Question about Pentair Plumbing
I cannot keep my pump primed
This is a fountain that just stopped one day. I first made sure the tank was full which it was, the pump was running, and I tried repeatedly to fill the basket, replace the lid, but the water just sucks out. All valves are open so I'm not sure what is going on. My landscape guy suggests digging out the rock beneath the fountain and check for some type of blockage in that line. To me that's a really expensive option. I'm not sure if anyone here has had this type of issue but any help at all will be greatly appreciated.
  • 90 Answers
SOURCE: maytag mzd2766gew icemaker
Sounds like you have a bad motor module on the icemaker. Part # is W10122536
Posted on Jan 05, 2008
  • 68 Answers
SOURCE: toilet tank fill valve sprays water towards lid
Hi bpmorr1,
It may be that the fill tube has come disconnected . It runs from the top of the fill valve to the overflow. The overflow is the tube that runs up the middle of the tank. The fill tube runs from the top of the fill valve to the top of the overflow tube. Kohler has a little clip that can sometimes come undone and cause spraying.
If that doesn't do it, turn the water off to the toilet and take off the tank lid. Partially open valve ( Slowly). Locate where spray is coming from. If it is in the area on top of the fill valve then yes, buy anew one. ( Fluidmaster )
Please rate this response and good luck, Phil
Posted on Dec 27, 2008
  • 6 Answers
SOURCE: i have a flotec water pump that sits on top of my
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
Posted on Apr 06, 2009
gbaker30
  • 4 Answers
SOURCE: fountain pump keeps tripping the GFI
install a standard outlet with a weather proof box and you will have no more problems
Posted on Jun 26, 2009
SOURCE: Water does not run through to espresso basket
My 40729 would not pump water. The pump made a sort of muted sound (not loud as it normally is) and would not pump.
I took off the top of the machine and discovered that the valve in the pump was simply stuck.
Here's what to do: at the 'water out' end of the pump there are two brass fittings that are joined at ninety degrees. The vertical one screws into the horizontal one. the vertical one has a nylon (beige coloured plastic) fitting attached with three tubes attached to it: one is screwed on and the other two are pushed on. Remove them.
Then turn the whole assembly (nylon part and vertical brass fitting) and screw it out of the horizontal brass fitting that is on the end of the pump.
The nylon assembly will come apart by prising the snap-fasteners apart. Inside you'll find the valve, comprising two springs a rubber washer and a red 'ball'.
MAKE SURE YOU NOTE CAREFULLY WHICH WAY THESE COME APART.
The red 'ball' is actually slightly conical and is held in place to close the valve with the larger spring. The red ball is displaced by the water pressure of the pump, but it sticks in place and can't be shifted. use a fine screw driver to displace it (loosen it) and then re-assemble everything.
I had to make a washer where the two brass fittings join at nintey degrees to prevent a drip at the join. (I used foam, but a flat rubber washer or even cereal cardboard will do the job.)
It is working fine again.
Posted on Jul 01, 2009
Have deep well vetical sta rite pump both pipes in ground staying full of water will not pump press does not looose prime but wont build press
shut off pump breaker at the lowest faucet drain completely. Turn it back on. If this doesn't work, you have to change out the pressure valve on the side of the tank. it's not hard.
Oct 08, 2012 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Just changed the fuel filter on a John deere 1020, is there a way to prime the injector pump?
If the fuel filter is full when replaced it shouldn't be necessary. But if you have access to compressed air, put air to the fuel tank and that will do it. Hope that helps ya.
Dec 21, 2010 | John Deere Fuel Pump Fits 1020 Thru 4230
Sprayer will not stop pumping when switched to pump mode after primed it will not shut down it just keeps pumping. .
Paint sprayer.
Flip lever down to prime > paint comes out small plastic hose.
Flip lever up to put pressure on spray line.
Problem: prime keeps running and spray line never gets pressure.
Future solution:
You did not clean sprayer very well last time, or it is rusted. When cleaning, run full 5 gallons of cleaner through machine twice.
You should fill spray line and pump with kerosene if machine sits idle more than few days.
We all forget.
Good news: you have prime. If machine doesn't prime, you probably have to disassemble.
More good news: There are two steel balls inside pump. Tap top one with hammer to loosen. Keep machine running. Keep lever up. Start tapping top one. Tap a little harder... keep tapping ... sometimes it will not free up ... take apart pipe and see if you can nudge ball loose >> be careful not to scratch anything... the sprayer is high pressure and all parts have to fit
Oct 07, 2010 | Garden
Water not coming at full force from pool into pump basket
It sounds like your pool pump is either not primed or is not strong enough to provide adequate suction. Check to make sure the pump is properly primed. Check for cracks in the lines that might also cause loss of pressure in pool pumps.
Jul 01, 2010 | Sta Rite 1 Hp Above Ground Pump Ne641
How to prime a sta rite mse 7 deep well pump, when I've filled the 1 inch pipe plug with water and it won't fill.
have to fill the housing complete with fluid. make sure there is no more air in it. also make sure that is not poss. to **** air. also the sucktion side must be full of fluid. watch rotation direction. pump is not able to **** from under 7 meters.
Feb 08, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
How do I prime the STA-RITE DS3HF-01?
I have a sta-rite mkse-6 pump and it has lost its prime..... how do I prime it???
Feb 15, 2009 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Plumbing Logo
26 people viewed this question
Top Pentair Plumbing Experts
kli99gunrunn
Gil Shultz
Jay Finke
Jay Finke
Are you a Pentair Plumbing Expert? Answer questions, earn points and help others
