Question about Hitachi Heating & Cooling
Hitachi 1 week old hitachi doesnt heat a room of 12m2 the model is RAC- E14H2 indoor RAS-E14H2A. Set a temp to20degrees works for an hour restarts again but never reaches 20 it drops to14 air is luke warm 30cm away from fan
    Scholar:
  • 67 Answers
I would really call your installers back mate.
If you have anything to measure air temp with I will take you though some tests.
But at this point I would say that your air con does not have any gas and the installers should come back. If they will not come back you should contact Hitachi warranty
Hope this helps
Posted on Jan 11, 2009
Split a/c. RAS/RAC-35YHA3 1. Book says Green light on, filter needs cleaning. Filter and air way clean. ?? 2. Heat function ok, Cool function ok. Auto, heater comes on and keeps going. I swictched back to...
I believe the filter light is just a timer set for "x" any days or month. Most t-stats are that way. If you have the manual, you can reset it. Also make sure fresh batteries are in the controller. Good luck.
Apr 05, 2011 | Hitachi Heating & Cooling
Hi all, I have Hitachi central A/C RAS-4010MX2, and it is 10 years old... Last week, the heating system stopped working and that happened out of nowhere... do you mind me asking what could be the...
Check power to heating element. If not, check contactor relay is energized. If not, replace relay. If power is there, heating element condemned. Please replace it. Thanks.
Feb 05, 2011 | Hitachi Heating & Cooling
Hi, I have Hitachi model: RAS 63CHA4/RAC 63CHA4 The indoor unit looks working for the fan function, but not for the other function. The fan on the outdoor unit looks not working. What is the problem?
Is your compressor is working? If so, check motor to rotate manually. If hard to remove, replace bearings or motor. If easy to rotate, replace capacitor.
If your total out door is not working, check for power in out door unit. If not communication error between indoor and out door, provided you keep in right setting. If so, replace your indoor PCB.Helpful?
Jan 15, 2011 | Hitachi Heating & Cooling
My hitachi ductless split room air conditioner with heat pump is not heating my room , i have cleaned out the filters and unplugged the unit for 10 min and plugged in back in and it only blows cool air , i...
dear sir
please reset you air conditioner by it,s remote to heat mode and check thermostat setting maybe it has been turn off after remove air conditioner,s electric supply plug from electric source . i hope after reset it will be able to work again.
hope answer the question
thank you
please vote!
Oct 03, 2010 | Hitachi RAS-09UH Air Conditioner
Red blinking and ac not working
If the power "flickers" and unit fails but will restart once the breaker is reset, this sounds absolutley normal. It is a safety device that keeps the unit from burning up things due to improper power being supplied. As long as resetting puts it back into service with no issues, don't worry about it.
May 12, 2010 | Hitachi RAS-09UH Air Conditioner
Blowing out warm air
Turn thermostat switch to 'cool' setting. It's a 'heat pump' and is in the heat mode.
Nov 05, 2009 | Coffee Makers & Espresso Machines
Odour from ac
There is a problem with heat pumps known as "Dirty Sock Snydrome". Research this on the web as this may be your situation. It is a smell produced by micro bacterial growth on indoor coil. Contact a local HVAC company for solutions if you determine this is the cause of odor.
May 22, 2009 | Hitachi RAS-09UH Air Conditioner
Hitachi RAS-25CHA will not work after power supply -brown outage.
Is the unit responding to remote instruction at all? It does sound like your board is gone. This is usually a capacitor (blue or green and round flat disc) on the pc board, and possibly one of the diodes (small black cylindrical shape with a white line on one side) Often it is the compressor drive relay (rectangular black box) on pc board. If however you have managed to find a replacement board. The plastic heads holding the pc board are released by using a small long nose pliers and pinching the bit sticking through the board. The rest is simply a matter of changing one wire at a time from old board to new board. Or a good method is just to take a snapshot with a camera to refer to regarding the wire positions.
Jan 30, 2009 | Heating & Cooling
Heya,
I am an ex warrenty agent for Hitachi in Western Australia and I will be able to take you through some tests if you want. But from the sounds of it I think that you will be up for a new indoor PCB as these are the most common things to go when there are power failures. If you would like me to go through it with you let me know. But first where abouts are you in Australia?
Jan 08, 2009 | Hitachi RAS-09UH Air Conditioner
Heating & Cooling Logo
235 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
