Question about MSI Wireless-G RG54G3 Router
How do i encrypt my system
I want to encrypt my MSI RG54G3 wireless router. It has been installed and is working fine but it isn't encripted.
  • 104 Answers
Hi, I will lend a hand if I can.
There are four basic steps to set up wireless security:
1) Login to your router
2) Change the router login password/username
3) Change the network name, or SSID
4) Enable WPA encryption
As you only want encryption, I will go straight to step 4. The following is based on the manual for the MSI RG54G3.
Here are the details:
1. Login to your router.
2. Go to Setup> Wireless.
3.
Select WPA-PSK - strictly speaking the correct option depends on your wireless adapter. However, this is usually a good choice to start with. You may see one or more new options pop up. Select ASCII if necessary.
4.
Under ‘Pre-Share Key’ you should enter a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers ( eg - 456HappynEWYeartoyou8899). It is case sensitive.
5. Note down the ‘Pre-share key’, also called the network key, carefully. You will need this to connect wirelessly. (The network key may also be called a WPA shared key, PSK, pre-shared key, passphrase, authentication key). Click ‘Save’ when finished.
When you next attempt to connect wirelessly, you are asked for the network key you've just set up. If all goes well, you can then save this and will connect automatically in future.
Hope this helps, but if it is not clear or doesn't work, please come back to Fixya. Good luck.
Posted on Jan 05, 2009
  • eecom Jan 06, 2009
    PS: Important: Use a wired (ethernet) connection when setting up security.
I have lost the pass code/security key for the Msi router at my mother's house. What can I do to retrieve it? Nick
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer/laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Dec 22, 2010 | MSI Wireless-G RG54G3 Router
Remote access working
DOWNLOAD TEAM VIEWER INSTALL IT ON BOTH PC'S
Apr 17, 2010 | MSI Wireless-G RG54G3 Router
Wireless not working/cable working
This problem occurs when the wireless card in the laptop has not been configured with the wireless router's settings ie the SSID and encryption settings.
Please click on this link and follow my instructions to secure your wireless network, configure your wireless router and the wireless card in the laptop. :-
Jan 25, 2010 | MSI Wireless-G RG54G3 Router
I have connected MSI RG54G3 to a caple and it's not give me ip and internet access
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
Dec 01, 2009 | MSI Wireless-G RG54G3 Router
MSI
The Pre-shared key is used to setup encryption on wireless routers.
The latest strongest encryption methods used is Wi-Fi Protected Access (WPA and WPA2).
The wireless router is configured with WAP or WAP2, and the computer's wireless card is configured with the router's WAP or WAP2 encryption. The wireless router will now allow communication with the computer's wireless card, data transmitted between the router and computer is encrypted and therefore protected from unauthorized access.
Sep 08, 2009 | MSI Wireless-G RG54G3 Router
How can you set up a network of 4 computers with a RG54G3 router?
*** configurez router ,ca nu am cd la el nici manual rg54g3 msi
Feb 26, 2009 | MSI Wireless-G RG54G3 Router
Wireless conncection
depending on who your ISP is, you need an ethernet cable coming from the modem into the WAN/Internet port on back of router. Once that is in you can try to connect wirelessly using the settings your router is setup for :
SSID/network name
encryption type
encryption key/passkey/passphrase
-- this part is dependent on above setting
wireless channel
Jul 08, 2008 | MSI Wireless-G RG54G3 Router
MSI rg54g3 ieee802.11g vista driver
Generally you do not install a router onto a PC you connect to a router with a wire using a network adapter or wirelessly with a wireless adapter. Can you any of the following you have identify you make and model of PC, make and model of add-on adapter card? Then I may be able to assist you in determining if a driver exists for the device attached to your computer intended to communicate with the identified router.
Thanks
Dec 09, 2007 | MSI Wireless-G RG54G3 Router
Msi rg54g3
i take it by your comment "unauthorised people been accessing it" that you wish to use the router wirelessly? do you currently have any type of encryption set up on the wireless signal at the moment eg WPA(2)-PSK, WEP, etc?
Sep 17, 2007 | MSI Wireless-G RG54G3 Router
MSI Wireless-G RG54G3 Router Logo
474 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
