Question about HP Photosmart 7850 InkJet Printer
I have hp photosmart 7850. I was printing envelop and there was paper jam. I pulled out the stock and jammed envelop and ever since the printer would not load paper to prinit and keeps flashing for error. Please help me.
    President:
  • 8,637 Answers
I have had this happen to several people and also to me. What I did is to take a sheet of Card Stock (Heavy Paper) and put it through the feed putting pressure on the Card Stock and pressing on the feed button. What happens is that a piece of the jammed envlope or document gets caught in the feed way and will not allow the document or envelope ( in your case) to pass. It should solve your problem if it works. Bud
Posted on Jan 06, 2009
HI, I'm trying to print on an envelope. The dimensions of the envelope are 8.75x5.77. Every time I do it there is a paper jam. Please let me know what I can do. Thank you!
try using paper of correct material. ideal would be 170gsm to 180 gsm paper. try not to use cheap envelopes in the market.
go and buy the envelopes with 170 - 180 gsm papers
Feb 24, 2011 | HP Photosmart C4150 All-In-One InkJet...
HP Photosmart 7850 Service Manual Required
hi i brought hp photosmart 7850 of ebay please could anyone tell me how many leads should there been with it
Nov 12, 2009 | HP Photosmart 7850 InkJet Printer
I have a paper jam on my HP 3210 Photosmart All-in One
When you open the back door there's a guide that pulls down and on either side of the fuser there are levers to release the pressure from the rollers, if you can see any of the envelope from there you should be able to gently and evenly pull it thru. Otherwise a shop repair to remove the rest and fix whatever caused the jam.
Sep 04, 2009 | Brother HL-2040 Laser Printer
My 5610 wont print on cardstock, creates paper jam!
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
alkkk-2
Jul 13, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Photosmart 7550 - Full Page Photo Printing Jams at end
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 17, 2009 | HP PhotoSmart 7550 InkJet Printer
Jamming paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Dec 30, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 photosmart all in one printer jam
Thank you for coming back. I decided to return the printer to the retailer as it is just inside the warrany period.
Rgds
Apr 28, 2008 | Office Equipment & Supplies
HP c6180 photosmart all in one printer jam
On the back of the printer there's a door.
Depress the latch and remove the door. This will give you easy access to the rollers and should give you enough space to remove any remaining paper from the jam.
Best of luck!
Apr 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart 7850 InkJet Printer Logo
238 people viewed this question
Seeker5211
Seeker5211
