PSI Pressure Washer
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Water will not drain out of barrel during spin cycle.
If you have the LG brand you posted under: Open the access door at the lower left on the front of the washer. Place the end of the small hose into a shallow pan and remove the end plug to drain the remaining water out of the machine. If water does not come out, the hose may be plugged with sand. In that case, pull the washer about 18 inches or so out into the room and tilt it back so the back rests on the wall and the front legs are in the air first before then removing the filter by unscrewing the big knob in that access area. Clean out the filter and reassemble. Test. If still no pump out, the pump impeller may have come off the pump motor shaft, which would require pump motor replacement.
Sep 15, 2009 | LG WM2688HWM TROMM SteamWasher
Humming from Water Solenoid area
It may have some dirt or sediment clogging it making it work harder than usual.
Jan 23, 2009 | Washing Machines
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
The water is not getting picked up when the pump runs
sounds like you need to prime the pump manually:
Fill water tank.
Turn power on.
Open the steam knob all the way.
Press the coffee button.
Put a cup under the steam pump wand.
Wait until you see a steady flow of water and no air.
When you see the flow of water, close the steam knob.
Turn off the coffee button.
Now the machine should be ready to brew an espresso.
You might need to do this if you have not used your espresso machine for a few weeks or if it has been moved.
if that does not work contact the service center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Sep 26, 2008 | Espressione XP1 Espresso Machine
My washer wont spin out
kinked hose or blockage in the water pump you defininatley have material in the water pump
disconnect washer all together pull out after you drain the water by hand as far as can go use a dolly take out side drain the rest by tipping on side you might need 2 or 3 people to get the washer out with little water left when on side pull the water pump off look inside and pull material out with a pair of needle nose pliars that clamp you will need 2 people to pull out material one to hold the pump and one to pull material out with pliars
once done before you put back together do a lube on your washer with appliance oil this will insure good maintenance
what i decribed at top is the non costly way to fix your own washer if there is material stuck in water pump
Jun 13, 2008 | Maytag Washing Machines
Kenmore 98702 Stacked Washer/Dryer Logo
14 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
