I have no power light on TV. Got back panel off and looked for fuse. Cannot find it! I suspect fuse is problem as I have power to the TV via the power cord, but no red standby light on TV and TV will not power up. Any assistance would be appreciated.
SOURCE: Insignia NS LCD32 standby light blinking off and on. No Power
I had this problem as well. Actually best buy just left my hosue to fix it. This is the second time they were here to fix it. The first time they said a part was loose. This time they had to replace a part.
SOURCE: insignia 15 inch lcd tv cant find replace power cord
part # 485-10144-00
try http://bestbuy.partsearch.com or
https://www.vancebaldwin.com
neither have it but there you go
thanks
scott
SOURCE: Insignia IS-LCD TV 26 Will not turn on
The power supply will need to be replace or repair if the LCD failed to switch to the blue light.
I repair these power supplies.
Let me know if you need further assistance.
SOURCE: 26" Insignia LCD TV will not power up. Green Light Blinks 1x
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay
particular attention at inverter and power board, power board can be
inspected looking for bulged or leaking capacitors, then tested with a
multimeter. The inverter is more difficult to test , there is need to
read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
SOURCE: INSIGNIA LCD won't turn on
replace 2 condensers in the power supply with greater voltage ones.original are 1000uf 35volt...use 1000uf 65volt...99cents each
power circuit is made to fail with typical tv industry tactics...the warranty is reflected by the life of their condensors (capacitors) average life is 2000 hours..
easy...huh
if your a smoker...you must clean the button cover as they get stuck on with your stupid tobacco residue. 75% of all LCD tv's that smokers own fail this way...
\tough huh?
TRY TO STOP SMOKING...
