Question about Element Electronics 40 in. LED HDTV
Problem with HD channels on Elent 40" LCD HD TV
Basically, the television turns on. The channels change. The volume works. The issue lies in the source: when it's on the "TV" source option (despite the HDMI cord being hooked in), all of the channels work, even the HD ones, they just don't have HD quality. When I switch the source to HDMI 1 (or 2 or 3 - I've tried them all), the quality looks GREAT for about ten seconds and then it goes in and out until I decide to turn it off. I have used multiple cable boxes and HDMI cords. It is obviously something with the television. Any thoughts?
    Sergeant:
    Champion:
  • 296 Answers
Could be the HDMI bank, try the DVI hook up, you won't have HD but it would give you knowledge.
Posted on Apr 25, 2017
  • 125 Answers
SOURCE: low volume on some channels
Well, some TV stations do broadcast at different volume levels. This is very noticeable when watching a TV show and the volume seems normal and then when a commercial comes on, the volume is very loud. They do this to get you to pay attention to the commercial. Another problem might be that you are adjusting volume from both your TV and your cable box. What you should do is make sure your cable box is set to "FIXED VOLUME" and then just adjust your TV volume. Fixed volume will have the cable box output only one volume level, letting the TV do the adjustment. Just go through your cable box setting and look in the audio settings. Hope This helps...
Posted on Mar 14, 2009
tvtek
  • 1284 Answers
SOURCE: Signal keeps coming and going whether I'm using
This is a very common issue with HDMI is compatibility. The compatibility problem is more likely the source and not the TV itself. The only work around is to use the component input as these are analog and don't have to go through basically a "handshake" as HDMI does. Please take a few moments to rate my answer. Thanks...
Posted on Nov 19, 2009
SOURCE: hey i have an element electronics 19
I have a 22inch element TV. just 1 year old. When it is turned on picture fades in and out.still have sound.it is connected to cable.
Posted on Dec 30, 2009
  • 1779 Answers
SOURCE: My dad has an element LCD tv that won't turn on. I
Looking is one thing and testing is another. You will have to check for the 5 volt standby on the power supply then check for activity from the micro to turn the power on to the run state.
Posted on Jan 14, 2010
SOURCE: I have an Element 32
I talked to the manufacturer & they said that all I needed to do was to run the channel search, uninterupted, again. I did it & everything works. Thank you for your input.
Posted on Mar 23, 2010
3D tv issues with HD channels on Dish Network
check screen resolution of your lcd tv & receiver too
Aug 24, 2012 | Dynex DX-L42-10A 42 in. LCD TV
My samsung le32r74bdx remote control wont change channels and cant turn volume on tv up or down
You can verify that the remote is working. Get a digital camera with a LCD display.
Aim the remote at the camera lens and press the volume and channel buttons. If you do not see
a flash through the camera the remote is bad or the batteries are dead.
If you know someone with any samsung hdtv remote, you can borrow it and try the volume/channel
to see if the tv remote receiver is good.
Feb 08, 2011 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Volume keeps turning itself up philips lcd tv
this is due to surface mount capacitors going faulty on the side buttons panel. You can simply disconnect the cable from this board and use you remote to control the channels and volume. if you want it fixed you will have to replace the side button control panel which is a cheap part.
Jan 29, 2011 | Philips 37PF5521D 37 in. HD-Ready LCD...
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Cannot turn tv off with power button or remote , must unplugpower
It could be a stuck button on the set. check to make sure they all feel the same.. If one don't feel right try to free it .. If a button is stuck it wont let any of the others work or the remote.
Mar 29, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
No sound when Wii is switched on
DID YOU TRY PLUGGING YOUR COMPONENT CABLE INTO A SCART ADAPTOR FOR YOUR TV...THIS SHOULD FIX IT FOR YOU.... I TAKE IT YOUR TV IS A 5 SERIES OR A 6 SERIES SAMSUNG.. GREAT TVS HAVE ONE MYSELF, BETTER WHEN MORE CHANNELS ARE BROADCAST ON FULL HD BUT...
Jan 11, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
PHILIPS 32PF7331/12 LCD TV
Press tv on sky remote then press help ,channel list appears . goto tv set use onset channel change button to scroll to hd channel .press volume up button onset to select.
Sep 28, 2008 | Philips 26PF5320 26 in. LCD Television
Sony BRAVIA KDL-40S2000 40 in changing from HD to digital channels
40X2000, both PS3 and DVD player are using a HDMI input and both flicker and loose signal fully, have to turn TV of then back on to get signal back. Sony say they have never heard this problem and replaced board. NOTHING fixed, still same problem.
Mar 09, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Multiple issues with tv
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Feb 21, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Digital Tv stopped working
I have got samsung 40 lcd is working fine but dtv got stuck on one channel. Its not moveing from one channel I have tried everything. Its not workig. please can you email me your suggestion to solve this problem.
Email address: fazalhareef@yahoo.co.uk
Dec 15, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Open Questions:
See all Element Electronics 40 in. LED HDTV Questions
Element Electronics 40 in. LED HDTV Logo
61 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
